Bug deflecters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevin46, Mar 2, 2010.
  1. Mar 2, 2010 at 1:03 PM
    kevin46
    kevin46 [OP] Member
    Kevin
    Jayton. Texas
    2010 DC prerunner TRD
    toyota racing sport package
    I was wondering, I want to install a bug guard, either AVS or EGR on my 2010 tacoma. what Im worried about is how it fits , does it rub the grill or will the rubber seal thats under the hood be in the way. thanks
  2. Mar 2, 2010 at 4:35 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Depends on what manufacturer and what model you get.
    Some mount on brackets that hold the guard away from the hood a bit, some mount right to the underside of the hood.
    I had a Lund Avenger that mounted to the underside of the hood. I left the rubber seal on. Didn't seem to make a difference. Everything worked fine and it did not rub on anything.
  3. Mar 2, 2010 at 4:47 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    My AVS doesn't seem to be rubbing on anything.
    I haven't taken it off to confirm this due to the plastic screws pieces having that single use quality about them. Not sure it they will work as intended if re-used.
  4. Mar 2, 2010 at 4:49 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    i have a weathertech b/s. fits great. but it does stick out further on the sides than the factory one does, and the ends broke off. thinking about getting a factory one for a replacment.
  5. Mar 2, 2010 at 4:58 PM
    WNYTACOMA
    Clarence, New York
    The factory one is the one that you don't want.
    Plenty of information to research on it, but they have a moronic design that employs clips (5?) resting on the surface of the hood to support the shield.
    The obvious result over time as a result of wind flex would be that the clips wear through the little plastic 'buffer' pads they adhere between the clips and the hoods surface.
    Stupid design that had lead to predictable damage to plenty of hoods of people who should have known better.
    Stay away from the ones with the clips supporting the shield against the hood. (Toyota OEM)
  6. Mar 2, 2010 at 5:13 PM
    Lennard Jones
    Lennard Jones Member
    2010 Double Cab 4WD TRD Off-Road
