Building a digital inclinometer
Discussion in 'CameronTech' started by Cannikin, Sep 18, 2013.
What display color do you prefer?
Poll closed Dec 8, 2013.
  1. White on black
    23.5%
  2. Yellow on blue
    0.9%
  3. Red on black
    33.0%
  4. Black on green
    7.0%
  5. OLED Blue on black
    32.2%
  6. OLED Yellow on black
    3.5%
  1. Dec 14, 2013 at 7:03 PM
    #301
    Knuckles
    Knuckles Well-Known Member
    Jamie
    Alberta and beyond
    '14 TRD Sport
    TRD blower, ARB winch bumper, XRC8 winch, OME 886/Dakar, pure sine wave 1000W Inverter, hood w/NO scoop.
    Sold...I'll preorder now if I can. Just shoot me details on how to get it happening. I tried your online store but it says "sold out" (I expected that though).
    Funny, I did a google search for "compass temperature inclinometer tacoma"...first time google found exactly what I want in one try :)
  2. Dec 14, 2013 at 7:04 PM
    #302
    Knuckles
    Jamie
    Alberta and beyond
    '14 TRD Sport
    Oh, and definitely rep's for you OP
  3. Dec 20, 2013 at 10:24 AM
    #303
    Cannikin
    Cannikin [OP] Well-Known Member Vendor
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Well, good news and bad news.
    The good news is that the circuit boards finally came!
    The bad news is that there's a problem on them. :( Two of the wires that come from the navigation switch run into two of the holes from the timing chip. I double checked the damn circuit board diagram a dozen times before send them off to be printed but I missed it. I'm pretty bummed. :( Every time you use the nav switch it resets the board or goes blank completely because it screws up the timing going into the main chip.
    I'm going to try a little hack by actually cutting the lead where it touches the timing pads and see if I can disconnect the two. If that works then we're back in business and you guys can start ordering these (I've got everything I need for 25 total in various screen colors). If you order the parts kit then I'll have the timing chip pre-soldered so I can cut those leads. If you get the pre-assembled version you'll never know the difference.
    I ordered a small batch of new boards with the leads in the correct position. Small batches usually take 10 days or so. But if this hack works I won't have to wait for those to come in.
    Sorry about this guys and thanks for hanging in there!
  4. Dec 20, 2013 at 3:11 PM
    #304
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Ouch! Well I hope that hack works for you Rob!
    I think these dudes are in for a real treat!
  5. Jan 1, 2014 at 11:52 AM
    #305
    TacomaN8
    TacomaN8 Well-Known Member
    Nate
    tbd
    It would be a happier 2014 if there was an update on this product... jk...
    I hope it's available soon
  6. Jan 1, 2014 at 1:20 PM
    #306
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I too am waiting to get one for my Tundra. I think this project is incredible....
  7. Jan 1, 2014 at 6:48 PM
    #307
    whiskeytango0311
    whiskeytango0311 Former Dispatcher of Freedom's Enemies
    Texas
    2014 TRD OR DCSB 6MT
    I'm in. Excellent job, sir.
  8. Jan 1, 2014 at 7:48 PM
    #308
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Too cool to not have one, I'm in.
  9. Jan 5, 2014 at 10:45 AM
    #309
    tweeek
    tweeek Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    Would love to have a voltage readout here. Would pay much more to have the ability to read battery voltage, and dual battery voltage if I run + from my seco d battery to a second terminal. My desired setup for dual batteries is a Bluesea ACR which has no monitoring, and this would be much cleaner than a dash mount.
  10. Jan 5, 2014 at 2:18 PM
    #310
    TacomaN8
    Nate
    tbd
    This is a stand alone unit with no plugins to read battery voltage.
    Unless of course the OP wanted to add bluetooth capability to it. Then it could be paired with a obd2 bluetooth to readout the cars vitals for display. This would require significantly increasing the size of this unit to be able to diplay not only the stand alone features (pitch, roll, altitude, etc... being offered with this unit + the torque app screen display, BUT this would be one kick ass stand alone unit!
    What do you say Cann? Make a larger screen unit with two built in dedicated displays (1 dedicated to display the stand alone features of this product and 1 dedicated to display the torque app) capable of bluetooth to accept the torque app data received from the obd2 bluetooth plugin?
    (hey a guy can dream, right? ... version 3.0.... )
  11. Jan 5, 2014 at 2:23 PM
    #311
    tweeek
    Victoria, BC
    I need voltage monitoring for two seperate batteries while ignition is off. Bluetooth would only show voltage of starter battery that the cpu sees.
    I understand there would need to be a seperate sensor board to accept + from each battery.
  12. Jan 5, 2014 at 2:26 PM
    #312
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    could always just use the IBS system....
  13. Jan 5, 2014 at 2:32 PM
    #313
    tweeek
    Victoria, BC
    Agreed. I looked at this. My reasoning for the Bluesea is that it is 1/2 the cost, has a flush mount overide button for the dash instead of a bulky surface mount controller. Also a manual overide on the unit itself. I see it as a cleaner install, but both would get the same job done. Just preference I guess. I do appreciate IBS' s built in voltage monitoring though.
  14. Jan 5, 2014 at 2:35 PM
    #314
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Subbing because.... this is awesome.
    I'm sure it's been asked but, any chance of doing a matching orange O-LED screen?
  15. Jan 5, 2014 at 2:50 PM
    #315
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    go check out the wealth of knowledge of Dual battery Systems on Ih8mud.com , not saying this is a good place to start but the mud scene is a little more grown in that aspect
  16. Jan 6, 2014 at 9:13 AM
    #316
    Crusher69
    Crusher69 Well-Known Member
    Sean
    Denver
    '05 Built
    dual battery tray is only way to go dad ust to have it in his old f150 shorty with a wench and kc lites on the rollbar haha it was sweet you shoulda seen it everthing else is just waist of time lol but something is always better than nothing they dont make im like the ust too haha
  17. Jan 9, 2014 at 4:03 PM
    #317
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Update!!
    So I got a new mini-batch of boards and they're looking good, finally. I just ordered a bigger run of those and should have them in two weeks. Once those come in these babies are going on sale come hell or high water.
    And not that it helps anyone yet, but I just finished the assembly instructions for those that get the parts kit: http://store.camerontech.io/blogs/news/11441929-offroad-cpu-assembly-instructions
    Now I have to scroll up and see some of these ideas about battery voltage and reading the OBDII!!
  18. Jan 9, 2014 at 4:04 PM
    #318
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    There's no pure orange OLED screen that I've seen...yellow is as close as it gets, sorry! You may be able to each and put some kid of orange cellophane sheet over the screen to tint it a bit...
  19. Jan 9, 2014 at 4:06 PM
    #319
    Cannikin
    Rob
    San Marcos, CA
    2012 TRD Offroad
    Oh geez, I didn't even know they made bluetooth interfaces to the OBDII system! Anyone have a link? I'll look into it...
  20. Jan 9, 2014 at 4:18 PM
    #320
    emelianenkov
    Alex
    NORTH POLE
    Glad the boards finally came out ok!
    Looking forward to the latest update to try to figure out the squirrelly number readout
