BruteForceFab Rear Bumper GB #2
Discussion in 'Group Buys' started by ironman44bear, Jul 29, 2012.
Thread Status:
Not open for further replies.
  1. Jul 31, 2012 at 10:06 AM
    #41
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Bill, I have been thinking. I remembered someone had mentioned putting bigger shackles on your bumper. And i found it. He asked you to put 1 1/8in holes to accommodation his larger shackles. Seems he has 13,000lbs shackes...the ones I have are 18,700lb..lol overkill much..but what ya think? sell them and get smaller ones that will fit normally...or get the holes drilled larger and use the ones I currently have? I emailed ARB to be 100% on the 1 1/8in diameter.(Just got email..they are just under 1 1/8in max)
  2. Jul 31, 2012 at 1:17 PM
    #42
    ironman44bear
    ironman44bear [OP] "Toyota Mafia" MORE BALLS THAN BRAINS
    Billy
    Clovis,CA
    05 DC Taco 4x4
    Read post below..lol...I will look for a pic that shows it more clearly
    Yup:D
    Way overkill plus just to cut 2 out with the bigger holes would cost around 60.00..I have the other ones cut out 100 at a time cause they are used on the front as well. The recovery points have a .900 hole in them for a 3/4 shackle w/ a 7/8 pin which are rated at 4.5 tons (9000lbs) with a saftey factor of 3 to 1 this means they would break at 27,000 lbs. There is no way possible to put that much load on them to the point of failure. I can get the shackles for you , they run 25.00 for the pair. I don't think you'll find a cheaper price on them..if you do let me know so I can buy them there....LOL:D
  3. Jul 31, 2012 at 1:28 PM
    #43
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Cool beans! Add them to my tab :) I'll hush now :D
  4. Jul 31, 2012 at 1:51 PM
    #44
    $SFTACOMA$
    $SFTACOMA$ Member
    Roberto
    San Francisco
    TRD SPORT 4X4
    Wet Okole seat covers. Snug Top tonneau cover.
    Deposit sent for a std rear w/ reverse light buckets
    Thanks.
  5. Jul 31, 2012 at 1:56 PM
    #45
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    FINALLY!! :D
  6. Jul 31, 2012 at 2:27 PM
    #46
    canoeski
    canoeski Well-Known Member
    Bill
    Southcentral Wisc
    2012 Tacoma AccessCab
    Debadged. ARE Topper. Tailgate mods, including locking handle. BAMF LCA skids.
    Great!
    I may order a pair of shackles too (let me check my recovery tool box, not seen in a long time, for the size I have). Who makes your shackles?
    OK, one last question(s):
    I presume you can still access the spare tire crank down mechanism in the usual fashion?
    Can the Highlift jack cutouts be temporarily plugged until you need them? I don't even own a Highlift (yet).:rolleyes:
    I am stoked for a real bumper!:)
  7. Jul 31, 2012 at 3:17 PM
    #47
    CaliAsh
    CaliAsh Well-Known Member
    Jesse
    Left Coast
    2012 Taco TRD Sport DCLB
    Trail Limo
    Wait? Shackles can be included for $25?? I'm guessing this are not colored ones? :)
  8. Jul 31, 2012 at 5:35 PM
    #48
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    btw: to anyone thats worried about towning with billys bumper hitch set up dont be!!!!!!!!! your truck will break in half before the bummper even breaks a sweat......i had about 8000lbs of concrete forms on 16ft 5ton equipment trailer, which completely flatened my expo packs..and the bumper was 110% perfectly fine...
  9. Jul 31, 2012 at 6:14 PM
    #49
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    That was me. I had the larger holes cut because I wanted to run the shackles I use for work every day, no other reason.
    The 3/4" shackle is definitely overkill, so don't worry about the capacity. The Crosby shackles I use have a factor of safety of 6!
    Billy, I'm planning that HC rear, but it's going to be a little while before I place the order. It looks like you're racking up the orders, keep up the good work! :)
  10. Jul 31, 2012 at 7:54 PM
    #50
    ironman44bear
    Billy
    Clovis,CA
    05 DC Taco 4x4
    You got it man;)
    Got it and thank you:)
    :D
    Wait? Shackles can be included for $25?? I'm guessing this are not colored ones? :)[/QUOTE]Yes and no not colored..just zink plated
    LMAO:D I've hauled more heavy shit on trailers than my poor truck is rated for.
    You got it man..;)
  11. Aug 1, 2012 at 1:40 AM
    #51
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Like the front bumper GB, just posting my order awaiting 8/4 paycheck :cool: oh and FREE BUMP!!
    Standard Rear Bumper w/o reverse light cutouts and a pair of Shackles!
  12. Aug 1, 2012 at 5:21 AM
    #52
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Agree about the strength of the bumper. I towed a loaded double axle trailer 600 miles last week with a drop hitch. I've towed a couple of cars a few miles with the shackles and a tow strap. I've dragged and bumped the bumper around offroad trails. I've jacked from the hi-lift notches. All no problemo. A little more rattle can and it looks just like new again.
  13. Aug 1, 2012 at 10:00 AM
    #53
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Just ordered standard rear with tire carrier, thanx billy
  14. Aug 1, 2012 at 1:55 PM
    #54
    ironman44bear
    Billy
    Clovis,CA
    05 DC Taco 4x4
    You got it man..;)
    Hell yeah...:D
    You got it man;) and thanks again
  15. Aug 1, 2012 at 3:03 PM
    #55
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I took this pic when i first got the bumper. The bumper is sitting upright like it would be on your truck and u can clearly see the two holes for the chains . . .
    figure that might help u out a little bit ;)
  16. Aug 1, 2012 at 3:39 PM
    #56
    canoeski
    Bill
    Southcentral Wisc
    Thanks for the pics ,man!:)
    I couldn't clearly see that from the other pic, but figured there must be a way.
    Can you answer my other question regarding accessing the spare tire crank? I would think the bumper sits low enough to get to it in the usual cranky manor.;)
  17. Aug 1, 2012 at 3:53 PM
    #57
    ironman44bear
    Billy
    Clovis,CA
    05 DC Taco 4x4
    The crank will work as the bumper sits at the same height ( on the top side) as the factory bumper:)
  18. Aug 1, 2012 at 4:21 PM
    #58
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    yes the spare tire crank is still very accessible
  19. Aug 1, 2012 at 6:58 PM
    #59
    cdk
    cdk Well-Known Member
    san angelo,tx
    2012 PreRunner TSS
    BruteForceFab rear bumper, Ranch Hand front grille guard w/ led lights, leds here and there, seat covers, dash cover, console and handle covers, weathertechs, upgraded audio system, bed mat
    deposit sent for standard bumper w/ reverse buckets
    what is the estimated time of completion?
  20. Aug 1, 2012 at 8:31 PM
    #60
    ortlie09
    ortlie09 Well-Known Member
    Eric
    Sacramento
    11 Reg Cab 4x4
    Debadged, took off front mud flaps, prevent tailgate theft mod, Magnaflow 18" muffler, Bilstein 5100s front and rear w/ front @1.75, wet okoles, plasi dipped front emblem, weathertechs, scangauge, toolbox, Bed pocket lights, BHLM, T1 eyelids, BAMF sliders, Bruteforce Fab rear bumper
    Bump :D
    Billy would you mind posting up a price if you're available to get the license plate flip up brackets? That 15 bucks is a great price but I wanna see what a group rate could be
Thread Status:
