Building upper control arms
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steve97tj, Feb 20, 2012.
  1. Feb 20, 2012 at 11:19 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    I don't think it would take that much trail and error unless you were going to build an LT setup. But with a stock replacement arm your just copying the stock geometry, not building from scratch and reinventing the wheel.:)
  2. Feb 21, 2012 at 1:24 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    The hardest part is the copying and building. Probably going to take 2-4 tries maybe more to get it right. Depending on how you set up your uniball your uca could hit your coil overs at full droop or not hit its full potential. Welding the uniball cup is also challenging. This can be easily warped if you never done it before. Most uca are bent through a Cnc bender To ensure an exact bend and fit. You can do it your self off a jd2 or jmr. Also notching you want to make sure it's an exact perfect notch.
    When you lift your truck most of the time the stock uca doesn't allow you to set camber and caster properly. After market uca are made to address the problems of caster and camber allowin you to get back to a factory setting. When you build your arms you want it to add caster into your spindle for better stability. On second gens if you lift over 2.5 inches it is pretty hard to get your camber back to stock setting as well. So you got to know how much camber you want to add/take. Tc Now has a adjustable heim uca allowing to weld your lca and set your camber through the uca.
    Some times even the big guys have problems with their ucas. Older all pro ucas had a lot of alignment problem my self and other members here have experienced that. There's a few thread on here and Ttora about camburgs older arms and it's caster problems.
    I've been around suspension for a while, from track cars/ slammed cars to Offroad and lt trucks.
  3. Feb 21, 2012 at 2:03 AM
    TmecTaco79
    Adam
    Escondido,CA
    Yeah those are all good points to consider. But I think if the op builds a jig he'll be much better off. And with those heim uca's, do you have to unbolt them Everytime you wanna make an adjustment? Never really understood those. But I definitely wanna get a jd2. They're not too badly priced if you get the manual one.
  4. Feb 21, 2012 at 9:30 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    @ Steve97tj: In case there's confusion, the regular-length UCAs you plan to build now cannot be re-used in an LT setup later. For LT, UCAs and LCAs need to be 2"-6" longer, to achieve more wheel travel for the same "swing angle".
  5. Feb 21, 2012 at 9:34 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    sub'd. the high cost of UCA's have always baffled me. though i know i personally don't have the skills to make my own i have always wondered if anyone has tried it.
  6. Feb 21, 2012 at 10:17 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Have to build a jig that allows you to correct camber and caster.
    And yes you adjust by removing the upper arms. But one you get your alignment correctly you'll never have to do it again.
  7. Feb 21, 2012 at 12:02 PM
    Steve97tj
    Steve97tj [OP] Active Member
    Stephen
    Atlanta
    98 taco
    Ya thank ya. I assumed they weren't but was just curious. After looking some more i figured it out.
    My thoughts are i plan to jack my truck up this weekend maybe and take a look at it. I do plan to build a set of uppers, i guess i'd be considered mid-travel, but it may be a little bit before i have the cash to throw at the uniballs and bushings. Trying to research if there is any other option out there, i've seen the desert guys use a vertical uniball, dont know if this would have any advantages in what i'm looking to do, with a little modification of the spindle of course.
    How much extra travel do most aftermarket companys claim when using there arms? I know some like icon say they are for extended travel but i was thinking you gained some travel with any of the aftermarket arms. I cant remember off the top of my head but whats the stock travel?
    Would I need a C/O like how Icon sales there for extended travel?
    Would i be able to use a regular coilover with any advantages?
    Is there any type of strut/coil combination that would give me the same travel as the extended coilovers?
    More i look into it and think about it, LT wouldn't happen unless it was way down the road. Even if i only had to buy 1 set of custom tundra axles to use and never broke them, $800 is ridiculous and not something i'd care to add into costs. Might would consider trying to modify a set, but one project at a time.
  8. Feb 21, 2012 at 8:37 PM
    TmecTaco79
    Adam
    Escondido,CA
    Sounds like a pain if you don't get it right the first time lol. But I guess once you get it all dialed in it'd be sweet. But then again like someone mentioned you'd have to replace then after awhile right?
  9. Aug 8, 2012 at 10:12 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i know this is old but i have been thinking of making my own also, did you ever get them made?
