Bucket seats in a regular cab, HELP
Discussion in '4 Cylinder' started by McJosh, Dec 25, 2009.
  1. Feb 6, 2011 at 4:18 PM
    #41
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    According to the safety specs from the Toyota website it does:
    And I recall seeing the little "SRS" tag on the sides of the seatbacks on my '09 reg cab (bench seat).
  2. Feb 6, 2011 at 5:18 PM
    #42
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Seems like if the the sensor wiring for the 09-11 Access cab's buckets would work w/ existing regular cab wiring, you could install them in the 09-11 regular cab.....:thumbsup:
    Motoretro
  3. Feb 6, 2011 at 6:10 PM
    #43
    HomeGrown
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    IIRC, (from working in bodyweld during the Taco install in San Antonio) I think the reg cab that came originally with the bench seat will not have the proper reinforcement/mounting inner brackets (near the tunnel on both sides) for the buckets. In the older trucks they had all the appropriate weld-nuts and reinforcements in place for both bench and buckets. I swapped the bench for 4Runner buckets in my '88 and it was a direct bolt-in swap. I don't think that's the case with 2nd gen Tacos.
  4. Dec 28, 2011 at 6:49 PM
    #44
    jacobblocker
    jacobblocker Well-Known Member
    Jacob
    east tennessee
    billet grill, black out emblems, procomp 7089, hankook dynapro 265/70/17
  5. Jan 15, 2012 at 4:45 PM
    #45
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    there are airbags in the seat. My 2010 had them right where the little tag is. they are designed to blow out through the seam in the fabric. In my sig there is a post on how to disable the side airbag when i installed my buckets.
    When you take the seat out it's obvious where they are.
  6. Jan 15, 2012 at 4:48 PM
    #46
    Yoytoda
    Roland
    completely stock
    yes it is. the bolt holes are right there. 08 and prior reg cabs had an option for buckets and now the 11+ have a bucket option. all the holes/reinforcement are there under the carpet
  7. Feb 28, 2012 at 6:32 AM
    #47
    ArmyTacoGuy
    ArmyTacoGuy Well-Known Member
    Jacob
    Naples, FL
    06 Regular Cab 2wd 2.7L
    black rim mod multi color LED's on floor boards Blacked out tail lights and headlights black emblems and white one in grille Police grade siren and PA system Glass Pack bull horn wired to radio in cab 10'' Kicker Bass House custom made intake hellogen bulbs Roof running lights aftermarket head unit
    So I want to do this in my 06, would anyone suggest just going to the junk yard and getting the bucket seats and center console out of a totaled extended cab...?
  8. Feb 28, 2012 at 9:35 PM
    #48
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That would be the cheapest way to go... especially if you'll be putting covers on the seats.
  9. Feb 29, 2012 at 3:38 AM
    #49
    ArmyTacoGuy
    Jacob
    Naples, FL
    Yes that's the plan I have mosy oak every where would also get the seat covers
  10. Mar 15, 2012 at 4:18 AM
    #50
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    You are correct ,I had custom brackets made to fit the beach seat bolt locations .The stock bench seat had to be tore down for the rails,it had some mold anyways. With said brackets was able to put Celica seats into my 1995 Tacoma .The old seat belts worked with the seats .Now just need a center console.
    Anyone thinking of going from bench seat to buckets should do it. Your ass and back will thank you.
