Brutal Gas Mileage? 2013 TRD V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soosage, May 29, 2013.
  1. May 29, 2013 at 1:33 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Im 15 mpg around the city with 2" lift and heavy TOYO ATII's
  2. May 29, 2013 at 1:40 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    my UG says 17.2mpg... i paid $3.70 for high-test yesterday, and i thought my life sucked.
  3. May 29, 2013 at 3:11 PM
    Soosage
    Soosage [OP] Member
    Chad
    Calgary, Canada
    2013 Trail Team TRD
    I'm not complaining. I'm asking cause most people here seem to know and care.
    I just put a K&N in it today. When I had my Nissan truck the K&N made fuel mileage worse (?) Not sure why. I have an automatic with the TRD exhaust. I am curious to see if letting it breathe a little more will help.
  4. May 29, 2013 at 3:28 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    The K&N is going to make little to no difference to your mileage.
  5. May 29, 2013 at 3:32 PM
    Dguy
    Dguy Well-Known Member
    Ottawa, Ont.
    TRD Sport
    I just got my best mileage the last 2 tanks. 2012 TRD 4.0 DBLC with 20,000km. The last I went 601 km on exactly 70 litres. Previous I went 525 km on 63 litres. I run premium fuel and synthetic oil. This is a mixture of running around and hwy driving on both tanks. I can live with that. I get my premium for just a few cents more per litre than regular and it makes a difference, especially over the ethanol regular.
  6. May 29, 2013 at 3:35 PM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    The TRD exhaust will look a little prettier and lighten you wallet but, unfortunately, that's all it will do for you. :rolleyes:
  7. May 29, 2013 at 3:39 PM
    jw1983
    Alberta
    When I had my DCLB I was getting 580 km on 60 litres(highway only). When I ran premium(city only) was getting just under 500 km instead of the 440 km I was getting with 87 octane.
    With my Access Cab Long box I am getting around 440 km at 70L(City only). I was getting around 575 km(highway), also on 87 Octane(70L). I haven't ran 89 Octane in my access cab yet.
    Some people say that running premium is better than running 87. Other peoples say 87 is better etc. Weather who you ask, it's what you prefer. It maybe worth it for your truck, it may not.
  8. May 29, 2013 at 5:15 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Don't forget guys....the US gallon is smaller then CDN gallon.... we are 4.5 liters...they are 4.0
  9. May 29, 2013 at 5:23 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I get 16 mpg in mostly rush-hour driving, which matches the EPA city milage exactly. The few long trips I took (70 mph cruise control), I got 21 mpg.
    Don't confuse city and highway milage. It's easier to get good highway milage with a tall 6th gear and cylinder deactivation. In the city, there's no hiding a 5500 lb weight of a full-size. If the OP is getting 16 mpg with the Taco, he'd be getting 14 mpg with a full-size V8.
  10. May 29, 2013 at 5:25 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    I would love to get 16 mpg. I only get 12-14 mpg at the most.
  11. May 29, 2013 at 5:37 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Nope, neither intake or exhaust will help your mpg. Pretty simple, unless you are flooring it at high rpm you throttle plate is almost closed and a huge restriction relative to air cleaner. Same with exhaust, at part throttle the stock exhaust can flow all the engine is producing. Never has been true that tuning for more high rpm power means better mpg at low rpm when "not using it".
  12. May 29, 2013 at 6:28 PM
    peiscooter
    peiscooter Well-Known Member
    Prince Edward Island
    2021 TRD Sport
    Expect 16-20 mpg depending on your driving conditions. Highway mpg will be slightly better. I used premium for a few thousand km, then switched back to regular. No difference. However, we don't have any ethanol in any grade here. That shit will kill your mileage in any vehicle.
  13. May 29, 2013 at 6:31 PM
    mistahgood
    mistahgood Active Member
    Mistah
    South Carolina
    2013 Tacoma Access Cab 2wd 4cyl
    Exactly why I got the 4 banger.. I'm getting about 28mpg (80% highway/rural roads)
  14. May 29, 2013 at 6:36 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    I just filled my 2013 TRD Sport for the second time. I got 17 mpg on both tanks. I added TRD exhaust half way on the second tank and was romping on it quite a bit. Haha.
    (I drive 45 - 60 min, in stop in go traffic to work; and 30 min cruising speed on the way home.)
  15. May 29, 2013 at 6:42 PM
    #35
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    got 23mpg running 89 octane in my '12 sport on the highway (75-80 mph). greatest day of my life... probably wont see that again anytime soon
  16. May 29, 2013 at 6:44 PM
    #36
    mikebuyscars
    mikebuyscars Well-Known Member
    Fenton, MI
    21 Toyota Tacoma double cab TRD Off-Road Voodoo Blue
    2 inch lift
    I average 16-17 mpg around town. Lots of start and stop taking my kids to school in the morning and to work. My first road trip only yielded 11 mpg towing my pop up with a bike rack on the front of the trailer. it sits high enough that it's like towing a hardside camper. That and I was doing anywhere from 70-80 MPH. When I go up north unloaded I do expect to break 20 from what I am reading in this forum.
  17. May 29, 2013 at 7:21 PM
    #37
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Cant wait to drive through Canada this summer! Lol
  18. May 29, 2013 at 7:34 PM
    #38
    BZP56
    BZP56 Take a shower, shine your shoes...
    B.Z.P.
    NM
    13 DCSB
    Just filled my 2013 DCSB V6 4x4 up for the second time. 17.3 mpg, probably 60/40 city/highway. Actually I am quite pleased. My old 3.0L V6 ranger got about 14 average. Thing couldnt stay under 3000.
  19. May 29, 2013 at 7:37 PM
    #39
    tommyg29
    tommyg29 Well-Known Member
    South Miami, FL
    12 DCLB PreRunner Sport
    I average 17mpg with my stock 4x2. Typical 50% city driving. Over the past year I have averaged about $3.50 per US gallon so about .21 cents per mile for me, and wish and would think these trucks could do better....but they dont :(
    At least it does better than the truck I traded in- a quad cab SRT-10. Try 9mpg premium. That gets old fast when youre using it as your driver.
  20. May 29, 2013 at 8:42 PM
    #40
    JayAre
    JayAre Well-Known Member
    OR
    13 TRD Sport DCLB
    here's mine since the day I bought it...
