Bud Built Skid install with an Elite bumper.
Discussion in 'Elite Off-Road' started by JLee, Aug 18, 2011.
  1. Aug 18, 2011 at 8:51 AM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Okay so the questions have been out there if the Bud Built IFS skid fits with the Elite front bumper. And yes it dose "with a little modifications" This is what I did to make it fit.
    On a side note I wouldn't get the powder coated skids because your going to be grinding it off. "And I don't think you should powder coat a skid anyway it's just going to get all messed up and you will have to paint over it anyway but that's just me"
    Tools
    Drill & 5/16th drill bit
    4.5" angle grinder (with 4 to 6 cut off wheels)
    Paint pen (or sharpie)
    Straight edge
    Measuring tool (I used )
    Primer & paint
    Optional Tools
    Welder
    C clamps
    3 beers :D
    You can see here how much the skid hangs over the edge of the bumper. This shot is with the hex bolts in place to align the skid.
    My mounting point is a little tweaked "yes I wheel my truck :p"
    So I took a measurement wile the skid was on the truck and came up with this.
    And broke out the angle grinder (Note) with the 4.5" angle grinder dont just bite into the edge of the plate. Do light passes over the top until you cut all the way through.
    I did it one bolt hole at a time.
    And that's what I trimmed off.
    And even if you take your time your going to eat up grinding disks I went through 3 and half of the fourth. And I took my time and didn't rush it.
    Here is what i cut off mine "But yours will be different trust me"
    Passenger side
    Driver side
    Then mocked it up to see fitment I cut back a little much for my taste but once the hex nuts are started you couldn't get it to go into place. (Note) i would knock off about 1/8" 1/4" from your cut and it will line up better.
    I didn't mined the over cut too much because i didn't plan on leaving it that way. i took the trimmed steel and lined it up wit the holes and stitch welded it to the skid.
    Then tested fitted the skid and there was just a little over hang i had to trim.
    Then I primed and painted the skid.
    Note you will have to drill out the hole on the bumper and buy nuts from Home Depot to bolt it to the bumper.
    I had some 5/16th bolts so I used those.
    Another thing if you have the Elite cut outs like I do you can forget about the middle bolt because you can get to it. You could put it in before the skid and hope it don't spin on you because you can't get to the top. The next time i take off my skid I may tack the bolt to the bumper and put it on but I'm fine with just 2 for now.
  2. Aug 18, 2011 at 8:54 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Looks good Jerry!
  3. Aug 18, 2011 at 8:56 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Great write up, Ill be doing this once my bumper gets here. :thumbsup:
  4. Aug 18, 2011 at 8:57 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    nice write up man....
  5. Aug 18, 2011 at 9:18 AM
    JLee
    Jerry
    Benicia, CA
    Thanks guy I figured Id help everyone out so there was no guessing when installing a Bud Built skid with one of these bumpers.
  6. Aug 18, 2011 at 9:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Nice write-up
  7. Aug 18, 2011 at 11:42 AM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Great write up man very helpful :thumbsup:
  8. Aug 24, 2011 at 12:43 AM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    nice job Jerry, thanks for posting this!! rep for you
  9. Apr 1, 2012 at 10:28 AM
    Dr. Sleep
    Dr. Sleep Well-Known Member
    Shane
    Colorado
    07 DoubleCab SR5 4X4
    I know this is an old thread, but was wondering if Bud Built redesigned their skid plates for the tacoma . . . . it seems the IFS one pictured here is different from previous ones.
  10. Apr 1, 2012 at 10:32 AM
    hard2kill
    Rhinebeck NY
    he has a 1st gen taco you have a 2nd gen
  11. Apr 1, 2012 at 10:42 AM
    Dr. Sleep
    Shane
    Colorado
    Uhhhh . . . . thanks ....feeling pretty dumb now. :)
  12. Apr 1, 2012 at 3:25 PM
    hard2kill
    Rhinebeck NY
    lol its all good...btw i love my budbuilts..
