Building Stairs....HELP
Discussion in 'Garage / Workshop' started by kris77, May 31, 2013.
  1. May 31, 2013 at 1:29 PM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    Building stairs off my front porch.
    30" to the ground.
    I've figured out i'll need 4 steps at 7.5" rise each. 10" run. Top step even with the porch.
    I just use a regular square right to lay out my stringers?
    Put a mark at 7.5 on the thin side and 10 on the thick side and line it up and mark my lines right?
    Sorta like this...Top left corner...
  2. Jun 3, 2013 at 12:45 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I believe so..but after doing a set of porch stairs with a friend..we both agreed perfect stairs should be left for a professional stair maker XD
  3. Jun 3, 2013 at 1:08 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes , you use a framing square and yes , put one side on 7 1/2" ( rise ) and one side on 10" ( run )
    After you cut those out you need to reduce the bottom rise by the thickness of the boards you are going to put on the stringers for steps
    For example , if you are going to use standard 2x material , which is 1 1/2" thick , you need to reduce your bottom rise by 1 1/2" , or to 6" in your case
