Budget Build Questions
Discussion in 'Audio & Video' started by mondata, May 20, 2010.
  1. May 20, 2010 at 2:25 PM
    mondata
    mondata [OP] Member
    Tyler
    Auburn, AL
    2004 PreRunner SR5 TRD
    2.5" Bilstein Adjustable Struts 1.5" Rear Shackles
    Ok so I am looking at doing a budget build in my 04' Double Cab since I do not plan on owning the truck more than 3-4 years.
    I think I am going to go with:
    Hifonics Zeus Series 6.5" components in the front
    6.5" Zeus Coaxials in the rear.
    [FONT=Arial,Helvetica]
    Hifonics ZXi-4410 4-channel 440W amp or something similiar.
    I am not set on Hifonics I just like to have the same equipments all the way around. 1 already have an 8" TREO sub (perfect for my 01 ext. cab Frontier) and plan on putting that in the double cab just for some added bass (not expecting too much but should add some lows). The question wouldn't it be easy to just purchase a 4-channel amp and run the front components on channels 1 and 2 and bridge channels 3 and 4 and hook that up to the 8" sub. I will run the rear speakers to the headunit so that I can fade them out some. To do this I need two sets of preouts correct?
    Thanks guys
    [/FONT]
  2. May 20, 2010 at 2:32 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    Yes you need two sets of preamps. Sounds like a nice system. I found some good used stuff for my setup and saved a ton.
  3. May 20, 2010 at 3:31 PM
    IRDCTACO
    IRDCTACO Well-Known Member
    Charleston SC
    07 IR DC
    Actually, you don't NEED 2 sets of preouts, but it would most likely work better that way. You COULD just run a Y-adapter from each single output thus making it a dual output RCA jack.
