Building a work truck
Discussion in 'New Members' started by mattboris, Feb 1, 2009.
  1. Feb 1, 2009 at 8:37 PM
    mattboris
    mattboris [OP] Member
    alberta canada
    '13 Taco double cab
    Chopped antana, bed extender, soft tonneau cover, fog lites anytime mod, go rhino side tubes, 1.25" spidertrax wheel spacers, bike fork clamp home made for rail system, TRD cue ball shift knob, chopped mud claps, HID headlites 6000k, 265/70R17 Duratracs, 1.5" strut spacer, 1" block
    as i am new to this forum, i thought I'd share my plans for my truck. Rather then for pleasure, this truck will be for work. It is a 2009 dbl cab TRD, with the six speed and dressed in dark grey. My job as a logger, has me covering up to 200km a day on gravel roads, packing 85 gal of diesel for the equipment, and dodging tank trucks and loaded log trucks at 85km/h. This truck is the best so far that i've run out there, and i've driven every domestic on the road.
    Currently Im getting a custom slip tank made (to make the most of the short box), have a small lift on order to help stuff a better tire then OEM under it (285/70r17 open country mt) and like most, have a few more pages of planed mods. I look forward to keeping all up to date on how the latest bush rig is built and how well it survives.
    matt
  2. Feb 1, 2009 at 8:54 PM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    Cool. Get some springs. Mine bottoms out with 1200 lbs of feed.
    What is you choice of chain saws?
  3. Feb 1, 2009 at 9:09 PM
    mattboris
    alberta canada
    '13 Taco double cab
    what do you recommend for springs? chain saw? nope, buncher. John Deere 853, cut around 3200 trees in 10 hours. gotta pack fuel, tools, maintance things. whats the deal with 5100's that everyone talk about?
  4. Feb 1, 2009 at 9:13 PM
    JustSomeGuy
    JustSomeGuy Active Member
    North Cascades, Washington State
    08 Tacoma Reg Cab 4x4 2.7
    2008 Toyota Tacoma Regular Cab 4x4 2.7L 5sp manual, A.R.E. MX Series Canopy, Shrockworks Front Winch Bumper with Center Hoop and Headlight Gaurds, C.B.I. Offroad Fabrication Custom Rear Bumper with Tire Carrier, Pro Comp Xtreme Alloy Series 7089 Rims, Pro Comp All Terrain Tires 265/75/16, Sway A Way 2.5" Coil Over Front Kit, Sway A Way 2.0" Rear Shock Kit, Camburg 1 1/4" Uni Ball Upper A-Arms, Differential Drop Kit, Wheeler's 1.5" Add A Leaf Kit, K&N Aircharger 63 Series Cold Air Intake, PIAA 510 Series Ion Crystal Yellow Fog Lights, PIAA 520 ATP All Terrain Pattern Driving Lights, Toyota Tacoma Bed Mat, Toyota Tacoma Cargo Cross Bars, Cargo Basket, Husky Custom Molded Floor Liners, Cover King Custom Ultratough Ballistic Seat Covers. Hi-Lift All-Cast Jack, Quick Fist Tool Mounts
    Nice to meet you. I'm building mine for work also. I'm a Professional Faller on wildland fires and do some climbing and logging off of fires so I'm making some suspension mods to handle the fire/logging roads, beefier bumpers, etc... and fixing up the bed to hold all my falling/fire gear. I'll be posting some pictures in a month or so, just waiting on the bumpers.
  5. Feb 1, 2009 at 9:13 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Welcome!
  6. Feb 1, 2009 at 9:21 PM
    40204ever
    Caldwell, TX
  7. Feb 2, 2009 at 4:26 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Welcome to TW :wave:
  8. Feb 2, 2009 at 4:51 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Welcome to TW!!:)
  9. Feb 13, 2011 at 3:18 PM
    DayStars
    DayStars Well-Known Member
    benn
    Edmonton
    07 Tacoma TDR 6spd DCSB
    Matt, this post was from a while back.... how is ur truck holdin up?
    I just picked up an '07 double cab, 6spd, TRD, with the intention of making it my electrical work truck. I'm thinking that i shoulda went with a long box, but don't think they are available with the 6spd.?.
    Did you have that custom slip tank built? Who did it and how much? I'm thinkin that i might have to have any tool boxes that i need for the truck custom made.
  10. Feb 13, 2011 at 8:25 PM
    mattboris
    alberta canada
    '13 Taco double cab
    haha, gotta be honest, i sold the truck a little over a year ago. But i did get a tank made (holds 365L) and it was a great work truck. and your right the long box is not avalible with a 6 speed. my buddy is a welder, and he had the tank bent up in edmonton, then he welded it. think final price ( he charged full rate since its his company/job, and was my company expense) like 750. the only issue with the taco is the soft leafs (even though canadians got the factory hd springs without complants required). i did a small lift on it, and it helped, but if i had to do it again i wouldn't do a spacer lift (fuck alignment unless you do control arms to correct camber) but i would go with monroe air shocks. they're basicly a shock with a built in air bag that can accomidate extra payload. i have them on my lowered canyon and they rock. no load, dump the air, but load it up and pump them up to a max of 150psi or about an extra 1000lbs. as far as custom boxes i'd say its totally worth it since your space is at a primium, but watch what they wanna charge and shop around. more drawers doors and shelves add labour which means $$$$. if you can draw up what you want its easier to get what you want and get quotes faster. Not sure where you live but i know you can get custom aluminum anything through cc industries outta prince george. i worked at raven truck accessories and i did allot of custom shit for clients. hope this helps
    latta
  11. Feb 13, 2011 at 8:41 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Let me get this straight..
    The OP makes 2 posts, 2 years ago. Then, someone revives the thread a year after he has already sold the truck with a question for the OP and he answers. Nice work!
  12. Feb 13, 2011 at 9:03 PM
    mattboris
    alberta canada
    '13 Taco double cab
    just wanna help. people helping people? and sorry whats op??
  13. Feb 13, 2011 at 9:05 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    There's trees to log in Alberta ?
  14. Feb 13, 2011 at 9:08 PM
    mattboris
    alberta canada
    '13 Taco double cab
    and very little bug wood too. well so far...
  15. Feb 13, 2011 at 9:11 PM
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    Original Poster (I believe). I thought it was really cool that you came back to help even though you had sold your truck a year ago. I have been to Canada several times (making a trip to Banff next summer). Canadians are always friendly people. I was just making an observation.
  16. Feb 13, 2011 at 9:12 PM
    OZ-T
    Peter North
    British Columbia
    I hope for your sake it stays that way , we've been decimated .
  17. Feb 13, 2011 at 9:16 PM
    mattboris
    alberta canada
    '13 Taco double cab
    hey i'm a car guy with way too much useless/ful information, just happy to share. logging here has go to shit, hence why im a hd mechanic at a coal mine, but will go back logging when its worth while. and just for the few people who are reading this, i will get another tacoma, loved the truck, just expensive.
  18. Feb 13, 2011 at 9:17 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Don't make me take pictures. We're no BC, but there are places where it is physically impossible to walk cause the trees are so thick.
    Where in Alberta are you from Matt? Where you logging out of?
    I'm hiding in Cowtown and been pretty much everywhere in the best province in Canada. :D
  19. Feb 13, 2011 at 9:17 PM
    OZ-T
    Peter North
    British Columbia
    Where in Alberta are you ?
  20. Feb 13, 2011 at 9:18 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Is there an echo in here?
