building an ar 15
Discussion in 'Guns & Hunting' started by mkerros, Sep 23, 2010.
  1. Sep 26, 2010 at 8:38 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    It sure is.
  2. Sep 26, 2010 at 8:59 AM
    m3zy6
    m3zy6 Well-Known Member
    Reno, NV
    '17 TRDSport AC 6spd 4x4
    Check out the link I gave you to know what "mil-spec" means in this instance. It has nothing to do with lowest bidder, or civilian vs. military, even though it is taken from the military standards.
    If you absolutely have to have gas-piston, then I would suggest skipping an AR and going with a platform that has been designed from the ground up that way. For a little more money than a LWRC you could get a SCAR or an ACR.
    If you absolutely have to have a GP AR, then I would definitely not get a piston conversion. Adding a conversion to a bolt that isn't designed for it is asking for trouble. Check out the uppers from Addax Tactical - http://www.adxtactical.com/store/pc/viewCategories.asp?idCategory=137 I've read nothing but good things about them, and the price is right.
  3. Sep 26, 2010 at 9:09 AM
    m3zy6
    Reno, NV
    x2 There you go, a GP designed rifle for less than you could build a GP AR. Hard to go wrong at that price.
  4. Sep 26, 2010 at 10:32 PM
    mkerros
    mkerros [OP] Well-Known Member
    jacksonville florida
    06 d/cab long bed
    well the thing with the gp conversion kits is that they come with new bolt assemblys. and it all depends on how much i have in the bank cause i am also looking at geting a scar maybe. but it all depends on were im at with money when i get home.
