Budget 5-lug rear disc conversion/kit
Discussion in '5 Lug' started by 808wrench, Nov 8, 2021.
  1. Nov 8, 2021 at 10:58 PM
    808wrench
    808wrench [OP] New Member
    1998 single cab Tacoma
    I installed rear disc brakes onto my ‘96 5-lug. I’m happy with the results so I figured I would share it. My truck had the V-6 rear axle (I don’t think this matters)
    I used Sky Offroad brackets ($104), a pair of 1985 Eldorado rear calipers from eBay ($150), and rotors from a 2014 Cadillac ATS from Amazon ($75).
    The Sky Offroad brackets are for a 79-95 Toyota Hilux 4x4, but they fit 1st Gen Tacomas (I run them on my 2001 Tacoma 4x4).
    The calipers come with pads and a short flexible brake line. The fitting is 3/8 inverted flare. The stock brake lines could be cut and flared. I elected to buy Sky’s stainless flexible brake lines.
    The rotor was the tricky part. The closest fit that i could find (to the Chevy truck Rotor that the 4x4 trucks use) was a 300mm front rotor from the 2014 Cadillac ATS. The Caddy bolt pattern is 5x115, but it is close enough that it installes without modification.
    The only modification that was needed was to sand down the axle flange. The stock diameter is about 152mm. I had to sand it down to 148.6mm for the rotor to clear. I made it a close fit to the rotor, so an alignment ring was not needed. Anyone know of a better rotor?
    Later on, I will install a Lugnut 4x4 parking brake cable. I used them on my 4x4 with good results.
    I took a few pictures. I’ll figure out how to upload them if there is any interest.
    TacoBunny, Wulf, Plkyone and 2 others like this.
  2. May 14, 2022 at 10:27 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    Thank you for this. Found my next mod. Does your handbrake still work?
  3. May 14, 2022 at 10:35 PM
    e.deCastro
    Eric
    San Diego
    Please post pictures.
  4. May 15, 2022 at 9:01 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Blast from the past!!
    For me the easy rear axle disc brake swap was swapping in a rear disc brake 4Runner complete axle !
    All off the shelf Toyota Parts if anything fails The parking brake still works. some fabrication at the intermediate lever needed
    Just a simple matter( for me) to remove the coil spring parts and weld on spring pads for leaf springs.
  5. May 16, 2022 at 1:31 PM
    e.deCastro
    Eric
    San Diego
    I can't weld so this is a great option for me. and it's only been7 months. not too much of a blast from the past and a lot of 5 lug people (including me) really want this option.
    Wulf likes this.
  6. May 16, 2022 at 1:35 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I love the detail provided by OP!!!
