Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Aug 28, 2018 at 5:03 PM
    #3641
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I wonder how many people have seen in and wondered...
    ChadsPride likes this.
  2. Aug 28, 2018 at 5:07 PM
    #3642
    ChadsPride
    Sponsored by TacomaWorld.com
    Somebody should cut a bottle opener in one, I dunno...could be dangerous in a couple ways lol.
  3. Aug 28, 2018 at 9:26 PM
    #3643
    AR15xAR10
    Someone does, i have seen that. But defeats the purpose of the wrinkle black powdercoat lol. It’d get chewed up
    ChadsPride[QUOTED] likes this.
  4. Aug 29, 2018 at 4:40 AM
    #3644
    ChadsPride
    Totes. When's your radio coming in?
  5. Aug 29, 2018 at 4:50 AM
    #3645
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  6. Aug 29, 2018 at 4:52 AM
    #3646
    ChadsPride
    EatSleepTacos[QUOTED] likes this.
  7. Aug 29, 2018 at 7:17 AM
    #3647
    AR15xAR10
    Gotta talk with @Taco Guy11 about that one
  8. Sep 10, 2018 at 8:45 PM
    #3648
    AR15xAR10
  9. Sep 27, 2018 at 10:00 PM
    #3649
    AR15xAR10
    New bumpstop johnnies to go on
    Soul Surfer and ChadsPride like this.
  10. Sep 28, 2018 at 12:21 PM
    #3650
    AR15xAR10
    Bumpstops are on:
    It was a massive pain in the ass to remove the factory ones. But i’m glad its done.
    Manfred, Soul Surfer and ChadsPride like this.
  11. Sep 28, 2018 at 12:21 PM
    #3651
    AR15xAR10
    New exhaust tip:
  12. Sep 28, 2018 at 2:06 PM
    #3652
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What made you go with ES vs super bumps?
  13. Sep 28, 2018 at 5:34 PM
    #3653
    AR15xAR10
    DID YOU SEE THEM, THEY’RE FUCKING RED RANDALL, RED!!!!!!
    That means its automatically faster.
  14. Sep 28, 2018 at 5:35 PM
    #3654
    AR15xAR10
    Also these were $29.
    So fuck the $65 for superbumps
  15. Oct 2, 2018 at 1:16 PM
    #3655
    AR15xAR10
    happy birthday Brandon!!!!! @vrod671
    vrod671 and ChadsPride like this.
  16. Oct 3, 2018 at 3:19 PM
    #3656
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Thanks, my bro!
  17. Oct 3, 2018 at 3:56 PM
    #3657
    AR15xAR10
    <3
    ChadsPride and vrod671[QUOTED] like this.
  18. Oct 3, 2018 at 4:55 PM
    #3658
    ChadsPride
  19. Oct 7, 2018 at 8:04 AM
    #3659
    AR15xAR10
    THINGS TO DO @ or BEFORE 100k:
    New Upper control arms
    New Lower control arms
    Rebuild OEM driveshaft (have the stuff)
    All new poly cab mounts (have the stuff)
    More lift
    New headlights
    Finish CB radio setup
    New clock spring assembly
    New steering shaft ujoint assembly
    New headunit with apple car play
  20. Oct 7, 2018 at 4:48 PM
    #3660
    AR15xAR10
    Maintenance History:
    0-24,900 miles- No idea, Previous owner kept no records, but i am told dealer did all servicing
    Purchased from Younger Toyota of Hagerstown MD April 2012
    25,100 Firestone Destination AT tires P245/75/16
    27,000 Oil + Filter changed Valvoline Conventional
    28,256 Tires rotated/balanced, retorqued
    30,000 Oil + Filter changed Valvoline
    31,391 Tires Rotated, Drums Painted
    33,009 Oil + Filter Changed Valvoline
    36,000 3/21/2014 Tires Rotated
    36,211 Hankook Dynapro ATM LT245/R16 E
    36,630 EBC Stage 5 Brake kit
    37,700 Squeaky Ujoints greased
    37,770 Transmission, T Case, F/R Diff Fluid Changed
    38,000 Seatbelt Recall Done (Younger Toyota-Hagerstown MD)
    38,500 New Cabin Air Filter
    39,000 Oil + Filter Changed Valvoline + Tires Rotated
    42,000 Oil + Filter Changed Valvoline + Tires Rotated
    45,026 Oil + Filter SWITCHED to Mobil 1 Full Synthetic + Tires rotated + Ujoints Greased
    45,818 Battery Terminals Cleaned, MAF Cleaned, Throttle Body Cleaned
    46,522 Oil + Filter Changed again Mobil 1
    48,150 Tires Rotated
    49,900 Pinion Seal Replaced
    50,079 Oil + Filter Changed + Tires Rotated + New Battery + Duralast Gold Brake pads
    50,621 1/29/2016 K&N Washable Cabin Air Filter
    52,317 Rear 5100s and TSB Leafs with all new Hardware
    52,680 Front 5100s on 883s + Moog Tie Rod Ends + ECGS Front Diff Bushing + Alignment
    52,836 Tires Rotated and Ujoints Greased
    54,334 Denso Spark plugs (.40 Gap)
    54,975 Oil + Filter Changed + Ujoints Greased
    55,375 FN Six Shooters 17x8 + Cooper ST MAXX LT265/70R17E
    55,575 EBC Rotors Duralast Gold Pads
    55,600 Sumo Springs (1000lb Rated)
    57,000 Tires Rotated
    57,500 Power Steering Fluid switched to Mobil 1 Synthetic ATF
    59,575 Carrier Bearing and Ujoints replaced Advanced Auto Parts
    59,880 Oil + Filter Changed + Tie Rods Greased + Cabin AF Cleaned + MAF/Throttle Body Cleaned + Engine Air Filter Cleaned
    59,853 Rear Diff Fluid Changed
    60,577 New ECGS Third Member with Factory Limited Slip and Solid Spacer + Wholesale Import Parts Replacement Driveshaft
    61,150 Rear Diff, Tcase, Front Diff switched to Lucas 85-140w Conventional Gear oil
    62,884 Tires Rotated
    64,927 Oil + Filter Changed + Filters Cleaned
    69,985 1/13/2018 Oil + Filter Changed + Ujoints Greased
    72,619 Tires Rotated
    73,000 3/7/2018 Transmission Serviced (Filter + Toyota Fluid)
    74,097 New Serpentine Belt, Belt Tensioner, and Idler Pulleys
    74,795 Oil + Filter Change
    78,680 6/18/2018 Radiator Flush, HPS Silicone hoses, TRD Radiator cap, new Serp belt and bottom Idler Pulley
    79,955 Oil + Filter Changed
    81,365 Falken Wildpeak MT01 in LT265/70R17 E
    82,500 Tires Rotated
    RobP62, DrFunker, Soul Surfer and 4 others like this.
