Budget lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nctaco90!, May 23, 2018.
  1. May 23, 2018 at 5:39 AM
    Nctaco90!
    Nctaco90! [OP] Member
    2018 Grey Tacoma Trd sport
    Stock....for now
    im wanting to do around a 3” lift on my 2018, I don’t have a ton of money to spend so what would be a good budget friendly lift?
    TacoManOne likes this.
  2. May 23, 2018 at 6:27 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
  3. May 23, 2018 at 6:41 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    If you go that route, make sure and get new coils (OME 887 or 888's for +$180~). And you'll need an AAL or block for the back if you want to keep it level.
    @HeadStrong Off-Road sells a complete kit.
    https://www.headstrongoffroad.com/store/p401/Coil/Bilstein_5100_Kit_(HS16BK-1).html
    Depending if you want 2" or 3" of lift..you may need new UCA's as well to get it in alignment and reduce rub.
  4. May 23, 2018 at 8:48 AM
    Ballinbosox
    Ballinbosox Well-Known Member
    Andrew
    2017 Toyota Tacoma TRD Sport White
    yea if you don't get coils you can put it at the highest setting if you so please to reach your desired height or any other setting.
  5. May 23, 2018 at 9:21 AM
    ThinkMud
    ThinkMud Well-Known Member
    2020 4Runner TRD Off Road Premium
    leveling lift, wheel spacers, yakima cross bars for the canoe.
    You can get a spacer lift for super cheap, rough country and others sell them. They are cheap, easy to install and work fine for most people. Not the preferred method on this site, but they work and many run them. I have 2.5" spacers up front and 2" blocks in the rear and running 33" tires no problems.
    sierra141 and Ballinbosox like this.
  6. May 23, 2018 at 9:37 AM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    i'm glad this thread started.... as i'm thinking about this a lot lately - mostly due to the chatter on this forum :)
    I have a 2017 Limited... that the dealer did a 3" lift on it for me (using spacers), with TRD Wheels etc. Looks awesome. I'm admittedly a mall crawler, but do a lot of mountain biking, so do see a fair number of trashed out forest roads, etc. Not really planning any serious off roading, but would like the confidence to know that I can get through most stuff i'll see on the way to a trailhead.
    I've been thinking about a suspension upgrade (again, reading all the forums and backlash on spacers)…. and of course the 5100's come up quite a bit.
    Knowing the type of use i'm suggesting, what would this get me? any smoother on the road? Less nasty cup-caking throwing stares from other forum members? :)
  7. May 23, 2018 at 11:24 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Let me save you some money... you can get through any roads you have the courage (balls) to get through, in a stock Tacoma. No lift, no sliders, no winch, no nothing except a stock 4WD Tacoma. 90% driver skill, 10% vehicle. Most guys who offroad all the time will tell you NOT to lift, as it raises your center of gravity and increases rollover chances.
    However, if you are lifting for show, then go for it as that is what most people are doing it for anyway.
  8. May 23, 2018 at 11:32 AM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    thanks... super helpful.
    to be clear though, mine is already lifted :) ... for show :)
    but if i was made of cash, what would the 5100's (for example) get me?
  9. May 23, 2018 at 12:03 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    From a Limited OEM suspension? A softer ride, which is better off road, not so good (body roll) on road. That's pretty much it. To get any real off road improvement, you need to A) Define what you will be doing off road and B) Decide how much you want to spend. For example, if you were high speed desert running, A King suspension with remote reservoirs is the way to go. If you were rock crawling, an Icon Stage 2 or 3 is the way to go. If you are just generally putzing around off road then stock is just fine. Don't get caught up in the hype. For looks, a spacer lift is sufficient.
    Actually, let me take it a step further: Your stock suspension is the best "compromise" suspension you can have. It handles great on the highway. It gives you the ability to go off road, although not as well as some of the other models, but you don't have the greater body roll on the highway either. Your stock suspension will last a long time (super reliable) with no maintenance. When you need new shocks, simply throw the old ones away and the new ones are cheap.
    That's what I mean by compromise. Any change you make is going to cost you somewhere like on road handling, off road handling, maintenance, reliability and durability and cost.
  10. May 23, 2018 at 12:06 PM
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    super helpful again... thanks so much.
    so why all the negativity on spacers?
    hiPSI[QUOTED] likes this.
  11. May 23, 2018 at 12:07 PM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Because when people take them off-road the struts break. Not surprising, don’t put a spacer lift on anything you beat on. For show and pavement pounding, you’re fine.
  12. May 23, 2018 at 12:08 PM
    Dirty Harry
    Andrew
    SW Florida
    This comment really helped me understand the different settings on aftermarket coils/shocks. Figured I share it.
    https://www.tacomaworld.com/threads/coil-preload-question.327637/
  13. May 23, 2018 at 12:24 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why do city dwellers grow beards and wear flannel?
    Why do people talk shit from the safety of their keyboards?
    Why do people with no athletic ability criticize pro players?
    Why do fat women wear yoga pants?
    Why do guys who will NEVER go off road spend thousands to get a "look" of toughness?
    Why do people think they are smarter than the engineers who designed it?
    :notsure:
  14. May 23, 2018 at 12:27 PM
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    picture pls?
  15. May 23, 2018 at 12:31 PM
    Dirty Harry
    Andrew
    SW Florida
    Cus sometimes engineers do weird shit.
    https://www.youtube.com/watch?v=KfqMDO2duos
    On second thought... I think we could use this in the 3rd gens.
  16. May 23, 2018 at 12:36 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  17. May 23, 2018 at 12:43 PM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    1) because they want to look rugged without actually being
    2) because no one can punch them in the face through a computer for being wrong or a dumbass
    3) because the invention of xbox and playstation have made everyone a subject matter expert on all things Military, Driving, Fighting and Sport related
    4) because they think it says one size fits all ( just because you can doesn't mean you should)
    5) because how else will anyone be impressed by such awesomeness that is a lift, big tires and shit gas mileage while having the cleanest truck around...oh resale thats why..my bad
    6) because mom and dad said they are smart and the only people who tell them they are wrong is random people on the interwebs that honestly have more experience in real life but mom and dad are truth tellers and everyone else is a liar ... also because google told me so....everything on the internet is TRUE
  18. May 23, 2018 at 1:03 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    We need to know what your budget is to determine what's budget friendly.
    Anything over 2.5 inches will likely require aftermarket UCA's to get a decent alignment which would add $400-600 in addition to the lift. If 2 inches or less a decent lift can be done for under $800.
    TacoTRD78 likes this.
  19. May 23, 2018 at 1:04 PM
    batong_23
    SoCal
    with the 5100 set at the lowest and using 887 coils, would you be needing to change your UCA?
    CaptainBart45 likes this.
  20. May 23, 2018 at 1:07 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Depends on the truck, some do to get a decent alignment some don't.
