Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Apr 25, 2017 at 8:17 AM
    #2261
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  2. Apr 25, 2017 at 11:59 AM
    #2262
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ok keep us posted. I can't do a Friday but Saturday is not a problem.
  3. Apr 25, 2017 at 12:17 PM
    #2263
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Roger that fellas. Will inform you directly with any updates. Thank you :)
    Tractorman and Blackout14 like this.
  4. Apr 25, 2017 at 2:07 PM
    #2264
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Am I correct in assuming that you need to swap in a new diff because you nuked your stock one? If so we're in good shape because I can do that with my eyes closed at this point. :D
    The only thing I'm not well versed in is bleeding the brakes - I had Dennis @TOYTONKA help me by doing that part. :oops:
    Blackout14 and AR15xAR10[OP] like this.
  5. Apr 25, 2017 at 2:09 PM
    #2265
    AR15xAR10
    I absolutely hate bleeding brakes. Yes. I'll tag you in the instagram video. I somehow grenaded a pinion bearing.
  6. Apr 25, 2017 at 2:10 PM
    #2266
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ok. No need to even touch the brake lines. We can pull the third & leave them in place. :thumbsup:
  7. Apr 25, 2017 at 2:11 PM
    #2267
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Been riding the bike in this shit weather? :(
    Blackout14 likes this.
  8. Apr 25, 2017 at 2:13 PM
    #2268
    AR15xAR10
    I bought axle seals just in case. I some how feel my luck will be that one will fail after everything is back together, then my shoes will be totaled...which I can't really afford to rebuild the rear brakes right now.
    My understanding is that the half shafts have to come all the way out to replace the axle seals. Also that the bearings are pressed on/off so I cannot do that either.
  9. Apr 25, 2017 at 2:19 PM
    #2269
    AR15xAR10
    https://instagram.com/p/BTIMe8_gQbu/
  10. Apr 25, 2017 at 3:05 PM
    #2270
    AR15xAR10
    Thats the difference between tearing up the gears and tearing up the bearings. I just don't know how I did it
  11. Apr 25, 2017 at 3:07 PM
    #2271
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    i tore up the spider gears. drunk burnouts ftw! *professional driver on closed course*
  12. Apr 25, 2017 at 5:29 PM
    #2272
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I highly doubt we'd need to replace those seals. When I replaced my snapped drivers side shaft with a junkyard shaft I used the seal that came on it & it's fine. ;)
    AR15xAR10[QUOTED][OP] likes this.
  13. Apr 25, 2017 at 5:57 PM
    #2273
    AR15xAR10
    Hopefully I didn't ruin the splines on either half shaft
    Tractorman likes this.
  14. Apr 25, 2017 at 6:05 PM
    #2274
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Also doubtful but I can bring spares if you really want me to... :rolleyes:
  15. Apr 25, 2017 at 6:08 PM
    #2275
    AR15xAR10
    Oh no no no, we'll cross that bridge if it comes into view
  16. Apr 25, 2017 at 6:31 PM
    #2276
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'll come down in the truck & throw the spare axle in the bed. :laughing:
  17. Apr 25, 2017 at 6:33 PM
    #2277
    AR15xAR10
    I seriously shouldn't need it. I'm guessing they aren't side specific?
    Also, I just realized its not like you don't already have my full name and Address :rolleyes:
  18. Apr 25, 2017 at 6:33 PM
    #2278
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Homerstalko.
    Nedrolls and Blackout14 like this.
  19. Apr 25, 2017 at 6:34 PM
    #2279
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    They are side specific...
  20. Apr 25, 2017 at 6:35 PM
    #2280
    AR15xAR10
    No need to worry about it then. I know where I can pull a set if I absolutely have to. But they're in SC....
