Building Sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monsterkx2fiddy, Jan 3, 2013.
  1. Jan 3, 2013 at 5:57 PM
    monsterkx2fiddy
    monsterkx2fiddy [OP] Well-Known Member
    Birthplace of Davy Crockett
    I have a few questions for you guys.
    A local guy builds sliders for all of his little toys. He told me he could build me a pair.
    So how/where are you guys mounting and building your BOLT ON sliders?
    How far from the door jams do I need?
  2. Apr 23, 2013 at 6:24 AM
    mightytacoman
    mightytacoman Well-Known Member
    kelby
    Moving every 3 months
    Heavily upgraded
    Magnuson supercharger, Walbro 255 fuel pump. URD supergrip pulley 2.825", urd O2 sensor calibrator, Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluid swap, Afe Stage II with pro-dry filter, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, Magnaflow headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 2- 20" light bars, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. Optima yellow top, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Hey there, looks like your question fell through the cracks this time. I am just about to put some on my truck, (getting them powder coated now). I left an inch of room between the door and the top of the slider. that way there is room for flex in them and also if dirt or ice or whetever builds up on them- my door will still open and not scrape the bottom of it. As for mounting them, i mounted directly to the frame. hope that helps
  3. Jun 20, 2013 at 9:22 PM
    Wickedwagens
    Wickedwagens Well-Known Member
    Mark
    Carson City NV
    07 Dbl Cab LB
    3" lift, 285/70/R17 BFG A/T
    Have any pictures?
