Budget Solid Axle 2nd Gen
Discussion in '2nd Gen. Builds (2005-2015)' started by Van-go, Dec 25, 2019.
  1. Dec 25, 2019 at 1:19 PM
    Van-go
    Van-go [OP] Well-Known Member
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Just joined. Almost done with this build, but needing some input from the experts. Never really messed with Toyota’s.
    Started this build a few months back. I’ll get everybody up to speed slowly as I have time to post.
    It had a good start when I got it.
    Had a ECGS rear 60 with a grizzly locker and 35 spline chromos.
    FJ case swap was done (console was a little hacked up)
    Chevy 63in springs in rear
    Front diff was removed.
    Had total chaos LCA’s and some aftermarket uppers. (Sold them on FB)
    front crossmember was already modified for a winch.
    this is how I got it.
  2. Dec 25, 2019 at 2:17 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    It also had a flatbed on it and a fuel cell. Really frees up space under the frame.
    That first gen is my buddy’s. We had just finished up his 3 link front and were getting started on my budget SAS.
    Got to work with removing all the IFS stuff.
    E7DDCF67-1AFE-4C0F-B0CF-474E2B80E552.jpg 5571F34E-9B0D-4E6E-BBD0-0CD9481E4C44.jpg F3B4A0FF-12D0-4450-B51D-2D2D0B296515.jpg 2EF0074F-BC27-4DC0-84F9-A24309982050.jpg
    essjay, 2ndGenOffRoad, Mully and 4 others like this.
  3. Dec 25, 2019 at 2:27 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    I knew how much work went into my buddy’s 3 link so I decided to go back 30 years in suspension technology and run leafs.
    I had a couple 1990’s Ford Dana 60 fronts laying around so I decided to use one of them.
    I settled on a set of stock ‘02 tacoma rears I had laying around and decided to use slider boxes up front.
    Had to add a few misc leafs to the packs to get the height I wanted.
    Spring perches are wider than Tacoma frames up front so I had to outboard the front mounts. Turned out okay.
    6EB75BA1-F853-4C4D-AC46-958065CE833E.jpg 1B6C9955-A4FB-4BF1-91EA-CEB4A58A7755.jpg A3F02EB9-9552-4DBA-BA82-F1350A49E160.jpg EA751DAE-4DA9-4E75-ACA4-4785A710BF8A.jpg E9B4E7B5-AA1E-4DD7-B1C6-1ADF601DA58C.jpg 8DEDA503-BFF4-4E5B-ABA0-9C5092A6B8DD.jpg
    Windigo, Slashaar, b_r_o and 10 others like this.
  4. Dec 25, 2019 at 2:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Following along. Always liked the idea of a simple, leaf sprung sas on our trucks.
    Slashaar, Mully, 05Taco4x4 and 3 others like this.
  5. Dec 25, 2019 at 2:36 PM
    chank
    chank Member
    Colorado
    07 DCLB
    Nice start! You looking to sell those LCAs??
  6. Dec 25, 2019 at 2:37 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    It always starts simple! It gets a little more interesting. :D
    EatSleepTacos[QUOTED] likes this.
  7. Dec 25, 2019 at 2:38 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    I already sold them. That’s how I funded the rest of the build. Sorry man
    whatstcp likes this.
  8. Dec 25, 2019 at 2:43 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Got the axle cleaned up. Had a buddy bring it down from NY a while back. It was a little pitted.
    Welded the tubes to the housing.
    Windigo, 2ndGenOffRoad and 05Taco4x4 like this.
  9. Dec 25, 2019 at 3:05 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Got it on its own weight. Still a long ways to go!
    Rear end had 4.56 gears, so I matched them up front.
    Pattern turned out okay.
    Had a Detroit sitting around. Threw that in for a locker.
    all new seals, etc into the axle.
    E5871335-DC8A-4929-BB3F-00EB0CA6BC9C.jpg 7ED6BDDC-D1F3-4365-9D58-DAD9332227A2.jpg
  10. Dec 25, 2019 at 4:21 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Steering box is next. Had to trim out part of the fender and remove the radiator to get in there right.
    B4DFABA1-B134-407D-B7B2-D181F48E8C12.jpg 85C29087-88B6-4110-AA2B-168514E3BE15.jpg E0FADE0F-EA7A-41A9-A4BA-7C73DBCC1C1B.jpg
    Ordered a flat pitman arm, but the drag link still hung down too far.
    Had to cut it in half and flip it to mount the DLE on top.
    F1407992-9967-4F7B-BAFC-1A415E5B6BBB.jpg B73134FD-53CE-4A36-855E-F4C552237DEF.jpg D340AC5E-875A-4AD1-AB7E-33507DD8FD55.jpg C5EBA6E8-23FE-46F8-8687-E848EA7270AC.jpg 7C5711C0-4160-4D7A-BAB6-3C70C9DB42D7.jpg
    Windigo, Slashaar, Wulf and 9 others like this.
  11. Dec 25, 2019 at 4:36 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Frame had to be cut ALOT to clear everything.
    Plated it inside and out.
    0DD5BD20-33F6-457D-96D8-F65A8FBF4DA1.jpg CCA66AC0-AF5D-4A9C-AFD5-25E76D1C7E55.jpg 176C82F1-2E67-482F-B129-58F6A3EFFEF3.jpg 17D87293-2490-4C8F-9EF8-ABF5938A7ADF.jpg 1D1D2692-BBCC-4890-9536-64CE00ED87EA.jpg
    70A40C98-46D8-4573-A751-BECD35D24B8D.jpg F91449F7-277F-4D57-8B01-07B920713BB9.jpg 90C452BE-CECB-43A5-AEFD-EF61B3B76C1C.jpg
    Extended a steering shaft I found at the junk yard to work.
    Got an adapter U joint thingy to weld on the end of the 3/4in solid bar to go to the steering column shaft.
    91834D17-692D-4EB7-9449-AA9CFC66AB09.jpg B6E5A816-D4A2-4C76-B43A-B937956006A2.jpg
    Windigo, Slashaar, Key-Rei and 5 others like this.
  12. Dec 25, 2019 at 4:46 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Made a drag link and tie rod too...
    So Toyota IFS boxes have about 6-7 inches of throw depending on your pitman arm. The high steer arm I used was made for 8 inches of throw. I had to use the hole that is closer to the knuckle. This moved my drag link back closer to the motor at full lock to both sides.
    This meant I had the axle about 1/2in too far back.
    Drag link was getting into the lower idler pulley.
    Notched it out and made some funky bends. Seems to clear.
    35D6DB01-4467-4C84-9D81-FF7D99501C61.jpg B1F19560-4CD4-4A81-91DA-4A9605343407.jpg 241EE260-5986-44FF-90BA-65E7F1F3E4C2.jpg 031B6519-90C7-4914-A10B-C70B2F96A4A0.jpg
  13. Dec 25, 2019 at 4:54 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Frame still flexed more than I wanted.
    Added some more bracing and cleaned up my plate job.
    0A4112D6-AD41-405B-A960-25444A3EAFDE.jpg 993D28B2-9A61-490A-9C55-B3CAC22362C1.jpg 2B0F7549-0F1D-402F-AEB7-D9344DA70EE4.jpg
    Also ordered some frame plates from WFO. Fit great. Just tacked them as I went then welded them in. Modified drivers side to fit around what I had already plated.
    75CA036D-0965-4B0D-835B-E8D264AA154D.jpg 135C6A76-E85D-48B6-86A0-7B56BC46582F.jpg 1E9B6E6D-93D9-4F0D-8968-61D723A5A456.jpg F01C4125-D1E5-4FBA-A70C-B82188ACE810.jpg B9A205E2-08F6-4010-9C7B-1C648C829A3F.jpg
  14. Dec 25, 2019 at 4:56 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Painted some things. Tried to color match it.
    068E5F74-D9A5-45B2-838F-691A0D07B49B.jpg C7CEB9B6-7939-41FF-8B86-5A14237E6B77.jpg BAEFFFFA-DE5A-4A50-876C-9A8F702B6A61.jpg
  15. Dec 25, 2019 at 6:42 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    35 spline outer shafts. Spicer U-joints. Stock 35 spline inner shafts.
    axle bolted underneath.
  16. Dec 25, 2019 at 6:47 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Drilled and tapped the steering box. threw some paint on it as well.
    9F6458DD-382F-4BFD-B324-04963FC302B3.jpg 04AC9592-1F9D-4CF0-B675-013E7738ED68.jpg
  17. Dec 25, 2019 at 6:52 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Decided to run a Surplus Center 1.5x8in ram for hydro assist. Running the stock pump for now. Not sure if there are any other options for one with more PSI that will bolt in.
    Ram mounted and lines run.
    used a 1981 TOYODA steering reservoir. Cut it, rolled some tube up and TIG’ed it up.
    Hopefully there is enough volume so the pump does not starve.
    90EE5383-B0CD-4982-8DEF-B0700A73C823.jpg D4E3C767-2904-42CC-9FB9-897C554B400A.jpg 093FC0B0-456A-4E7F-8742-6B609AEAC455.jpg 45B14286-8533-4A56-8C56-C7735FE9C231.jpg 63B24632-5248-4481-9757-64F8989FB773.jpg
  18. Dec 25, 2019 at 6:54 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Im in
  19. Dec 25, 2019 at 7:03 PM
    Van-go
    David
    Greensboro NC
    2009 Tacoma
    Dana 60 F&R
    Time for a front driveshaft.
    Had a long slip double cardan shaft I had cut down and retubed with .25 wall tube.
    Had to get a flange for the 60. Trail Gear came through.
    Cut out the stock crossmember.
    Modified it to clear the droop of the driveshaft.
    D7CABD9A-CC6D-4E41-B954-6A65CCB7D460.jpg 494C79E5-07CD-4BEC-8E0F-D15BC0200DE3.jpg DDBF86A4-110D-4C43-A30B-0512762BA4C6.jpg 8FCA751F-77C0-4CFB-B5DF-CD76CFF2E49D.jpg
  20. Dec 25, 2019 at 7:03 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Clean fab work. I have done a bunch of SASes on ifs rigs and the only thing I would have done different would be that I would have hung that steering box way farther out. To make room for the box, hacked up the rad support, cut off the body mount and fabbed a new one around the steering box. Then pushed the axle 6” forward and had crazy good approach angles. BUT not being there and personally seeing what you where building with, my opinion is essentially worthless.
