Bucket seat cons in regular cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tennisfan777, Jul 23, 2016.
  1. Jul 23, 2016 at 12:38 AM
    tennisfan777
    tennisfan777 [OP] Member
    Hey guys like many of you I'm thinking of swapping my bench seats for some bucket seats. I was wondering what the cons were ? Will I not be able to adjust my seat in a certain direction? Will the height be off?
  2. Jul 23, 2016 at 11:12 AM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    The biggest con is losing the middle seat and possibly the side airbags depending on what year RC you have.
    Bowers86 likes this.
  3. Jul 23, 2016 at 12:10 PM
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    ^ what Depoxy said.
    One thing I noticed was the passenger seat no having its full range of for-aft movement ability. And if you want to put it as far back as possible, then reclining is hampered. But to me it's a small price to pay for the individual seats. Would love a remedy to the wiring in order to get the passenger airbags to work.
  4. Jul 23, 2016 at 12:11 PM
    DrFunker
    DrFunker Well-Known Member
  5. Jul 23, 2016 at 2:53 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Basically what he said and you have to grind down the seatbelt buckles or use the old receivers. I just ground mine down. I also wouldn't say I really gained much room, if any other than if someone else is driving my truck that is shorter than me (which is very rare)
  6. Jul 23, 2016 at 3:06 PM
    MG06tacoma
    MG06tacoma Well-Known Member
    PA
    06 4x4 Base
    I did today. Installed buckets from a 2014 to replace the bench on my 06 regular cab and I'm loving it so far. Took about 4 hours to complete.
  7. Jul 23, 2016 at 5:47 PM
    whttaco2whl
    whttaco2whl Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    So did you do anything about the air bags? Some have thought the truck computer would not allow start if air bags were disabled. So I assume yours are disabled correct?
  8. Jul 23, 2016 at 5:58 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    My airbag connectors (on the passenger side) are not connected and I am driving just fine. The seatbelt light and airbag light are illuminated though, which is a little annoying.
  9. Jul 23, 2016 at 5:59 PM
    MG06tacoma
    PA
    06 4x4 Base
    Nope. Not disabled at all. Properly working. Had to remove whole wiring harness form the bench and put it back in the truck. Including the passenger seat sensor. Only ones disabled are the side airbags but that is only because my truck is an 06 and the seats are from a 2014.
  10. Jul 25, 2016 at 10:01 AM
    tennisfan777
    07 RC is what i have, what about the height? can it get to a higher seating position than the benchs?
  11. Jul 27, 2016 at 8:44 PM
    MG06tacoma
    PA
    06 4x4 Base
    The buckets do sit higher than the bench which I really like, the fact that the back rest is adjustable is also a + for me.
  12. Jul 9, 2018 at 4:46 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Will it work in the old buckle if it grinded and now smaller if you want to go back later
  13. Jul 9, 2018 at 5:56 PM
    tacobell007
    Drew
    Western MA
    Yes, I verified that
    pinktaco808[QUOTED] likes this.
  14. Jul 9, 2018 at 5:58 PM
    pinktaco808
    It won't be too loose. Also the buckle plug into the harness from the bench?
  15. Jul 9, 2018 at 5:58 PM
    pinktaco808
    What did you grind it with?
  16. Jul 9, 2018 at 6:00 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Not to hi-jack the thread, but where are people getting their bucket seats? I have a '98 would love to get 1st gen seats that are in good shape.
  17. Jul 9, 2018 at 6:54 PM
    tacobell007
    Drew
    Western MA
    No i spliced the harness so it was all plug and play
    Air die grinder with a sanding disc
  18. Jul 9, 2018 at 8:24 PM
    pinktaco808
    It only 2 wires yeah? Just prepping myself
  19. Jul 9, 2018 at 9:07 PM
    tacobell007
    Drew
    Western MA
    If I remember right, just 2 wires yes. It's been 3 years? Since I did it
