BSM not working on 2016 Tacoma Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma Bill, Dec 17, 2019.
  1. Dec 17, 2019 at 3:54 PM
    Tacoma Bill
    Tacoma Bill [OP] Member
    2016 Tacoma Sport
    None
    The dealer replaced/fixed the sensor a couple of years ago while the truck was still under warranty. The "non-working" indicator came on 3 days ago and it still does not work. I turn it on everytime I get in the truck but it still gives me the alert.
    Does anyone have any troubleshooting ideas or can give me some advice?
  2. Dec 17, 2019 at 4:00 PM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Mine acted up once and just wiping it off with a wet paper towel fixed it.
  3. Dec 17, 2019 at 4:04 PM
    Tacoma Bill
    2016 Tacoma Sport
    None
    I read the same thing on line but its been raining here for 2 days and still no change. Do you know where the module is so that I can make sure it did not short out?
  4. Dec 17, 2019 at 4:08 PM
    CTF
    2017 TRD OR
    That’s when mine acted up, while i was driving home in the rain. I just wiped all 4 of them off and it hasn’t acted up again. Unfortunately I don’t know where any modules are located.
  5. Dec 17, 2019 at 4:12 PM
    Tacoma Bill
    2016 Tacoma Sport
    None
    Thank you for the information. I will try cleaning them. I issue has never occurred due to rain in the past but there's always a first time for everything.
  6. Dec 17, 2019 at 4:25 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Mine stopped working at one point, it gave me "BSM not available" on the dash. Took it in, and there was a code thrown for sensors off master axis. They recalibrated them and been good to go since.
  7. Dec 17, 2019 at 4:27 PM
    Putzcommander
    Putzcommander Well-Known Member
    2016 Trd Sport Doublecab 5ft Box
    Softopper
    Not what you want to hear but i lost a sensor last year. By the end they had replaced bsm sensors 2x, harness and both mirrors. Seems the rear electrical shorted when the licenseplate light seal failed. One sensor blew, burned out mirror whcih when replaced triggered the sensor again. Finally had to replace sensor and mirror at same time. Shit show.
  8. Dec 17, 2019 at 4:30 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    The BSM sensors are behind your bumper...… 1 at each end. They are directly behind and subject to tire spray....
    Mine was out from the factory. Turned out to be the wire harness to the left sensor. I'm not sure you can wipe they off. but a good spray in there to remove ice and mud will help.
  9. Dec 17, 2019 at 6:39 PM
    Tacoma Bill
    2016 Tacoma Sport
    None
    Thanks everyone!
  10. Dec 17, 2019 at 7:06 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Do you try just turning on when you get in the truck, and then turn it off when it faults? I had weather do that to mine once. I was always pissed when it beeped so turned it off...this was a couple days, then I read somewhere it takes a few miles to recalibrate itself so I left it...sure enough bout 5 miles letting it go, it reset. Haven't a problem since
  11. Dec 17, 2019 at 7:07 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Mine went out a couple weeks ago during a snow storm. Said something to the effect, "BSM not available". Ran with it turned off for about a week until it warmed up enough to take it to the car wash where I gave it a good dousing with the sprayer. Still didn't work. Then I read somewhere here on TW to just leave it on for 10 minutes after cleaning. Sure enough, after about 5 minutes it began working again with no issues since.
    TeecoTaco likes this.
  12. Oct 22, 2020 at 3:38 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Anytime know where the sensors are located? I don't see anything on the bumper or mirror that is obvious and the only thing I can find in the owner manual is how to turn it on, etc. Nothing about the hardware/sensors.
  13. Oct 23, 2020 at 12:20 PM
    over60
    Muskoka, Ontario
    The sonar sensors are in the corner of rear bumper,,,.... It senses through the plastic bumper tip.
    Look harder... there are lots of threads above the BSM system....Most problems are with left rear sensor and debris...
    Good luck:thumbsup:
