Budbuilt Skid Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk340, Nov 16, 2013.
  1. Nov 16, 2013 at 1:32 PM
    elk340
    elk340 [OP] Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Will the Budbuilt IFS skid work with a Toytec diff drop? I'm ready to bolt skids up today but things are not quite lining up for me. There are no questions and answers or anything helpful on their website.
    Justin
  2. Nov 16, 2013 at 1:35 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    From what I have seen and heard it will not.
    Also - FWIW there are many who claim the diff drop is not necessary either...
    Best of luck! :thumbsup:
  3. Nov 16, 2013 at 2:39 PM
    elk340
    Justin
    Ouray, CO
    After removing the diff drop, it would appear my BAMF LCA skids will make contact with the Budbuild IFS skid. Damn. I'll likely need to cut the IFS some to make clearance.
  4. Nov 16, 2013 at 2:50 PM
    elk340
    Justin
    Ouray, CO
    Craig,
    I saw you have Budbuilt skids and BAMF LCA skids as well, did you have to cut your IFS for LCA skid clearance? Did you have to cut a bit of your IFS skid bracket to properly "hang" the IFS skid on the hooks?
    Sorry.
  5. Nov 16, 2013 at 4:58 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    IIR I took a small 1"x1" corner off to fit the LCA skid on the passenger side. The drivers side fits fine.
    I'm pretty sure there are pics in Jerry's LCA group buy thread of what I did...
  6. Nov 17, 2013 at 7:59 AM
    elk340
    Justin
    Ouray, CO
    Thanks Craig!
