Budget Method To Run 285/60/18?
Discussion in 'Suspension' started by IrishPilot, Nov 28, 2009.
  1. Nov 28, 2009 at 1:30 PM
    IrishPilot
    IrishPilot [OP] Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    I know jack about lifts. Ive read through the stickies, etc. but havent seemed to find the answer Im looking for. Id like to run a 285/60/18 setup for a truck that does minimum off-roading (mostly pulling a 20ft boat).
    I dont really consider myself a "lift" guy, so Im just looking for the minimum I need to do to run this setup, and how much its going to cost me.
    Thanks for any insight! (and for your patience with my stupid question)
  2. Nov 28, 2009 at 1:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be fine running the Bilstien 5100's set at 2.5". Then, a 1.5" AAL for the rear, along with 5100's should be fine.
  3. Nov 29, 2009 at 7:18 AM
    IrishPilot
    MN
    5100s at 2.5 all around Chris? Thanks for the input.
  4. Nov 29, 2009 at 7:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only the fronts can be set for height. You would need to run an add a leaf in the rear. :)
  5. Nov 29, 2009 at 8:35 AM
    IrishPilot
    MN
    Gotcha ;) thanks again
  6. Nov 29, 2009 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anytime :)
  7. Nov 29, 2009 at 9:30 AM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    Lifting it would look better, but you can run that size tire with some trimming. When I had my '06 I ran it that way for a couple months. I had to take the mud flaps off and trim both the front and back of the fender flares.
