building my lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stcktnkid, Nov 6, 2015.
  1. Nov 6, 2015 at 1:49 PM
    stcktnkid
    stcktnkid [OP] Well-Known Member
    New Jersey
    14 Tacoma DCLB 4x4
    Ok so I traded in my 2014 Tacoma for a 16DCSB Sport. In my '14 I had bilstein 5100 set at 1.75 in the front. I am trying to understand the differences between the 14 and 16 now. I read that someone said we can't set the 5100's at 1.75 in the new taco or it would need UCA. So my option is to just set it at .85 and call it a day or set it at 1.75 or higher?? and get UCA. Or, would going higher then 1.75 be too much on the current spring?
    My thought was Bilstein front shock set at 1.75" with
    rear bilstein shocks 5125 (for 2" lift)
    Shocks $330
    Light Racing (Toy tec) UCA $450
    Toytec 2" block $100 or Toytec AAL 1.5-2" lift for $85
    Do I need Diff Drop kit?
    Do I need longer Break Lines?
    Do I need sway bar relocates?
    Thoughts?
    proven21 likes this.
  2. Nov 6, 2015 at 1:56 PM
    be_unscared
    be_unscared Wardaddy
    Brendan
    So Cal
    2016 TRD Sport 4X4
  3. Nov 6, 2015 at 2:13 PM
    stcktnkid
    New Jersey
    14 Tacoma DCLB 4x4
    Ok, I wasn't sure if anything changed because I didn't need UCA for 1.75" bilsteins but now we do?
  4. Nov 6, 2015 at 4:04 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Rock is correct, you can get away with it and be within safe operating specs, but to be within factory alignment specs across the board aftermarket UCAs will be required.
  5. Nov 6, 2015 at 4:07 PM
    stcktnkid
    New Jersey
    14 Tacoma DCLB 4x4
    and you are also going off 2015 specs right? do you think the specs could be different for the 2016 and maybe you actually are within spec?
  6. Nov 6, 2015 at 4:12 PM
    Dean724
    Upland, CA
    Yes, this was with the 12-15 specs.
    That's actually a really good question and not one many can answer at this point. I asked the service guy the same thing and from the conversations he had the specs should be nearly identical from 2015, but not sure I can trust that info with the coil change in the new truck or if that makes a difference. I do know I'm not within factory spec just by the looking at my camber. You can visually still see the slightly positive lean in the wheel and my camber bolts are maxed out. Hopefully in the next month or two Toyota will start updating these factory specs to their service centers.
  7. Nov 6, 2015 at 4:15 PM
    stcktnkid
    New Jersey
    14 Tacoma DCLB 4x4
    Yea I'm just thinking it would be a shame if you actually are within spec and spend the money on buying and installing new UCA if it wasnt actually needed.
  8. Nov 27, 2015 at 3:34 PM
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Is the rear bilstein shocks 5125 (for 2" lift) the correct shock to get with say a 1.5" wheelers 3 leaf progressive as opposed to billstein 5100's?
  9. Nov 27, 2015 at 3:55 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    it was mentioned in the pinned thread about lifting a new tacoma that the UCA are recommended for a 2inch lift
