Building first home
Discussion in 'Off-Topic Discussion' started by Tacomada, Apr 4, 2012.
  1. Apr 4, 2012 at 11:31 AM
    Tacomada
    Tacomada [OP] Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Just closed purchase on a piece of land and planning to build my first home in the very near future. Since TW is full of so many great minds I figured i'd post up to see what everyone thinks about home plans.
    This is the plan we've picked out.
    http://www.westhomeplanners.com/House-Plan-1479.html
    We are going to leave the basement unfinished, just what's required for local code.
    As far as construction, I am planning on using independent concrete forms for the foundation and walls to the roof line.
    There have to be a lot of home owners on here so any thoughts/suggestions. What would you change, where would you spend extra and where would you save?
    Am I off my rocker for building my first house instead of buying?
  2. Apr 4, 2012 at 11:34 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This will be fun to follow
  3. Apr 4, 2012 at 11:37 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Want to head up north and build it for me?
  4. Apr 4, 2012 at 11:37 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    insulated concrete forms. :cool:
    I would suggest staying away from internet plans. they are usually very vague, full of mistakes and don't contain the correct information for your area. you would be better off to show that link to someone local who does drafting work and have them make up plans that will meet your local codes and requirements.
  5. Apr 4, 2012 at 11:38 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    What are you planning for flooring? I started out with a pretty small Cape (24'x34') and I will offer that all tiling we did we placed at a 45-degree angle. Really makes a smaller sized room look bigger. And it looks a little less industrial.
  6. Apr 4, 2012 at 11:43 AM
    OZ-T
    Peter North
    British Columbia
    Where are you ?
  7. Apr 4, 2012 at 11:44 AM
    gusher
    Greg
    Hudson NH
    Also, if you can, I would pay whatever it cost (of course within reason) for at least a full 8' ceiling height in basement. if you could do 9' you'll be happy you did because there's nothing worse than a basement ceiling that's scraping the top of your head. Been in so many that, by the time you drop a ceiling to clear all the pipes & duct work, you don't have any ceiling height.
    Also, LVL -vs- 2x10 joists with lally coulmns is worth whatever it costs. I put a 20x22' addition on and I think it was $600-800 to "upgrade" from having 2x10" joists with a lally column right in the middle of the room (read that right in the middle of my POOL TABLE) to LVL beams that can clear-span that distance no problem. Easily the best $$$ I've spent in a while.
  8. Apr 4, 2012 at 11:45 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Thanks MT, definitely insulated not independent... Logix is the brand im looking at. I've heard good things, and stayed in a couple houses for a month that were constructed using the forms. Definitely quiet, and nice constant temperature.
    The builders we have giving us quotes are going to deal with modifying the plans. Walls need to be thicker and trusses have to be engineered for our local snow load as well...
  9. Apr 4, 2012 at 11:46 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    We are thinking wood and tile. I like the angle idea, not only makes it look bigger, but probably a little less 'spec' home ish.
  10. Apr 4, 2012 at 11:49 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Terrace... up on the north coast.
    Yes! The lot has a little slope to it so we can have the basement walk out to the back yard. Builder gave the same advice on the joists... I have a pool table to put down there as well so definitely dont want any beams hanging down.
  11. Apr 4, 2012 at 11:54 AM
    OZ-T
    Peter North
    British Columbia
    oh , Ripbum
    My wife is from there , my stonemason too .
    So , I assume your area requires rainscreen too , being on the coast ?
    Have you considered radiant thin slab over framing heat or exterior insulation over your framing ?
  12. Apr 4, 2012 at 12:07 PM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Sounds like you'd enjoy a trip up. Maybe fit in some fishing!
    Radiant thins lab over framing. That is on floor eating correct? We were thinking of putting a heat pump in, and I think that works along with it? Could be confusing ideas though?
    The icf forms have insulation on the interior and exterior built in. Part of why we are leaning that way, suppose to e more efficient as far as heating and cooling. Not that we need much cooling up here.
  13. Apr 4, 2012 at 12:11 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Blown in insulation. Insulate, insulate, insulate.
  14. Apr 4, 2012 at 12:12 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Toytec (Eibach) coils with bilstein 5100 shocks and Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Wheelers Super Bumps,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I had my house built in 2007. It's nice get to pick everything from flooring and fixtures to the lay out of the house and see it all come together. It gets stressful at time but the pay off is a the end when everything is done congratulations and good luck.
  15. Apr 4, 2012 at 12:19 PM
    OZ-T
    Peter North
    British Columbia
    Radiant thin slab over framing is basically 1 1/2" of concrete poured over standard framing with tubes containing hot water ,
    You use the same type of tubes in the slab in the basement .
    You can get Air to Water heat pumps now specifically designed for hydronic heating systems .
    This heating system needs to be figured out early in the planning process as it has to be allowed for at the framing stage .
    I was reffering to foam insulation over the exterior of the framing system , or are you considerring ICF's for your exterior walls to the ceiling line ?
  16. Apr 4, 2012 at 12:20 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    I wouldn't use masonite siding like that elev. shows....
  17. Apr 4, 2012 at 12:21 PM
    OZ-T
    Peter North
    British Columbia
    We use wood where I am :)
  18. Apr 4, 2012 at 12:24 PM
    xJuice
    Josh
    North DFW
    07 DCSB Sport 2wd
    Most of the houses around here will use Hardie or Certainteed fiber cement siding. Some of the $money$ houses I bet use wood though.
  19. Apr 4, 2012 at 12:26 PM
    OZ-T
    Peter North
    British Columbia
    Wood is cheap here , and we don't have extreme heat issues like in Texas
  20. Apr 4, 2012 at 12:27 PM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Ya I'm planning on icf right tithe ceiling.
    Siding will be either hardyboard (or similar) or cedar. I have a friend that mills it. Just have to decide if the extra maintenance is worth it.
