Building a 2GR-FKS for max power and reliability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMcCade, Sep 5, 2022.
  1. Sep 26, 2022 at 9:56 PM
    #121
    BMcCade
    BMcCade [OP] Well-Known Member
    Buck
    16’ Tacoma Dbl Cab
    King shocks all four corners C4-Fab 1st Gen Overland front bumper Baja Designs light bar & fog lights Home fab headache rack
    Looks like piston upgrades are available……Wonder if anybody else on here running a supercharger upgraded their pistons & rods ??
  2. Sep 26, 2022 at 9:59 PM
    #122
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    auskip07 likes this.
  3. Sep 26, 2022 at 10:00 PM
    #123
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    So would buying a new set of heads straight from Toyota be the answer to not having them rebuilt/decked?
  4. Sep 26, 2022 at 10:02 PM
    #124
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    theres no reason not to deck them. just be sure to run thicker gaskets to make up for it. new heads from toyota are BARE. they only have valve guides installed. you even have to hammer in the spark plug tubes. its not so cheap
  5. Sep 26, 2022 at 10:31 PM
    #125
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    even if I use a gasket to make up the difference, If Toyota says “don’t deck the heads” Would I not be better off in the long run going through the hassle of having new heads built & installed, Instead of decked & rebuilt….
    I’m just trying to do it right the first time, Already going to be into this build about 20K After the supercharger edition.
    In for a penny in for a pound
    :spending:
  6. Sep 27, 2022 at 4:43 AM
    #126
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I have not picked out pistons yet, but do have a set of H beam connecting rods inbound. They were designed and produced for a supercharged Lotus Evora project. If they look suitable, which I expect they will, I'll share pics and info.
  7. Sep 27, 2022 at 5:56 AM
    #127
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    By all means, please do!
  8. Sep 27, 2022 at 10:38 AM
    #128
    Empty_Lord
    Dan
    The. To do it right yes, replace. UNLESS the heads don’t need to be decked. They usually don’t unless it overheated
  9. Sep 27, 2022 at 11:08 AM
    #129
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I have to wonder again if these kinds of low mile failures have been observed on the 2GR-FE in Camrys, Avalons, etc., or are they particular to the FKS?
    It seems like the 3.5 has been a superstar of reliability in Camrys and the like so I was surprised to see all these engine failure threads. Maybe the extra weight of the truck chassis negatively impacts the reliability?
  10. Sep 27, 2022 at 12:06 PM
    #130
    Empty_Lord
    Dan
    Fks failures are rare. Fe is super rare. All the ones I’ve replaced have been due to drowning.
    The drain back issues plague the trucks. They took a fwd design and didn’t change how draining in the head worked. So steep inclines are letting these things starve for oil
    SR-71A and Ozark_RegCab[QUOTED] like this.
  11. Sep 27, 2022 at 12:19 PM
    #131
    saint277
    saint277 Vigilo Confido
    Due you mean will overfilling the engine with 2 extra quarts of oil cause failures in 2gr-fe engines? I'll bet yes, but I'm not going to try and test it out with mine.
  12. Sep 27, 2022 at 12:20 PM
    #132
    Empty_Lord
    Dan
    Overfilling loves to blow out the rear main seals. But I’ve never seen an engine failure from it yet.
    And we see a lot of 1-2quart over filled trucks from jiffylube
    Ozark_RegCab likes this.
  13. Sep 27, 2022 at 12:36 PM
    #133
    tstack22
    tstack22 Well-Known Member
    Arizona
    '22 TRD-OR 6MT
    Fewer people online to complaint about engine failures in the first 85k miles, so that means there were fewer engine failures, and current owners all have engines that didn't have a defect and survived, ergo its more reliable.
    Ozark_RegCab[QUOTED] likes this.
  14. Sep 27, 2022 at 5:36 PM
    #134
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    So is there any viable solution or remedies you can do to make sure the heads not drowning in oil and starving the pistons???
  15. Sep 27, 2022 at 5:41 PM
    #135
    saint277
    Not really an issue unless your planning to do some serious offroading. The issue isn't that pistons starve the problem is oil getting sucked into the pcv valve when the head fills, that oil gets sucked into the intake than into the cylinder which hydrolocks the engine. A catch can solves this issue you just need to make sure its empty when offroading a severe angles.
  16. Sep 27, 2022 at 6:13 PM
    #136
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    That’s a big 10/4
    Catch can was one of the first things I ordered for the new build :bananadance:
  17. Sep 27, 2022 at 6:14 PM
    #137
    Jowett
    Brian
    North Adams, MA
    BassAckwards and SR-71A like this.
  18. Sep 27, 2022 at 6:17 PM
    #138
    saint277
    Jowett[QUOTED] likes this.
  19. Sep 27, 2022 at 6:34 PM
    #139
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
    and I casually thank him IMMENSELY!!!!
    Thank you
    thank you
    thank you
    thank you
    thank you!!!
  20. Sep 27, 2022 at 6:35 PM
    #140
    BMcCade
    Buck
    16’ Tacoma Dbl Cab
