Budget 6" lift
Discussion in 'Suspension' started by redtaco, Feb 7, 2010.
  1. Feb 7, 2010 at 2:09 PM
    redtaco
    redtaco [OP] Well-Known Member
    Im not sure if this will work of a "budget" lift but let me know of any other options.
    1999 Tacoma Ext cab 4x4
    This is a daily driver that sees no offroad time.
    Eibach Coils- 3" spacers- 3" AAL- http://www.suspensionconnection.com/cgi-bin/suscon/85250TA.html
    2" shackles- Longer shocks
    Price looking around $1K
  2. Feb 7, 2010 at 2:12 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It will ride like crap and likely break. Your front suspension will be overextended and you will destroy your balljoints.
  3. Feb 7, 2010 at 2:16 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Are you trying to compensate for something?? Why lift it if you aren't going to do any off roading. It's your $$ to waste though :eek:
  4. Feb 7, 2010 at 2:16 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    very bad idea to stack lifts.
  5. Feb 7, 2010 at 2:25 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Theres times to be on a budget, But you never skip on your suspention, If you want a lift cheap go with a 3" spacer lift.
  6. Feb 7, 2010 at 4:27 PM
    redtaco
    just want it to look good :D
    it was just a thought, but i figured it wouldnt work just wanted to get some input
    what about a 3" spacer w/ 5100s stock replacement coils and 3" AAL- 4" lift
  7. Feb 7, 2010 at 5:15 PM
    Jason'sLawnCare
    I would preload the 5100's at 2.5 as opposed to putting a 3 inch spacer in there. I'm not aware of a 3 in aal. If you lift the back that much don't forget to extend your brake lines though.
  8. Feb 7, 2010 at 7:37 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you're looking to lift the rear much more than the front...
    unless you want the truck to sit like a dragster...
    when lifting, if you want the truck to sit level, think 1.5 to 1 on a 1st gen...
    if you lift the front 3", you want to do the rear at 1.5" to 1.75"
    lifting the rear 3" would work if you lifting the front 5"
  9. Feb 8, 2010 at 2:59 AM
    redtaco
    wouldnt it be lifting the front about 4.25 (3" spacer and 1.25" setting on the bilstein 5100s) and the rear 3" aal from skyjacker #RTC20
  10. Feb 8, 2010 at 3:21 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    being that your truck is 4x4, if you lift more than 2.5'' your going to run into CV problems real quick. if you want 6'' you need a drop down bracket, but thats much more than $1000. other than that you'd have to get into a body lift, which is super phag.
    there is no budget 6'' lift.
  11. Feb 8, 2010 at 7:22 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  12. Feb 8, 2010 at 3:56 PM
    redtaco
    3" it is then
    rancho or pro comp shocks?
  13. Feb 8, 2010 at 4:04 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    neither
  14. Feb 8, 2010 at 4:04 PM
    Jason'sLawnCare
    Good decision. Honestly if I were in your position I would go ome but that's just my opinion
