Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Apr 9, 2017 at 9:07 PM
    #1981
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Diff oil? Is your windshield molding loose?
    MTopp likes this.
  2. Apr 9, 2017 at 9:11 PM
    #1982
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Not loose that i know off
    Just replaced the rear diff fluid 600 miles ago at the cost of $64 :bananadead:
    Tractorman and MTopp like this.
  3. Apr 9, 2017 at 10:12 PM
    #1983
    AR15xAR10
  4. Apr 9, 2017 at 10:56 PM
    #1984
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    There is no reason you need a new driveshaft. Just replace them with OEM parts and it'll be as good as new. As far as pinion seal goes that isn't a ton of oil so your gears are probably fine. Also i've been driving my truck in fwd for the last 2 weeks, its weird to get used to but nothing bad has happened so you'll be fine.
    MTopp likes this.
  5. Apr 10, 2017 at 12:45 AM
    #1985
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    hmm, might want to give the sealing surface a good look and blueprint it, sounds like something is fucked and causing the seal to die early
    MTopp and ChadsPride like this.
  6. Apr 10, 2017 at 3:54 AM
    #1986
    ChadsPride
    Sponsored by TacomaWorld.com
  7. Apr 10, 2017 at 9:12 PM
    #1987
    AR15xAR10
    Ordered that complete drive shaft....
    Picking up a pinion seal tomorrow...or i might call ECGS and see if they can sell me one without a kit
  8. Apr 10, 2017 at 9:44 PM
    #1988
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Yikes
    ChadsPride likes this.
  9. Apr 11, 2017 at 3:15 AM
    #1989
    ChadsPride
  10. Apr 11, 2017 at 6:25 AM
    #1990
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I'd take the old one since it's probably fine other than the carrier/u joints and maybe needing a balance. An off-balance driveshaft could maybe cause pinion seal life to decrease.
    Also, for that hefty $575 price tag, you should've gone to a driveshaft shop and had them make a one-piece shaft. Eliminates the carrier, is stronger, and has a longer slip yoke for better extension off road.
  11. Apr 11, 2017 at 6:29 AM
    #1991
    MTopp
    05 SR5 4x4
    You've been driving with just the CV's pulling the truck? What's the top speed you've gone with that? Soft accelerations also, I assume?
    Good to know if I ever need to limp mine home, as your truck is as heavy as most tacomas will get, but you also have the upgraded LT cv's.
  12. Apr 11, 2017 at 6:55 AM
    #1992
    AR15xAR10
    Also has less ground clearance and every company that makes one for tacomas has reviews that say its great and others that say they suck...not gambling there just yet
  13. Apr 11, 2017 at 6:56 AM
    #1993
    AR15xAR10
    I wouldn't go over 40-50 with just the front diff
  14. Apr 11, 2017 at 9:15 AM
    #1994
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I've done 50mph. Friday I'll likely be doing 60-65mph for more time though.
    Yes I have chromoly cv shafts but it's always the joints that break, which aren't any different than yours.
    MTopp[QUOTED] and ChadsPride like this.
  15. Apr 11, 2017 at 10:07 AM
    #1995
    AR15xAR10
    Pinion seal ordered from ECGS
    Tractorman, ChadsPride and MTopp like this.
  16. Apr 11, 2017 at 10:08 AM
    #1996
    MTopp
    05 SR5 4x4
    Hmm good to know and didn't realize the joints were the same, they may likely even have more stress on them in your situation then than with a stock width axle shaft and suspension setup.
    They'll probably be "ok", but I'd carry a couple spares for the next offroad trip, current axles may likely have some excess/increased wear&tear on them from being used alone with the front diff to move the truck; alot more stress and force put on the entire system than was intended or designed to be.
  17. Apr 11, 2017 at 11:41 AM
    #1997
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Yeah I always keep my spare with me, mainly because if I break one it's not like I can go to Napa and get one to get me home.
  18. Apr 12, 2017 at 5:43 PM
    #1998
    AR15xAR10
    Tractorman, MTopp, 23Skidoo and 2 others like this.
  19. Apr 12, 2017 at 6:28 PM
    #1999
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Thank you!
    :cheers:
  20. Apr 12, 2017 at 8:06 PM
    #2000
    AR15xAR10
