Bucket Seat/Bench Seat Swap, 1st gen.
Discussion in '1st Gen. Tacomas (1995-2004)' started by WThomas1250, Aug 26, 2012.
  1. Aug 26, 2012 at 5:20 AM
    WThomas1250
    WThomas1250 [OP] Well-Known Member
    I have a '98 extended cab with the split bench seats, but I really want a center console.
    I found a junkyard that can sell me bucket seats & a center console for my truck.Has anyone ever done this?
    I've heard that the seats just bolt right in, but what about the console?
  2. Aug 26, 2012 at 5:28 AM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    I did the swap on a 99 years ago the seats bolt right in i had to drill 2 holes in the floor for the console. I did not get any hardware so it might be different if you get the bolts.
  3. Aug 26, 2012 at 5:30 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    My console is part of my (drivers side) seat, it slides along with my seat and all, this is in my 2004 though. And I'm guessing that they made all the bodies with the mounting holes/studs for both type seats, would make sense to anyways...
  4. Aug 26, 2012 at 5:41 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I did that swap on a 97. I used seats from a 2004 and they bolted right in. The center console also bolts right in if I remember. I had to get a bracket from the dealer, and I had to lift the carpet between the bucket seats to find the holes, but they were there. The only problem I ran into was the seatbelt recievers did not match. I ended up swapping them around, putting the ones from the 97 seats onto the 04 seats. Came out perfect. Funny thing, the truck was impounded for the rusty frame issue less than a year after I did the swap.:(
    I just reread your original post. Make sure you take the bracket that is under the console when you remove the console at the junkyard, you should be good to go.
    obrandt and Hamer95USA like this.
  5. Aug 26, 2012 at 6:20 AM
    WThomas1250
    Thanks man. I have one more question:
    When I look at pics, there seems to be 2 parts to the center console. My truck already has a small one (where the shifters and cupholders are)
    Do I leave that one in there, or do I have to get a different one?
  6. Aug 26, 2012 at 6:37 AM
    oldtacomaguy
    Dave
    SE Conn.
    If I remember right, you need to unscrew the parts around the shifter and replace them with the parts from the junkyard. My truck was a 97, the cupholders were attached to the dash above the radio and you pulled them out to use them, so I ended up with 2 sets of cupholders. I don't have any pictures so it's kind of hard to remember exactly how it was done. I'd take all the parts I could from the junkyard just to be on the safe side.
  7. Aug 26, 2012 at 8:01 AM
    jbrenn
    allen texas
    10 sr5
    i left the front part but i had an auto. i would buy both part just in case.
  8. Aug 28, 2012 at 2:11 PM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    I'm looking to do the opposite--trade buckets for the 60/40 split bench. Where are you and what color interior do you have? Perhaps we could just trade....
  9. Aug 28, 2012 at 3:07 PM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Granted, mine is a 1995, but the bucket set is out of a 1999. Mine is also a 5 speed, but I would GUESS that it does not really matter.
    As stated above, bolt in (assume 1st gen set). Centre console needs the factory bracket under the rear. The bracket bolts to the bottom of the console and then bolts to holes that were already in the floor with a sticker over them. You just need to cut the carpet for the bracket to come through. My truck had two sets of holes so be sure to double check (if yours is the same) which set align with the console bracket.
    On the front of the console I just needed to remove the two rear screws on the front console, slip the rear console in place and align. The rear console has two front pieces that slip over the edge of the front console and have screw holes in them. I then just put the screws back in to secure the two pieces together.
    Seats bolted right in, no problem with alignment.
  10. Aug 28, 2012 at 5:32 PM
    WThomas1250
    I have a gray (I think it's also called blue) interior. I live in VA
  11. Aug 28, 2012 at 5:34 PM
    WThomas1250
    Thanks!!
  12. Apr 3, 2013 at 11:47 PM
    jce002
    jce002 New Member
    James
    Houston, Tx
    I'm looking to trade if you're still interested, I have a 97 with 60/40 seat
  13. Feb 20, 2014 at 10:01 AM
    WThomas1250
    Bump! After 2 years of on-and-off looking, I finally found a driver's side seat today to go with the console that I've had for over a year! Hopefully doing the swap today
  14. Mar 16, 2014 at 11:59 PM
    ROBDAVIS1
    ROBDAVIS1 Super Member
    Rob
    SAnta Cruz, CA
    2003 taco
    Before......[​IMG]
    After.....
    No welding or rail swap. 3 holes line up fine. Just bend outside front rail mount and drill a hole for rear outside.... HUGE IMPROVEMENT!!! Hardest part is finding gray leather seats!!
    Gray Goose 96 likes this.
  15. Mar 17, 2014 at 4:25 AM
    oliver1539
    oliver1539 Well-Known Member
    Kentucky
    2022 Pro/2016 Off Road
    Looks great! I'm looking for the 4runner seats also in gray. Like you were saying, it's almost impossible!! I've seen several but always in tan or the few gray seats I do find are torn and are crap! I have the standard buckets in my 04 and they are worthless....
  16. Mar 17, 2014 at 11:39 PM
    ROBDAVIS1
    Rob
    SAnta Cruz, CA
    2003 taco
    I lucked out and found some on eBay with only 38k on them.... Had them shipped to Cali from South Carolina. Had to buy the whole set and now I'm stuck trying to sell the rear to recover cost. Only other ones I saw in the 6 months i was looking were a whole set as well on Craigslist out here and they were sold immediately for 750. The guy got 3 replies in the first day and got his asking price. Good luck!! They are rare as double-horned narwhals, but they are out there!!!
  17. Mar 18, 2014 at 10:21 AM
    WThomas1250
    Looks awesome! I went with a Tacoma seat but I wish I coulda found some leather ones
  18. Jan 28, 2017 at 10:58 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Any pics of putting bench in a double cab?
  19. Jan 28, 2017 at 11:21 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wanna swap? Gray/blue 60/40 bench here. Nice shape.
  20. Jan 28, 2017 at 11:27 AM
    PROseur
    Pussy
    I have the grey
    What would I need additionally b sides seat to do a bench conversion?
