built 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by longboardlife1122, Aug 22, 2019.
  1. Aug 22, 2019 at 7:35 PM
    longboardlife1122
    longboardlife1122 [OP] New Member
    casey
    2006 silver tacoma base
    I'm curious to see how many people have built the 4.0 to hold higher horse power my goal is anywhere between 350-400 if you've built for higher horsepower please tell me what parts you've used (pistons,conrods,head studs, what you've tone to the trans and rear end) right now this is just an idea but if it can be done relatively easy I'd like to do it while im rebuilding my engine
  2. Aug 22, 2019 at 7:49 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Personally, I wouldn’t even try to get more horsepower out of the 4.0. The only thing I’d even consider would be a supercharger, but the prices are outrageous. You’d be better off with an engine swap to reach 350-400 horsepower as you’d sink thousands into the 4.0 platform to reach those numbers.
  3. Aug 22, 2019 at 8:04 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    @Torspd put a good thread together that includes various build specs and dyno charts https://www.tacomaworld.com/threads/1gr-fe-f-i-mods-and-dynos.465243/
    You realize he'd be ten thousand or so into a swap (unless he could do it himself...but then he likely wouldn't be asking here about building the 4.0).
    Torspd likes this.
  4. Aug 22, 2019 at 8:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    350-400whp doesn't need to be built. Just don't use nitrous. Or you will have to build it.
    Bebop likes this.
  5. Aug 22, 2019 at 8:53 PM
    ZachPrerunner
    Southeast TN
    Correct, but I’d rather spend $10k and have a platform that is known for power than a “built” 4.0 for $4-5k. To me, it’s just not worth the money to try and put more power into the existing 4.0. If you’re rebuilding it with stock components, it’s an entirely different story. Different strokes for different folks though.
