BS transmission filter change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Squatchytaco, Jun 14, 2025.
  1. Jun 14, 2025 at 5:16 PM
    Squatchytaco
    Squatchytaco [OP] Member
    Wade
    2019 TRD off road
    Has anyone had an issue doing the stupid wire thing in the connector port ? I think this is the dumbest thing ever. I couldn't get it to work.
  2. Jun 14, 2025 at 6:04 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    What?
    Chew and auskip07 like this.
  3. Jun 14, 2025 at 6:19 PM
    Squatchytaco
    Wade
    2019 TRD off road
    Google 2109 tacoma transmission filter change.
  4. Jun 14, 2025 at 6:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Much easier to use a scan tool or scagauge to read transmission temp (needs to be 95-113F with the engine running to check) but the jumper method works too.
    Squatchytaco[OP] likes this.
  5. Jun 14, 2025 at 6:45 PM
    Squatchytaco
    Wade
    2019 TRD off road
    Thank you for this
  6. Jun 14, 2025 at 8:01 PM
    545 Well-Known Member
    2015 Access Cab
    Just use an IR temp gun on the pan. It’s close enough
    b_r_o and Chuy like this.
  7. Jun 14, 2025 at 8:27 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Concur on the IR reading. I’ve compared it to my UltraGuage readout and IR reading averages 1-3 degrees off, on hotter side. Probably cause IR is more immediate.
  8. Jun 14, 2025 at 10:07 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I did my tranny filter around 80k along with a new gasket. Easy to do. The jumper wire process to check the temp level is pretty easy with the instructions.
  9. Jun 14, 2025 at 10:32 PM
    MGMDesertTaco
    I think I used a paper clip to jump the wire terminals. A scan gauge with a temp readout would be much easier. I need to do mine again soon along with the filter. Currently at 72k.
    Chew likes this.
  10. Jun 15, 2025 at 6:47 AM
    Squatchytaco
    Wade
    2019 TRD off road
