Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Nov 6, 2017 at 7:00 PM
    #3261
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I just want a plate bumper so i can access stuff like that without dismantaling everything in sight lol
    ChadsPride and fatfurious2 like this.
  2. Nov 6, 2017 at 7:02 PM
    #3262
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I took the top washer out. No more hood vibrations
  3. Nov 6, 2017 at 7:03 PM
    #3263
    AR15xAR10
    I’ll eventually do the full body kit. So for now this works
    ChadsPride likes this.
  4. Nov 6, 2017 at 7:04 PM
    #3264
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Ya I wouldn’t mind having one too.
    Just not real high on my list.
    At least you know how to dismantle it easily, although it’s a total pain in the ass.
  5. Nov 6, 2017 at 7:04 PM
    #3265
    AR15xAR10
    I can have it off in two minutes now. I’ve swapped that bumper at least a half a dozen times now
    ChadsPride and 303tacoma[QUOTED] like this.
  6. Nov 6, 2017 at 7:05 PM
    #3266
    AR15xAR10
    If they weren’t so expensive, i’d already have a full hoop, aluminum plate pelfrey
    ChadsPride and 303tacoma like this.
  7. Nov 6, 2017 at 7:09 PM
    #3267
    303tacoma
    Rebecca
    I won’t even try messing with that at this point........
    Or ever:)
  8. Nov 6, 2017 at 7:47 PM
    #3268
    AR15xAR10
    Pffffft. I’ll do it for you :wink:
    303tacoma[QUOTED] and ChadsPride like this.
  9. Nov 7, 2017 at 4:13 AM
    #3269
    303tacoma
    Rebecca
    Dang too bad you’re so far away!!!
    :D
  10. Nov 7, 2017 at 6:26 AM
    #3270
    AR15xAR10
    Like i need much of an excuse to come back to Colorado :p
  11. Nov 7, 2017 at 9:52 AM
    #3271
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Just a heads up, if you do the poly cab mount bushings, be prepared for all the vibration in the universe in your cab
  12. Nov 7, 2017 at 9:56 AM
    #3272
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I don't have that. I also have the upgraded @Bonzen engine mounts, with poly bushings.
    AR15xAR10[OP] and ChadsPride like this.
  13. Nov 7, 2017 at 10:07 AM
    #3273
    AR15xAR10
    Yeah i’m not concerned about it.
    Its a truck. Its supposed to be stiff.
  14. Nov 7, 2017 at 10:08 AM
    #3274
    ChadsPride
    Sponsored by TacomaWorld.com
    Weird, I feel like my poly bushings helped the cab vibrations
    AR15xAR10[OP] and Rattletrap66 like this.
  15. Nov 7, 2017 at 10:14 AM
    #3275
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :burnrubber:
  16. Nov 7, 2017 at 10:15 AM
    #3276
    ChadsPride
    :D :cheers: :headbang:
    Rattletrap66[QUOTED] likes this.
  17. Nov 7, 2017 at 10:16 AM
    #3277
    AR15xAR10
    Rizzletrizzle sixtysizzle
  18. Nov 7, 2017 at 10:26 AM
    #3278
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    WHAT'S UP Monica
  19. Nov 7, 2017 at 10:33 AM
    #3279
    AR15xAR10
    Just chillen, killing time.
  20. Nov 7, 2017 at 1:40 PM
    #3280
    AR15xAR10
