Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Apr 16, 2017 at 12:39 PM
    #2041
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I would imagine they'll send a housing seal with it...
    I shouldn't have to do axle seals or anything else right?
    Yes, i'd say at least half of the fluid has been flung everywhere all over the underbody. :rolleyes:
    Tractorman, ChadsPride and MTopp like this.
  2. Apr 16, 2017 at 12:45 PM
    #2042
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Id use the RTV gasket. I would replace the axle seals. Its somewhat easy to damage then when removingthe axles.
  3. Apr 16, 2017 at 12:47 PM
    #2043
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I didn't need to replace axle seals, but blue RTV around the third member is a must
  4. Apr 16, 2017 at 5:47 PM
    #2044
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im getting regeared in a week. Whats this I hear about a solid spacer? @northwesttaco
    MTopp, AR15xAR10[OP] and ChadsPride like this.
  5. Apr 16, 2017 at 7:43 PM
    #2045
    AR15xAR10
    I'll ask them about it when I call them then i'll text you @fatfurious2
  6. Apr 17, 2017 at 3:17 AM
    #2046
    ChadsPride
    Sponsored by TacomaWorld.com
    Lucky dude rhyecheer
    MTopp likes this.
  7. Apr 17, 2017 at 7:15 AM
    #2047
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    A crush sleeve holds the two pinion bearings apart and sets the bearing/pinion preload. As you tighten the pinion nut it will "crush" the sleeve. Most people swap out to a solid spacer, which is a machined piece of tubing with no place to crush. Then you change its height with shims instead of the "crush" method.
    @fatfurious2
  8. Apr 17, 2017 at 7:39 AM
    #2048
    AR15xAR10
    ORDERED From ECGS:
    Tacoma 8.4 Non ELD/ T100/ Tundra 3rd
    (T100/8.4 3RD)
    ADD LOCKER: No Locker
    ADD SOLID SPACER: ADD SOLID SPACER
    Select Gear Ratio: 3.73
    Shipping Options: Send CAll TAG
    Select Core Charge: Core Charge
    Select Flange Style: Used Flange
    Select Gear Oil: No Gear Oil
    ADD Factory LIMITED SLIP Posi
  9. Apr 17, 2017 at 7:40 AM
    #2049
    ChadsPride
    mud​
    MTopp likes this.
  10. Apr 17, 2017 at 7:43 AM
    #2050
    AR15xAR10
    This is what was explained to me @fatfurious2
  11. Apr 17, 2017 at 7:44 AM
    #2051
    ChadsPride
    offroad​
    MTopp likes this.
  12. Apr 17, 2017 at 7:44 AM
    #2052
    fatfurious2
    David
    Ashburn, VA
    I thought this was $3k that you didnt have..
    MTopp and ChadsPride like this.
  13. Apr 17, 2017 at 7:45 AM
    #2053
    AR15xAR10
    1120 minus 400 core
    Tractorman, MTopp and ChadsPride like this.
  14. Apr 17, 2017 at 7:48 AM
    #2054
    ChadsPride
    Stock​
    MTopp likes this.
  15. Apr 17, 2017 at 7:57 AM
    #2055
    fatfurious2
    David
    Ashburn, VA
  16. Apr 17, 2017 at 7:57 AM
    #2056
    ChadsPride
    MTopp likes this.
  17. Apr 17, 2017 at 9:28 AM
    #2057
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Stalk
    ChadsPride[QUOTED] likes this.
  18. Apr 17, 2017 at 9:29 AM
    #2058
    ChadsPride
    Cowboyzuh
    MTopp likes this.
  19. Apr 17, 2017 at 9:30 AM
    #2059
    Noelie84
    Noel
    Wales, Maine
    Suck
    MTopp and ChadsPride[QUOTED] like this.
  20. Apr 17, 2017 at 9:31 AM
    #2060
    ChadsPride
    abuse​
    MTopp likes this.
