BSM and aftermarket rear bumpers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Elphane, Sep 17, 2016.
  1. May 15, 2017 at 11:51 AM
    #61
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    I don't think I have any pictures, but the camera is hardly blocked at all. You can see a small amount of the spare tire up in the top right corner of the screen, otherwise the view is normal.
  2. May 15, 2017 at 2:02 PM
    #62
    tweakit88
    tweakit88 COPELANDING_ADVENTURES
    Leroy IL
    3rd gen inferno TRD OR.
    Only the best.
    Thank you for the reply. Im just trying to get all my ducks in a row so i can get my build fully underway in a couple of months. One more question and ill leave you alone till i order lol, whats the distance from the back window to the tire on a short bed( have to make sure my rtt will fit)
  3. May 16, 2017 at 9:53 AM
    #63
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I have no idea what that measurement would be. All I can say is that the top of the tire when attached to the swing out does not extend towards the cab past the rear edge of the tailgate. Hopefully that makes sense.
    So basically if your tent does not extend past the outside of your tailgate at all then you should be fine.
  4. May 16, 2017 at 10:56 AM
    #64
    tweakit88
    Leroy IL
    Only the best.
    Okay thank you for the info
  5. Jul 29, 2017 at 10:07 AM
    #65
    Hunter75
    Hunter75 Member
    2016 Tacoma TRD Off-Road 4x4
    So if you use the C4 Fab BSM compatible bumper, I assume you have to remove your factory hitch. If so, what is the C4 Fab bumper hitch rated at? Any chance you could mount this bumper over the top of the factory hitch?
  6. Jul 29, 2017 at 5:34 PM
    #66
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Can't mount over it and it's not rated
  7. Nov 4, 2017 at 9:53 AM
    #67
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    are there any other options? I dont like the plate being on a angle like that nor that the hitch is behind it. Any other options that work with the tech package?
    rlx02 likes this.
  8. Nov 4, 2017 at 12:18 PM
    #68
    JoeCOVA
    Joe
    Colorado Springs
    I think RCI has an option but the BSM hangs below the bumper which probably won’t work. Most aftermarket bumpers have an integrated hitch. C4 is the only one. The angled plate is growing on me for the added clearance.
  9. Nov 4, 2017 at 12:20 PM
    #69
    Canadianguy91
    Sean
    2016 Limited
    Why is this? Like why cover the hitch to begin with?
  10. Nov 4, 2017 at 12:21 PM
    #70
    JoeCOVA
    Joe
    Colorado Springs
    Because 99% of the people want better departure angle. So the factory hitch is completely removed.
  11. Nov 4, 2017 at 12:34 PM
    #71
    Canadianguy91
    Sean
    2016 Limited
    Not worth it imo
  12. Nov 4, 2017 at 12:48 PM
    #72
    Tac0maSteve
    Tac0maSteve Well-Known Member
    East Bay, CA
    '15 TRD Off Road Icon Ext. Travel
    DCSB... No mods here
    You're not losing capability though, you still have a solid hitch that is durable and reliable. It is just moved up into the bumper.
  13. Nov 4, 2017 at 8:21 PM
    #73
    JoeCOVA
    Joe
    Colorado Springs
    To each their own.
    Just my thoughts, the vast majority of tacoma owners don’t tow. So why R&D
    erok81 likes this.
  14. Nov 4, 2017 at 8:41 PM
    #74
    erok81
    erok81 Well-Known Member
    Imposter
    Further those that do tow how often do they tow? I don’t think flipping a plate up is a big deal even if you do tow. Plus it looks way better hidden.
    I used to hate that angled plate. But the more and more I look at it the more I like it.
    JoeCOVA[QUOTED] likes this.
  15. Nov 5, 2017 at 5:10 PM
    #75
    Canadianguy91
    Sean
    2016 Limited
    Aren't you loosing capacity because now it's off some bolts instead of right off the frame?
    Really? I think it looks so unnatural
  16. Nov 5, 2017 at 5:57 PM
    #76
    Tac0maSteve
    East Bay, CA
    Stock tow hitch is off of bolts as well. If the new hitch is welded into the bumper itself it is using the stock hitch bolts + some additional ones. You'd lose some towing weight capacity due to the weight of the steel bumper itself, but not that much.
  17. Jan 29, 2018 at 3:01 PM
    #77
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Correct, the bumper is mounted the exact same way that the factory hitch is mounted to the frame so there shouldn't be any lost capacity in the mounting system. The only way capacity would be lost is if the structure of the bumper itself is not as strong as the factory hitch, or the fact that the hitch inside the steel bumper is up so much higher than the original hitch will cause more leverage on the bumper when towing with a drop hitch. The added leverage from a drop hitch could effectively lower the towing capacity of the bumper.
    We often get asked what the capacity of our bumper is and we say its close to the original capacity, but we have no way of officially testing that, so the bumper hitch does not have a rating.
  18. Jan 29, 2018 at 3:18 PM
    #78
    phsycle
    phsycle Well-Known Member
    CA
    Very cool. But what to do about the trailer 4/7-pin harness? I didn't see an option to have them mounted somewhere on the bumper.
  19. Aug 3, 2018 at 7:31 AM
    #79
    DeeBee
    DeeBee Member
    18 Taco
    This one is brand spankin new..
    I know this is an old thread but I’m shopping for a bumper and I went to C4’s site and it seems the BSM supported bumper is no longer offered with swing arm tire mount only the high clearance. What happened?
  20. Aug 3, 2018 at 8:47 AM
    #80
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    @DeeBee weird. I just had my BSM supported bumper with swing arm delivered on Wednesday. I'm curious why they switched it up.
    DeeBee likes this.
