Built For the Internet...By the Internet Mall Crawler (AR15xAR10's Build Thread)
Discussion in '2nd Gen. Builds (2005-2015)' started by AR15xAR10, Feb 24, 2017.
  1. Aug 30, 2024 at 1:50 PM
    #4501
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Good catch then!
    AR15xAR10[QUOTED][OP] likes this.
  2. Sep 20, 2024 at 4:11 PM
    #4502
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So today started a new issue with my truck that i’ve never experienced before. I used 4wd Hi and Low off and on a couple times yesterday with no issue and this morning with no issue. Then this afternoon two separate times in which i wanted to use it, i had to shut the ignition completely off, turn the knob, then turn the truck back on and it would automatically shift into 4wd. Now, it will come out of it just fine….but every single time i want to go INTO 4wd, i have to shut the truck off and turn it back on. Very frustrating.
    Road_Warrior likes this.
  3. Sep 20, 2024 at 4:56 PM
    #4503
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    That is super frustrating.
    I’ve had it happen a few times in the past where the 4x4 hi wouldn’t engage when I turned the knob, or it wouldn’t go back to 2wd after being in 4 hi.
    It’s been a while since it’s happened but I feel like when I was researching the issue, I found some TW posts saying that it can happen after driving through water. Could that be a factor? I also could be misremembering.
  4. Sep 20, 2024 at 5:45 PM
    #4504
    AR15xAR10
    It just rained for three days and i didnt drive it at all in the rain
  5. Sep 20, 2024 at 5:45 PM
    #4505
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Well then that theory is out the window lol
  6. Sep 21, 2024 at 3:40 PM
    #4506
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Im having that too. But 4lo beeps at me. Im going to more expensive route, and replacing my tcase.
    Doesn't it state in the manual that 4wd needs to be used monthly to keep it lubed?
    https://youtu.be/29c5XJjycFo?si=LBytbzQc5PrFfqxB
  7. Sep 21, 2024 at 3:55 PM
    #4507
    AR15xAR10
    But is your new one truly manual or is it just a lever that does the same thing as the electronic switch like my 4runner used to?
  8. Sep 21, 2024 at 4:03 PM
    #4508
    fatfurious2
    David
    Ashburn, VA
    Its from a FJC/4runner. Truly manual shifting. I will need to rewire the electrics to have the lights working, but manually shift from 2H to 4H and 4L
  9. Sep 21, 2024 at 4:24 PM
    #4509
    AR15xAR10
    But my 4runner still had ADD in the front diff even though it had that same tcase…
  10. Sep 21, 2024 at 4:43 PM
    #4510
    fatfurious2
    David
    Ashburn, VA
    I will be deleting ADD
  11. Sep 21, 2024 at 4:45 PM
    #4511
    AR15xAR10
    I’ll let you pave the way and then you can come do mine :p
  12. Sep 21, 2024 at 5:21 PM
    #4512
    fatfurious2
    David
    Ashburn, VA
    Either buy the tube, or score one on ebay and ill swap it. While you're there, get a FJ case
  13. Sep 25, 2024 at 3:47 PM
    #4513
    BradyT88
    BradyT88 Well-Known Member
    I'm pretty rusty on this stuff, but when you shift into 4Hi the light will blink while it's waiting on the ADD sensor to say it's engaged. I suspect it is also waiting on a sensor from the Tcase. Since shutting it off and back on works it sounds like the solenoids are working and the ADD and Tcase are engaging but they are not getting the signal back to the computer. It sounds like the sensors are also working unless possibly turning it off and back on bypasses them somehow (I kinda doubt it though).
  14. Sep 25, 2024 at 4:02 PM
    #4514
    fatfurious2
    David
    Ashburn, VA
    Looks like you guys need to do some reading
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
  15. Sep 25, 2024 at 7:48 PM
    #4515
    AR15xAR10
    When i had my issue, i got no dash light at all. No flash. No illumination at all. It was super weird.
  16. Sep 26, 2024 at 3:22 AM
    #4516
    fatfurious2
    David
    Ashburn, VA
    Was your truck on?
  17. Sep 26, 2024 at 5:12 AM
    #4517
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    you dont need your truck on! crazy talk!
    AR15xAR10[OP] likes this.
  18. Sep 26, 2024 at 6:11 AM
    #4518
    AR15xAR10
    :rolleyes:
    BradyT88 and fatfurious2[QUOTED] like this.
  19. Sep 28, 2024 at 3:55 PM
    #4519
    AR15xAR10
    Just replaced my MAF with a brand new denso unit from rockauto
    lets hope that fixes my randomly occurring p0101 code
  20. Nov 17, 2024 at 7:40 AM
    #4520
    AR15xAR10
    While doing an oil change friday night i found that my driver’s side caliper has a sticking piston that is causing the in board pad to drag. So now its time for new calipers, pads, and rotors.
    i investigated going to 5th gen 4runner brakes. Determined that it was not worth the extra $200-250 for under 10% of POTENTIAL stopping power gain. The rotors are considerably heavier at 21lbs vs 18.5lbs. So unsprung weight nearly negates the potential performance gain in the larger bore of the pistons and larger pad surface area. The brake pads are the same part number so you gain almost NOTHING. Plus its just too much shit to mess with this close to winter.
    I ordered new stoptech rotors. Now i need to find pads and choose calipers. I’m leaning towards napa calipers as those are what i put on my 3rd gen 4runner and they were great
    fatfurious2 and Road_Warrior like this.
