Bub Built Trac Bar installed .... no more axle wrap
Discussion in 'Suspension' started by My68ur8trd, Aug 4, 2012.
  1. Aug 4, 2012 at 4:41 PM
    My68ur8trd
    My68ur8trd [OP] Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I got around to installing my trac bar today.
    With the flexy alcans and the S/C I was always battling axle wrap issues and some slight vibes.
    The one piece drive shaft took care of the take off shake, but I always had a driveline vibe at WOT when the pinion would turn up. ..
    not anymore.
    This is a nice little bolt on design and totally eliminated my issues
    The beefy brackets bolts to the diff once you swap out 5 of the studs for the supplied longer ones
    the front shackle mount bolts to the cross member directly next to the carrier bearing. I did have to trim the CB mount a bit to ensure enough clearance for the shackle (1/4" or so).
    The bar is very stout with 1.20 wall DOM. The shackle mount allows full suspension travel without binding ( including articulation).
    It hugs the driveshaft pretty well too. It would actually protect is from damage as well. ( it hangs about 1/4" below the DS.,
    Its a pretty straight forward install and I would recommend it for anyone who has soft rear springs and some added power. The also have a weld on version that you can weld mounts to the rear axle housing if you wanted to do it that way,
    Justin
  2. Aug 4, 2012 at 4:52 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    bout time :p
  3. Aug 4, 2012 at 4:54 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    maybe a new record. I have been moving it around the garage for the past 4 months lol
    Justin
  4. Aug 4, 2012 at 4:56 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    understandable. im still slowly gettin the crawl box finished up. Nick did a great job on the shift boots he made for me. i just have a crossmember that needs to get fabbed up
  5. Aug 4, 2012 at 5:18 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    Nick does good work. I need to go see him about a headliner for my car...
  6. Aug 4, 2012 at 5:35 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i had one on the MonkeyCrawler and it worked great until i was hung up on a rock..tore the bracket from the housing ripping out a few studs along with it. i also twisted a rear axle and busted an output shaft from the tcase..all pretty much at the same time :cookiemonster:
  7. Aug 4, 2012 at 5:45 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    yeah, i also got the console lid done and he gave me a great price. kinda want to get my arm rests done now
  8. Aug 4, 2012 at 9:28 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Not gonna lie, I laugh everytime I see you post the name "MokeyCrawler". I get a big smile and giggle to myself. Hehe MonkeyCrawler.
    :eek:
  9. Aug 4, 2012 at 9:38 PM
    jandrews
    '09 FourDubDee TRD OR
    Looks good!
    Keep an eye on it...I stayed away from the Budbuilt for my traction bar because I had worries about tweaking the studs, loosening the nuts, and possibly causing differential leaks/alignment problems.
    Re-torque 'em sometime soon and let us know if anything crops up.
  10. Aug 5, 2012 at 4:45 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    This is the third budbuilt Bar I have had ( one on my 99, one on the X, and this one)
    I had a diff leak on the X, but I did not let the diff drain for very long when swapping the studs.
    I learned a few lessons
    I let the diff drain over night, and I clean the threads with brake clean before I install. I use liberal loctite and i put a bead of high temp black RTV around the stud before I put in the spacers, then let that dry for the day before I refilled it.
    I think I will be ok on this one
    Factory spec is 18 ft lb for the nuts.
    When it comes time that I really beat on this thing. I will probably make my own weld on mounts and just built a new cross member for the front mount ( I dont use the stock one to mount anything to other than this bar).
    but thats further down the road. This should do the trick for now
    Justin
