BT and iPhone
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Mar 27, 2012.
  1. Mar 27, 2012 at 6:09 PM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    I have a 2012 with a standard radio, not enTune or JBL. I paired my iPhone and the "Internal Audio" also. I was trying to play Pandora through the radio via BT but it didn't work. What am i doing wrong?
    Thanks
  2. Mar 27, 2012 at 7:24 PM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    are you selecting your truck as the audio output on your iPhone? its the little square with the arrow inside it pointing up, its usually on the right of the volume line on the phone when palying iPod/pandora etc
    once paired the phone should automatically select your truck for it but maybe with audio from pandora and such it might want you to select it..just a guess, mine does it auto but mine is JBL/entune
  3. Mar 27, 2012 at 8:04 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    May not work with an app. Usually requires the use of the "iPod" on your iPhone to use the Bluetooth audio.
  4. Mar 27, 2012 at 8:11 PM
    JTyfz450
    JTyfz450 Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    You have to pair it as an audio player as well. The phone and audio player are two separate set ups.
  5. Mar 27, 2012 at 8:27 PM
    pdrunk
    pdrunk Well-Known Member
    2012 DCSB 2.7L
    This. Once paired, the truck speakers will play ANY sound from your iphone, including games, movies, even the slide sound effect.
    Mine is the plain system, no entune or jbl either.
  6. Mar 27, 2012 at 10:42 PM
    OverRated
    OverRated Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    If you are trying to link your phone for Internet use on your stereo it won't work unless you are jail broken.
  7. Mar 28, 2012 at 6:45 AM
    Squirrellydw
    I tried this but couldn't get it to pair for some reason. Does it matter what one I pair first, phone or phone as audio player? Guess I will just keep playing with it
  8. Mar 28, 2012 at 7:22 AM
    1GR
    Scott
    BC, Canada
    If you pair phone first, it should ask you if you want to pair the audio player as well.
  9. Mar 28, 2012 at 7:53 AM
    JTyfz450
    Jeryck
    SoCal
    No it shouldn't matter. It took me a while to get my iPhone paired as a audio player. It kept saying to make sure the Bluetooth device is close to the truck (or something like that). From what I remember when it kept saying that I turned off my Bluetooth on my iPhone and turned it back on right when the truck's Bluetooth was searching for my iPhone. After that it worked right away.
    Hope that helps.
  10. Mar 28, 2012 at 9:54 AM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    bluetooth will ( and does on my tacoma) play any audio source from your phone. in fact, my entune display even shows the album artwork from my pandora or spottily while using bluetooth.
    if his pandora is not platting my bet is on selecting the truck as the output choice of speaker form his airplay button on pandora volume area. it should select truck automatically but if its not then that might be the case
  11. Mar 28, 2012 at 12:25 PM
    Squirrellydw
    It got it working with Pandora. My one sports app won't work though, I don't think it supports airplay. The app is for the Pittsburgh Penguins, I wanted to be able to listen to the games while I was driving but can't get this one to work.
  12. Mar 28, 2012 at 1:33 PM
    differential
    differential Member
    Dallas
    Black Pre Runner
    I have this same setup, mine works great, plays all sounds, radio apps, etc...but I have not been able to get my address book to sync up. I've read somewhere that the iphone address book will not sync with the standard system through bluetooth.
    Does anyone know if there are any updates to this problem, or a workaround?
  13. Mar 28, 2012 at 2:48 PM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    address book? as in your phone contacts? mine syncs no problem. You might need to go into your "settings" => "general" => "bluetooth" => select your truck, usually "car multimedia" and make sure all your stuff is selected to sync...in this case "sync contacts" tuned on and if you have groups in your phone book, make sure you check which you want synced or all.
  14. Mar 28, 2012 at 2:50 PM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    as far as your sport app, if it has a volume that the iPhone dictates, it should allow you to select bluetooth as your audio output from it....from that same airplay thingy next to volume bar.
    odd thing is that all these are usually default settings on the phone so that they just work automatically.
  15. Mar 28, 2012 at 3:25 PM
    JTyfz450
    Jeryck
    SoCal
    Are you basing it on an iPhone or a different cell phone?
  16. Mar 28, 2012 at 5:20 PM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    iphone
    but most phones do have a bluetooth preferences as to what you want synced over bluetooth anyway. if not an iPhone, which ever phone you have will have a set of rules for what you want synced. most default to everything but you never know why it might've been chaged at some point if its not working
  17. Mar 28, 2012 at 6:00 PM
    JTyfz450
    Jeryck
    SoCal
    Did all that and there is no option to sync my contacts with the regular non-entune system. Oh well...
  18. Mar 30, 2012 at 5:13 PM
    drsus
    Los Angeles, CA
    4Runner TRDpro
    stock
    that sort of blows...... its not some crazy feature, wonder why Toyota would leave that out? even my shitty $50 motorola bluetooth speaker used to voice out callers from my phone book
  19. Mar 30, 2012 at 5:35 PM
    Greenhatter
    Greenhatter Well-Known Member
    Washington
    Silver 2008 TRD Sport
    TRD Supercharger, Toyo Open Country M/T 285/75/16, 16" TRD Ivan Stewart Wheels, Clearbra
  20. Mar 31, 2012 at 6:43 AM
    Squirrellydw
    Use SIRI, thats what I do.
