Budget build help w/ idctx65cs
Discussion in 'Audio & Video' started by Amo-cat3, Dec 17, 2010.
  1. Dec 17, 2010 at 1:02 PM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Finally doing my stereo upgrade and want to do install myself (I'm a novice, but know the basics). I have a Pioneer avh-3200 unit, Pioneer GM9500f amp which has 75w rms x4 x 4ohm, and ID ctx65cs comps on order. I'm not to picky on SQ, but just need a little more bump from my system.
    I want to amp the front components and sub and will power my stock back sperakers with headunit.
    Questions:
    1. is the amp enough to push the front components and a single sub. don't want to add another amp for sub. If so what sub do you recommend - i eventually will get a ********* sub enclosure for my dbl cab. i could bridge amp for fronts, but ideally want one amp overall (please don't tell me to change amps :)
    2. Which install kit to make my hookup the easiest
    3. can i just sound deaden my front doors for now. If i don't sound deaden will my truck just be a rattle snake on steroids.
    Anything else i should get to make this a painless install.
