Build a Homemade Kegerator
Discussion in 'Off-Topic Discussion' started by Agent475, Nov 7, 2008.
  1. Nov 7, 2008 at 12:59 PM
    Agent475
    Agent475 [OP] "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Ok, so I have not done this yet - but it's on the list... I found this online and wanted to share it - in case anyone else wanted to do the same… Anyone out there have any experiences in this? If so, I’d love to see some pics!
    ***You will want to go to the link and read up on the topic before you try anything… I sure plan to!
    How to Build a Homemade Kegerator
    (Source - http://www.kegerators.com/articles/how-to-build-a-homemade-kegerator.php)
    "Homemade kegerators are a snap to make for the experienced home brewer. With only a few modifications, you can take a clean fridge and make a homemade kegerator out of it. It only takes about an hour to make the modifications once you have the parts, and your homemade kegerator can hold up to four different varieties of beer on tap all at once. You will thank yourself for going to the effort to make a kegerator, as your home brew will have a clean, cold, professional taste unlike what you have had before. There are two basic varieties to choose from, if you want to build a kegerator, and I’ll go into both of those here.
    Either the stand up fridge or the smaller half sized fridges are both easy conversions to make a kegerator from. It is recommended that you take the time to pick your base fridge with care. Measure the size of the kegs you are using and try to get a fridge that will pack as many kegs in it as possible. This will allow you to not only have ice cold beer on tap at all times in your house, but also will offer you opportunities to lager your beer by using kegs as fermentation vessels in your homemade kegerator.
    Whether you decide to go with a kit or hobble together what you need from individual pieces, this is the hardware that you will need to build a kegerator: kegs, a CO2 tank with regulator, a coupler, beer lines and CO2 lines (aka a lot of surgical tubing), a tap, tower (optional), drip tray, draft spigot, shank, and draft spigot handle. All of these items can be bought separately or all together in one of many homemade kegerator kits. It is likely that you will already have some of these items if you are an experienced home brewer, but the kits are not very expensive and available easily online.
    You will need a couple of specialty tools when you make a kegerator, which are also available online, with homemade kegerator conversion kits, and at your local homebrew supply store. You will most likely need to drill holes into your fridge in order to mount your draft spigots and spill tray. A simple attachment called the hole saw can drill through fridge materials quite easily, and is available at most hardware stores.
    You will want to ensure that the part of the fridge you are drilling through does not contain any coolant lines (most fridge doors do not), as damaging one of these lines will likely spell T-H-E E-N-D for your fridge. The only danger of this comes from drilling through the top of a half-sized fridge, one in which the door is side-mounted and not top-mounted. It is recommended to only use the top-mounted-door variety of these fridges for this reason. If you are going to build a kegerator, always use safety equipment such as goggles when drilling into the fridge.
    When you build a kegerator, the main difference between making a regular and half-sized fridge style homemade kegerator is that you may install a tower for your draft spigots in the half-size variety. These towers can come with your homemade kegerator conversion kit. When you build a kegerator with a tower it can give your home brew station a sense of bar-liked authenticity. The other difference when you make a kegerator out of the half sized variety is that if you do not use a tower, you will need to build a collar through which your draft spigots are mounted.
    Most folks make the collar out of 2x4s with a trim finish. This collar is where your shank is mounted for the draft spigots to attach to. It is a good idea to mitre the wood on such collars, cutting a 45 degree angle in the wood at the joining points. Remember also to seal the wood with a mold and water resistant coating once you are done with the inside (or structural) collar. Some adhesive foam can act a as gasket for between the collar and the edge of the kegerator and the lip of the kegerator.
    No matter which design you choose to make a kegerator out of, be sure to keep your lines clean and cold to ensure the continued good taste of your home brewed beer – and enjoy!"
    Another good resource: http://www.micromatic.com/templates/static/images/705/Kegerator_door_kit-use_manual.pdf
  2. Nov 7, 2008 at 1:13 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    He'll yeah mad props man
  3. Nov 7, 2008 at 4:50 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    i got my rough bar plans off of barplan.com . it also has info for a kegerator and my bar was actually designed for one...but i omitted it because i didnt have the room and rather have a sink instead. some days i wish i had the keg though.... if i ever move again and have more room i will make the full size bar with a kegerator for sure. had to cut this plan down quite a bit already because i wanted room for a table next to the bar for cards or whatever.
    maybe ill finish it this winter
  4. Nov 7, 2008 at 4:56 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    This thread could greatly contribute to the drunken ramblings thread :D
  5. Nov 8, 2008 at 7:20 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
  6. Nov 8, 2008 at 7:50 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    Yea.. I started scouting supplies to build my own bar.. but then I met my wife, so it got pushed to the side.. It will have to wait till we buy a house.. cant do anything major in a rental
  7. Nov 8, 2008 at 8:50 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    its not permanent. just make it in 2 pieces so you can carry it out :D Total for all building materials was around 1500. I used top grade stuff though. i priced out pre-built bars and they were over 2000 bucks for something of similar size on the lower end of quality. now i have water and electric and a better built bar for less.
  8. Nov 17, 2008 at 8:49 AM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    Badass looking bar at your crib RoyB. I am just getting back from business travel, so not it's time to start thinking harder about building one at my place...
