Build
Discussion in '3rd Gen. Builds (2016-2023)' started by Joe23, Dec 29, 2016.
  1. Jul 17, 2017 at 1:49 PM
    #81
    Jake4848
    Jake4848 Well-Known Member
    Jake
    Petawawa, ON
    2017 Quicksand DCSB TRD Offroad
    6112/5160's,SPC UCA's,3 Leaf AAL, ECGS bushing, Extang Trifecta, 35% Tint, Rear diff breather mod, 285/75r16 K02, Clazzio's, RCI Sliders.
    I got mine directly from RCI. It's not peeling like crazy but pretty much at every weld I have rust starting. It's not a big deal for me, but I'll probably strip them one year and just spray bomb them. It's just kinda sad because I figured they'd last more than a few months before rusting. I got mine in November.
  2. Jul 17, 2017 at 1:54 PM
    #82
    Joe23
    Joe23 [OP] Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    word. so different person. I'm guessing the powdercoating that RCI uses isn't the greatest.
    My guess is whoever is doing their powdercoating isn't doing a good prep on the surface.
    I put mine on around march, so they still saw some salt but not much. But haven't found any rust. Mind you the prep I did was pretty thorough and prior to the zinc coating as I cleaned up the welds a bit I put some sort of paste stuff i got off a welder at work that they use to prevent corrosion.
    How did you mount yours? I didn't have two holes line up in the front so mines actually only head with three bolts on driver side and five on passenger. I upgraded all hardware though to 1/2 grade 8. I've put the highlift on them and lifted no problem and didn't have much flex. Even though I likely won't lift from them much, just use my tire lift attachment for the highlift
    Brafasco also does custom U bolts now as well so was thinking of getting some made up to go around the whole frame and slider part to better secure it, sort of like how mobtown goes around the whole boxed frame portion.
    got a price on them from brafasco of $56 each. not cheap but thats 1/2" grade 8 rod. Either that or I'll fab up some brackets.
  3. Jul 17, 2017 at 2:11 PM
    #83
    Jake4848
    Jake
    Petawawa, ON
    Mine mounted the same way as yours. Only 3 or 4 bolts per side, I'd have to check. I haven't lifted it with them, but they feel pretty sturdy when I stand on them. I'm sure I'll drill out the other holes at some point or weld them on. They're just handy for being high clearance door ding protectors right now. lol
    Joe23[QUOTED][OP] likes this.
  4. Jul 17, 2017 at 2:26 PM
    #84
    Joe23
    I haven't decided if I'll drill them out as I'm worried about frame rot and then toyota using that as an excuse not to warranty etc lol.
    I didn't get the wheels off but took all suspension travel out without the sliders moving at all. They're plenty strong to protect the rockers etc and protect from door dings from other cars. Just a little note, they don't help preventing you from dinging your own door when you open the door and hit a stupid post thing at the gas station, who would've thought. lol luckily it didn't actually damage my door.
    Either way after lifting and taking all teh travel out didn't find them to be moving or anything so i'd be pretty confident to lift off them. Even still they're mostly there for protection and will definitely do so.
    Jake4848[QUOTED] likes this.
  5. Jul 22, 2017 at 7:53 AM
    #85
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    AS an FYI, the ARB summit bumper works with the TRD Pro skid plate. I had mine installed the other week.
  6. Jul 22, 2017 at 8:33 PM
    #86
    Joe23
    I don't have the TRD plate. I have mobtown off-road.
  7. Jul 22, 2017 at 11:48 PM
    #87
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Could not find a place to mount your ARB twin ??????? Your kidding right !!
  8. Jul 23, 2017 at 6:57 AM
    #88
    Joe23
    Not a place that didn't sacrifice too much space.
    No place under the hood and no place in the cab that I didn't already have planned for other stuff
  9. Jul 23, 2017 at 6:59 AM
    #89
    Tacomamike mike
    Michael
    There is a ton of room under the hood !!!
  10. Jul 23, 2017 at 7:09 AM
    #90
    Tacomamike mike
    Michael
    image.jpg image.jpg I guess there's room if you want it! Installed these a couple weeks ago !!! I had the mounting plate built !
  11. Jul 23, 2017 at 2:42 PM
    #91
    Joe23
    Ya where you put it I want my second battery. I don't want both side by side.
  12. Jul 23, 2017 at 2:45 PM
    #92
    Tacomamike mike
    Michael
    Yep cause side by side MAKES SENSE !!! And leaves room for the twin!
  13. Jul 23, 2017 at 2:48 PM
    #93
    Joe23
    Too much weight in the one spot. Besides I pretty much got retail price for the twin
  14. Jul 23, 2017 at 2:53 PM
    #94
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Damn that's clean.
  15. Jul 23, 2017 at 2:55 PM
    #95
    Tacomamike mike
    Michael
    Lmao to much weight in one spot :). Boy your getting pretty freaking technical!! Did not realize you were a PRO !!!:facepalm::facepalm::facepalm:your going to need to explain exactly what the weight distribution does !!
    :rasta: Or at least share whatever your smoking !!
  16. Jul 23, 2017 at 2:56 PM
    #96
    Tacomamike mike
    Michael
    Thanks not bad for putting to much weight in one spot :)
  17. Jul 23, 2017 at 2:57 PM
    #97
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Meh. With the right coils you won't notice. Not sure you'd notice if it were stock. Or the 1/4" spacer would deal w/ it anyway.
  18. Jul 23, 2017 at 3:02 PM
    #98
    Tacomamike mike
    Michael
    I know :) I just had a post a few above I was just kidding !!!
  19. Jul 23, 2017 at 3:06 PM
    #99
    Joe23
    Not even just for weight, would just rather not have them there. Besides I sold the twin and got enough money to buy a new viair that meets my needs with money left over for other stuff. Twin air isn't needed unless filling 35s and or running tools and lockers like I did on my Jeep when I had it. Not needed anymore.
    cblow5 and YDCtaco like this.
  20. Jul 23, 2017 at 3:13 PM
    #100
    Tacomamike mike
    Michael
    Jeep yep got one on this too !!! :) and its balanced alright :) lolimage.jpg
