Budget 3 inch lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabe_taco_06, Jan 26, 2023.
  1. Jan 26, 2023 at 3:41 PM
    Gabe_taco_06
    Gabe_taco_06 [OP] Member
    2006 Toyota Tacoma 4x4
    17" KMC impact ol wheels 275 70 17 general tires
    I have a 2006 Toyota Tacoma 4x4, I'm wondering if anybody can help me choose a budget 3-3.50 inch lift kit.
  2. Jan 26, 2023 at 3:43 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    What are you going to use the truck for?
  3. Jan 26, 2023 at 3:44 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Bilstein 5100's. New coils, new leaf packs. Light racing UCA's and a carrier bearing drop kit.
    Reach out to headstrong off-road. Marie will get you right.
  4. Jan 26, 2023 at 3:46 PM
    Gabe_taco_06
    I don't plan to do any extreme off-roading or rock crawling just a good suspension that's good on and off road
  5. Jan 26, 2023 at 3:47 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    That's literally everything I installed about 5 years ago and it's been great. You don't wanna go over 3 inches. All from Marie.
    Keep it 2.5-3 so it doesn't look silly and you don't have more issues down the road.
    TS4x4 and 50Buck like this.
  6. Jan 26, 2023 at 4:18 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    In my experience there's no such thing as a budget 3" lift. Especially if your talking about a daily driver. I've had a couple first gen tacomas with "budget 3" lifts". I wound up having to replace multiple CV Axles on my 03, both trucks drove fairly crappy, and I had some vibrations on my 96. Both needed the proportioning valve relocated for the rear brakes to work "properly"
    I feel like anything over 1.5 - 2" lift requires relocation of a lot of stuff in a 4wd .... IF... your plans are to daily drive the truck and have it drive nice. Over time the budget type lifts wound up nickle and diming me in the long run over 100k.
    Just my .02
    TS4x4 likes this.
  7. Jan 26, 2023 at 4:24 PM
    TacoTuesday1
    SD CA
    6112/5160
    RXT
    UCA
    bearing drop
    alignment
    is about the minimum
    above that is Fox
    wanting 3” (probably too high) explicitly stating planning to avoid clearing off road makes zero sense
  8. Jan 26, 2023 at 4:27 PM
    Gabe_taco_06
    I've been looking at Bilsteins 5100, are those good?
  9. Jan 26, 2023 at 6:30 PM
    TacoTuesday1
    SD CA
    mine were not
  10. Jan 26, 2023 at 6:34 PM
    Bishop84
    Bishop84 Well-Known Member
  11. Jan 26, 2023 at 6:50 PM
    geekhouse23
    What springs did you have?
  12. Jan 26, 2023 at 6:50 PM
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I had 5100s on my red first gen on the lowest setting .75". They were installed with new rubber seats and new stock springs. They were not horrible. I would have rather honestly just rather purchased stock SR5 shocks.
  13. Jan 27, 2023 at 6:03 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    It all depends on what size tire you want to run. if youre looking at 33s, you need to start looking at Cab Mount Chops, UCA's, fender trimming, alignment....etc etc...its not just a lift and call it good, UNLESS youre looking at MAX tire size 265/75/R16 or something
    EDIT: there are people who run 285s, but they rub, and if youre going offroad, they will rub even more..
    2k2 likes this.
  14. Jan 27, 2023 at 6:05 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Don't cheap out on a lift. You're gonna end up paying way more in the long run due to your budget lift causing other components to fail prematurely. If you can't afford to do it right, don't. Just max out your tire size.
    2k2, NobDriver and MSgt O like this.
  15. Jan 27, 2023 at 6:26 AM
    NobDriver
    NobDriver Well-Known Member
    Brandon
    2015 TRD OR
    Is there even such a thing anymore as budget wallet friendly lifts anymore lol. Curious op what's your budget?
  16. Jan 27, 2023 at 6:34 AM
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Yes. But not at 3".
    1.5 - 2" you can get away without breaking the bank. Even then, to do it right you have to spend a little coin.
    Like others said... It kind of all depends on what you're doing with your truck and how often you want to replace prematurely worn components.
    3" lift is a lot if your not getting to the trail a whole lot and personally looks strange to me if you don't have some pretty big tires.
  17. Jan 27, 2023 at 7:52 AM
    El Taco Sucio
    El Taco Sucio Well-Known Member
    SoCal (805)
    Silver TRD Sport 4x4
    Mod list... Well, my paint is factory.
    Logger likes this.
  18. Jan 27, 2023 at 8:22 AM
    YotaFAB
    YotaFAB Well-Known Member
    I have a set of 6112 set on first clip and 5160 I am going to be selling. Also, have 2 " blocks for the rear. located in San Diego
    tudes and dirtnsmores like this.
