BSM Offroad Bumper
Discussion in '3rd Gen. Tacomas (2016+)' started by unavailableTaco, Sep 19, 2018.
  1. Sep 19, 2018 at 1:14 PM
    unavailableTaco
    unavailableTaco [OP] Well-Known Member
    Roy
    Grapevine Texas
    2018 Tacoma TRD PRO
    Full tank of gas
  2. Sep 19, 2018 at 1:36 PM
    Doozy4212
    Doozy4212 Well-Known Member
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    Yes, it is the only one. Ditch the BSM, be a better driver, BUY @Mobtown Offroad
    /thread
  3. Sep 19, 2018 at 1:38 PM
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    What happens when you ditch the BSM? Do you get a permanent warning light on your dash?
  4. Sep 19, 2018 at 1:40 PM
    Doozy4212
    Drew
    Littleton, CO
    nope, i ditched BSM and Sonar when I put my bumper on. Kept the harness plugged into the truck as the license plate lights are intertwined in the harness and just turned the buttons off in the cab. no lights or warnings in 6000 miles. All i did was put plastic baggies over the 6 unconnected plugs to protect them in case i ever wanted to go back to stock....
    LostHusker, Blais03 and gman36 like this.
  5. Sep 19, 2018 at 1:40 PM
    steele-taco
    steele-taco Well-Known Member
    james
    NE PA
    17 TRD OR DCSB white
  6. Sep 19, 2018 at 1:41 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    Why do that? @C4 Fabrication makes good stuff and is a vendor on here
  7. Sep 19, 2018 at 1:43 PM
    Doozy4212
    Drew
    Littleton, CO
    they make great stuff but personally that bumper is not worth it. It hangs lower than stock in the corners thus decreasing departure angles and does not blend with the lines of the truck
    however C4s HC bumper is beautiful!
  8. Sep 19, 2018 at 1:45 PM
    Doozy4212
    Drew
    Littleton, CO
    don't buy this powdercoated, you're going to end up touching up the paint on the corners if you ever leave asphalt
  9. Sep 19, 2018 at 1:47 PM
    Mobtown Offroad
    Mobtown Offroad Boss Vendor
    Joe
    Greensboro, MD
    2002 SR5 4Runner
  10. Sep 19, 2018 at 1:48 PM
    Doozy4212
    Drew
    Littleton, CO
    :headbang:
  11. Sep 19, 2018 at 1:48 PM
    mach1man001
    Rob
    Blackstone, MA
    I'm not a 3rd gen guy so I don't have BSM but does the bumper going lower than the body lines have anything to do with the BSM?
    Mobtown Offroad likes this.
  12. Sep 19, 2018 at 1:49 PM
    mach1man001
    Rob
    Blackstone, MA
    :wave: Hi Joe!
    Mobtown Offroad and Doozy4212 like this.
  13. Sep 19, 2018 at 1:49 PM
    Doozy4212
    Drew
    Littleton, CO
    it doesn't, but it doesn't look good either and defeats the purpose of an OFF ROAD bumper
  14. Sep 19, 2018 at 1:52 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    35" Trepadors w/ OMF Beadlocks, Kings, OBA, 5.29s etc
    I might have to hit you up in person to check it out.
    What drawer system is that?
  15. Sep 19, 2018 at 1:58 PM
    Doozy4212
    Drew
    Littleton, CO
    DOOZY custom, but I'll sell you this one or build you a custom set :thumbsup:
    Durango95 and doorsidedown like this.
  16. Sep 19, 2018 at 2:18 PM
    JoeCOVA
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    nice! Found your thread. I may hit you up on that. Pretty slick.
    Doozy4212 likes this.
  17. Sep 19, 2018 at 2:29 PM
    Doozy4212
    Drew
    Littleton, CO
    please do!
  18. Sep 19, 2018 at 2:36 PM
    phsycle
    phsycle Well-Known Member
    CA
    There are a few threads on that bumper. Consensus seems to be that it's finicky. Works part of the time and is not 100% reliable. I'd rather just get a proper high-clearance bumper and forget BSM. It's a highly-sensitive system. Toyota tech told me even it gets a tiny bit out of alignment, it's $$$ to calibrate it. Not worth it.
  19. Sep 19, 2018 at 3:19 PM
    Mobtown Offroad
    Joe
    Greensboro, MD
    2002 SR5 4Runner
    Hey Rob!
    mach1man001 likes this.
  20. Sep 19, 2018 at 3:25 PM
    monkeyevil
    monkeyevil Some dude
    Daryl
    Kalamazoo, MI
    2016 TRD Sport
    Be sure to waterproof the BSM plugs on the harness once you pull the BSM sensors. One of the 12v lines in those plugs is tied to an ACC fuse that also powers the HVAC. It was a cold ride back home before I could diagnose why that fuse kept blowing last winter :p
    Mobtown Offroad and steele-taco like this.
