Budget lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nctaco90!, May 23, 2018.
  1. May 23, 2018 at 1:13 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    3) You forgot Overlanding
    Hobbs and hiPSI like this.
  2. May 23, 2018 at 1:19 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    simple, engineers are on a budget, so they do not always design for the "best". As for lift and offroad, there are trails where you need more clearance. parts of Joshua Tree, Pilot Rock etc come to mind.
  3. May 23, 2018 at 1:20 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Oh God yes, how can we forget that jewel...
    stealthmode[QUOTED] and jsinnard like this.
  4. May 23, 2018 at 1:22 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    we do its called 4H and 4L, or for the mall crawlers, ECT
    Dirty Harry[QUOTED] likes this.
  5. May 23, 2018 at 1:22 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    And Instagram...... need the offroading porn.
  6. May 23, 2018 at 1:24 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You got that precisely wrong lol. Engineers (except Civil engineers and they don't count) are never on a budget - the people who buy their products are the ones on a budget. Take the Tacoma for example, pretty sure if the prospective customers wanted to spend $100K on their trucks the Toyota engineers would give them their money's worth... that's OK though, people get that concept wrong all the time.
  7. May 23, 2018 at 1:24 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Ain't that the truth?
  8. May 23, 2018 at 1:26 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    I'm in the manufacturing business, for 25+ years, trust me they are on a budget.
    TacoManOne likes this.
  9. May 23, 2018 at 1:29 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    So am I. Their budget is proportional to the customer's budget. The customer always controls the budget. My original was a tongue in cheek comment directed at the guys who argue over oil change intervals and cold air intakes lol.
  10. May 23, 2018 at 1:31 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    oil change and cai...yea thats a never ending debate. One that I "exclude" myself from as much as I can.
    hiPSI[QUOTED] likes this.
  11. May 23, 2018 at 1:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Those guys are "always" smarter than the engineer lol.
  12. May 23, 2018 at 1:34 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I ran this set up for about 1 and 1/2 years good setup and my alignment was very close to factory. With added 1/2" and 1/4" spacer and aftermarket UCA's my alignment improved.
  13. May 23, 2018 at 1:38 PM
    desperado915
    desperado915 Well-Known Member
    No disrespect, but this is pure urban legend. A spacer above the strut along with a bump stop extension prevents that from happening. Of course, with no bump stop extension, one COULD break or bend the strut while off-roading. Best advise I can give you is determine the size of tire you want to run first. THAT will determine the means and size of lift you need.
    stealthmode and hiPSI like this.
  14. May 23, 2018 at 1:44 PM
    TacoTRD78
    Stuart,fl
    I agree to some extent of this. One could run 33" with a spacer lift and be equivalent to the same tire size as one with say a OME lift,however I would not advise the one on the spacer lift to take the same lines as one with the OME lift.There are a lot of variables to take into consideration.It mostly depends on ones function of the vehicle. If your going to offroad and you cant afford a reasonable lift kit than save your money until you can.If you want to stay on pavement and run 285's than a spacer lift will be just fine. Just my .02
  15. May 24, 2018 at 4:37 PM
    #35
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    Topping out is what breaks them, I've seen photos and heard from reputable mechanics. So no it is not a "urban myth"
  16. May 24, 2018 at 6:41 PM
    #36
    desperado915
    OK, you heard this and you heard that. Got it. I have over 25 years of building 4x4 suspensions (Jeeps, trucks, etc.) so I will explain to you what happens. When you add a spacer to the strut tower and take your truck off-roading, there is the possibility/probability that you will OVER COMPRESS the strut. The longer strut compresses, but there is no bumpstop to prevent over compression. All of that down force then bends the lower strut housing because the stock bumpstop was unable to do its job and prevent said over compression. This is why a simple bumpstop extension spacer prevents the destruction of the strut during full compression. I hope this helps your understanding.
    So, yes, an improperly set up spacer lift can end badly, but if you simply extend the bumpstop it will be fine.
    House Forsaken, ATXtacoJay and hiPSI like this.
  17. May 24, 2018 at 9:52 PM
    #37
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    thank you for contradicting your first post :) Regardless "how", it will cause damage, that was the point.
    topping out, just re-read my post...was thinking too much preload and not spacers.
    too much preload-topping out
    spacers-as you have pointed out, bottoming out
  18. May 25, 2018 at 2:13 PM
    #38
    desperado915
    I didn't contradict anything. The "Urban Myth" is that spacer lifts are bad and cause damage to the strut. Damage is only an issue if you don't extend your bump stops properly. Most of the guys running spacer lifts never run their 35k Tacoma's on any type of rough terrain anyway. I wouldn't either. That said, I have seen guys that run stock AND after market strut assemblies bend their struts because running high speeds over rough terrain without the best suspension (read very expensive) components can destroy their suspensions as well. Please don't take this the wrong way, but I just get a little tweaked when people that "heard this, or heard that" pipe in that really have no real world experience to back their claim. I do think we can both agree that a spacer lift is a bad idea if improperly set up or used in hard core off road conditions. By the way, I used to live very close to the Mohave desert at one time. We were rolling Jeeps through Calico Ghost Town, Big Bear, etc. Great area for a Taco.
    TacoTRD78 likes this.
  19. Jun 8, 2018 at 3:50 AM
    #39
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    So you're saying a spacer lift with bump stop extensions would be viable for say fire trails and mild off-roading? Asking for a friend :spy:.
  20. Jun 10, 2018 at 4:06 PM
    #40
    desperado915
    Yes. I wouldn't abuse it though.
