BruteForceFab Rear Bumper GB #2
Discussion in 'Group Buys' started by ironman44bear, Jul 29, 2012.
Thread Status:
Not open for further replies.
  1. Sep 15, 2012 at 8:17 PM
    #321
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    oh sweeet, that means me next \\ i think
  2. Sep 17, 2012 at 9:27 AM
    #322
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Billy, Do you have a recommendation for a license plate flip bracket that actually fits the holes in the bumper? :D Can't get mine to work. Lol
  3. Sep 17, 2012 at 11:00 AM
    #323
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    From what I can tell - the holes in the bumper line up for the license plate only.
    You will have to drill a new set of holes for a flip bracket unless you come up with some sort of custom adapter.
    I've looked at several flip brackets and they all appear identical to me.
  4. Sep 17, 2012 at 11:06 AM
    #324
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    Yeah you have to drill new holes to mount the flip up bracket. I do not think you will find one that will fit into those preexisting holes. You'll also want to do testing to make sure you can flip up the plate with no problems as well as clear the hitch.
  5. Sep 17, 2012 at 11:09 AM
    #325
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    I modified the $15 bracket to fit the holes .. but then it was too high to flip-up and I needed a break. I will tackle this again soon, but I'm pretty sure it can be done with minor modifications.
  6. Sep 17, 2012 at 11:18 AM
    #326
    whiteboy
    Cody
    Glendale, AZ
    '06 TRD sport
    Let me know if you find a way. I just drilled new holes called it a day.
  7. Sep 17, 2012 at 11:35 AM
    #327
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Took the shackles out to bring them to get powdercoated and already down to bare metal spots in the shackle hole...DERP lol(I have a feeling all the rain had a part to do with it..lol)
  8. Sep 17, 2012 at 1:02 PM
    #328
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Mine is the same way. Its just that metal on metal rubbing and the fact that the hole is pretty small so its hard to get a lot of paint in there. I don't see it as being a problem, just get a lil surface rust
  9. Sep 17, 2012 at 1:15 PM
    #329
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Ok cool beans :) Dropping off shackles to get powder coated..probably industrial red...they said they rarely do white..plan to ask them to sandblast the whole thing then not powdercoat the pin and prime/paint that myself.
  10. Sep 17, 2012 at 1:22 PM
    #330
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Damn! Reds bright!!! And im painting my shackles and front bumper right now! Woohoo
  11. Sep 17, 2012 at 1:25 PM
    #331
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I hope they can show me a sample when i drop it off. Lol
    Oh and painting shackles without taking off the zinc coating..whatever it has...LOL..comes off so easy..
  12. Sep 17, 2012 at 1:41 PM
    #332
    Tommys2
    Tommys2 Well-Known Member
    Tom
    Westminster, Colorado
    2009 XS SR5 TRD OR V6
    color match silver shell, OEM side steps horn relocate lighted 4wd switch Bud Built full skids testosterone overflow collector
    I just drilled the bumper to match the flip up brackets. Actually, a bit smaller diameter. Then I used a couple of the lower skid blate self tapping screws and threaded a new hole that way. Just got to make sure you drill the new hole smaller than the self tapping screw or it won't have any metal to tap. squirat a little wd 40 when you are drilling and again when you do the tap screw and it will work fine if you take your time and press hard. when i did the layout for the screw holes I gave it about the same distance from top to bottom for the bracket.
    I had extra self tapping screws from the skid plate as, like most of us, we have beefed up the underside protection. The metal is not too hard and even a slow speed drill cuts OK.
  13. Sep 17, 2012 at 3:22 PM
    #333
    Me Likey TRD
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    A lot of guys probably know about this - but try putting a couple of rubber washers in there when you mount them - no rattle! :D
    Look for ballcock shank washers in your plumbing supply:
  14. Sep 17, 2012 at 4:07 PM
    #334
    ironman44bear
    ironman44bear [OP] "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    Lmao...yep the ol ballcock washer...:D you don't want them anouncing that over the loud speaker....hahaha
  15. Sep 17, 2012 at 4:56 PM
    #335
    Me Likey TRD
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Yes! :) Both my wife and teenage daughter snickered when mentioned what I was looking for at the hardware store.
  16. Sep 17, 2012 at 5:28 PM
    #336
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Wait..what is this used for? LOL
    Your horrible :rofl:
  17. Sep 17, 2012 at 5:30 PM
    #337
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    heehee he said plumbing
  18. Sep 17, 2012 at 6:32 PM
    #338
    Me Likey TRD
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    :rofl::rofl::rofl:
  19. Sep 17, 2012 at 6:56 PM
    #339
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    lmao, I've been meaning to go get these. Still thought you were joking with me.
  20. Sep 19, 2012 at 9:14 PM
    #340
    Strautins
    Strautins Well-Known Member
    Nick
    SL,UT
    2019 TRD OR; 2011 TRD OffRoad TX Pro
    2019- 265/70R17 on methods, GFC to be installed: Yukon 5.29, ARB oba, snorkel. (Lift tires armor TBD) 2011- Retired:OME lift, Light Racing UCA, Demello Front, Demello sliders, Brute force rear, TX pro wheels, 285/75s, snorkel, M8000, ARB OBA, Century shell, Relentless skids, Cobra 75
    Final payment sent!! Excited!!!!!!
Thread Status:
