Building a lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colecooper28, May 19, 2020.
  1. May 19, 2020 at 6:14 PM
    Colecooper28
    Colecooper28 [OP] Member
    Cole
    2018 Tacoma sport short bed
    I’m trying to piece together a 3in lift for. 3rd gen, looking for suggestions and parts I need that I might not be aware of?
  2. May 19, 2020 at 6:20 PM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Rear brake line spacer or lines. Rear leaf shims. Front sway bar relocate brackets. Carrier bearing drop bracket. ECGS bushing and removal tool, UCAs. Axle nut socket. You may not need all of that but look into it.
  3. May 19, 2020 at 6:23 PM
    Pilsner
    18 TRDOR
    I went Bilstein 6112 front, 5160 rear with OME Dakar medium leaf pack. Leaf pack requires bushing packs. I really like it so far. If funds allow, look at Kings or ADS, but I felt those Bilsteins were the best value for me and what I do off and on road.
    71tattooguy likes this.
  4. May 19, 2020 at 6:34 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Depends, are you 2 or 4 wheel drive?
    Do you want to do spacers, high end coil-overs, or something in between for the front? Do you want to do blocks, add a leafs, or full leaf pack replacement in the rear?
    what are your plans for the truck? Are you looking for performance? Do you just want the look? Or are you trying to copy some overlander you saw on Instagram?
  5. May 19, 2020 at 6:40 PM
    Colecooper28
    Cole
    How’s the ride with the bilsteins.. I’ve heard bad and good things?
  6. May 19, 2020 at 6:42 PM
    jmauvais
    NorCal
    ...stuff
    i haven’t used 6112s, but I was told and I have seen a lot of people saying that the ride is very harsh once you get up towards the top perches. The lower perches are a great ride though.
  7. May 19, 2020 at 6:43 PM
    Pilsner
    18 TRDOR
    I like it. Much better on road manners than a stock OR and takes washboard and bumps a lot better on unmaintained roads. Haven't made it to serious off road yet. Got it done 2 weeks ago.
  8. May 19, 2020 at 6:44 PM
    Colecooper28
    Cole
    I have a 4x4.. I don’t want to do spacers.. I just like the loo right now . I used to off-road my Jeep quite a bit but since I got the truck have it had time. So really I guess in between more casual off-roading then anything else.
  9. May 19, 2020 at 6:45 PM
    Pilsner
    18 TRDOR
    I'm on 5/6 on mine and it's softer on bumps than stock, but doesn't dip and roll like it used to. I found it much less harsh.
    Edit: I do have a hidden which mount and armor/ sliders though, so I'm heavier than stock fwiw.
  10. May 19, 2020 at 6:45 PM
    SpeySquatch
    2016 TRD OR DCSB
    The CB drop should not be needed with shims. The main driveline out of the Tcase should be as straight and true as possible. The shims correct the working angles of the second driveline pinion with the rear axle
    Colecooper28[OP] likes this.
  11. May 19, 2020 at 6:49 PM
    jmauvais
    NorCal
    ...stuff
    look into Bilstein 5100s with OME coils. You can do an add a leaf for the rear.
    since you have 4x4, keep the lift under 3”, more like 2.5-2.75” to maintain your CV angles. Prepare for the need for upper control arms for your alignment, it’s hit or miss, and an expensive add on. You can do an add a leaf for the rear, or a block to get the lift. Most people aim for about 1” less lift in the rear to level the truck. Also, do not get a drop bracket lift as you will have to cut out a cross member, the drop brackets are not necessary if you keep to the guidelines I explained.
    Check out headstrong off-road. They are active in this forum and their website will have all of the information you need to figure out your lift. They will also answer any questions you have
  12. May 19, 2020 at 6:50 PM
    Pilsner
    18 TRDOR
    Agree. I used 2.5* shims only and my angles are good. Also didn't use diff drop or sway drop. Probably taking sway off though.
    SpeySquatch[QUOTED] likes this.
  13. May 19, 2020 at 6:52 PM
    jmauvais
    NorCal
    ...stuff
    you have a lot of extra weight to help. I wanted to get the 6112s but I didn’t want the harshness with close to stock weight.
  14. May 19, 2020 at 7:04 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    So would the 6112’s be a bad choice for 1-1.5” lift with only 225lbs of slider armor? This is a 95% daily driver. I’m looking for a quality lift that’ll take care of some of the Taco roll on the road as well as the nose dive. And as we all know, and extra inch or so never hurts. :rofl:
    AKGSD likes this.
  15. May 19, 2020 at 7:06 PM
    jmauvais
    NorCal
    ...stuff
    not sure about those numbers, but fox 2.0s would probably be a better option for a few more bucks
