Build my own matching hood with hood scoop?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cybrnook, Jul 7, 2022.
  1. Jul 8, 2022 at 5:49 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Paint it inferno and I'll give you a couple bucks for it or trade you my scooped one.
    Also, where in SE Michigan? Waterford here.
    cybrnook[QUOTED][OP] likes this.
  2. Jul 8, 2022 at 6:04 AM
    cybrnook
    cybrnook [OP] Well-Known Member
    SE Michigan
    2022 TRD Off-Road Manual Transmission
    Rochester Hills :cheers:
  3. Jul 8, 2022 at 6:13 AM
    EarthCruzn
    EarthCruzn Well-Known Member
    Florida
    2022 TRD V6 4WD Manual 6 Speed
    DCSB SPORT
    Why not get one ready for paint?
    This one is functional ram air,..... nice. They do make non-functional as well.
    This is just one site that carry's them...... I would look around before OEM parts and build then paint as it is time and money.
    Just my thoughts, I would like to have a ram air intake option,.... or just block it off.
    https://www.extremeterrain.com/tacoma-sms-style-ram-air-hood-unpainted-tta16ahsmsfhw.html
  4. Jul 8, 2022 at 6:16 AM
    EarthCruzn
    Florida
    DCSB SPORT
    The underside,. see the air chamber opening to the air filter side of the Tacoma stock intake box
    cybrnook[OP] likes this.
  5. Jul 8, 2022 at 6:18 AM
    cybrnook
    SE Michigan
    @EarthCruzn pretty snazzy....... But I've never really had good luck with fiberglass parts before unless it was OE. The fit is allllways "close" but not quite (I'm a sucker for panel fitment and clean gaps). Cool design on that hood though, semi functional intake and all, hadn't seen that.
  6. Jul 8, 2022 at 7:05 AM
    EarthCruzn
    Florida
    DCSB SPORT
    Might be a nice fit, nice hood though.
    This is the passenger view;
    Toyota should be proud.
  7. Jul 8, 2022 at 7:14 AM
    cybrnook
    SE Michigan
    My buddy has a hood with louvers similar to that and we always giggle at him when runs outside with aluminum foil every time it rains so his intake and doesn't get wet :rain:
    I actually prefer the more sealed design of the OEM hood as I just got done Formula 3000 spraying my truck, and inside of the hood being one of those parts. So having the OEM hood be a bit more sealed off than a louvered hood is preferrable to me as I'm going to be filling it up with rust prevention.
  8. Jul 8, 2022 at 7:24 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    IIRC in the mid 60's Chrysler/Plymouth did some testing with hood scoops and found that unless scoops were at the very leading edge of the hood and of at least a particular size (like 2" x 20", but I don't remember exactly) they did not capture a lot of air. Supposedly most of it traveled over the hood...
  9. Jul 8, 2022 at 8:02 AM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Sorry but every time I hear the comment (panties dropper) I just shake my head. It has to be one of the dumbest comments to use especially in relation to a hood scoop…
    steel wheels likes this.
  10. Jul 8, 2022 at 8:50 AM
    steel wheels
    If she'll drop her panties for a ride in a Taco w/a hood scoop you should consider seeking out a different class or smarter woman. Be sure to check that it isn't a tranny...
    MadKatt likes this.
  11. Jul 8, 2022 at 9:12 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Huge waste of money, but you do you brother!
  12. Jul 8, 2022 at 9:31 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Funny, that's the same thing I told your parents.
    Rainoffire, tonered and msgs350 like this.
  13. Jul 8, 2022 at 10:35 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    tonered likes this.
  14. Jul 8, 2022 at 10:36 AM
    steel wheels
    Does anyone know if the sport hood scoop leaks in the rain?
  15. Jul 8, 2022 at 10:41 AM
    #35
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    If it does, it is very little.
  16. Jul 8, 2022 at 10:42 AM
    #36
    Buck Henry
    And if they were still alive, I am betting that they would agree with you!
  17. Jul 8, 2022 at 10:56 AM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note for clarity that one scoop on one of the full size Cheby's is functional.
    six5crèéd likes this.
  18. Jul 8, 2022 at 10:58 AM
    #38
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes sir on the Duramax it is. Friend of mine has one.
    tonered[QUOTED] likes this.
  19. Jul 8, 2022 at 10:59 AM
    #39
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Why would that matter? It is right over the top side if the intake / valve covers. Everything is sealed and uses water tight connectors.
  20. Jul 8, 2022 at 10:59 AM
    #40
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for the confirmation.
    :cheers:
    six5crèéd[QUOTED] likes this.
