Built my truck on Toyota’s website and..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by invicis9094, Jul 6, 2021.
  1. Jul 6, 2021 at 9:20 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    I read it twice and am confused too.... So OP "rebuilt" his current truck on the Toyota site and is upset that NOW it's offered as LED only....
    Kev250R likes this.
  2. Jul 6, 2021 at 9:21 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Have you compared purpose built LED lights/housings to your purpose built halogen lights/housing or did you just put LED bulbs in your halogen housings expecting to get something good out of it?
    CG256, Junkhead, Kev250R and 3 others like this.
  3. Jul 6, 2021 at 9:21 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Aftermarket LED's tend to be garbage.
    Honestly? Have you compared OEM LED's to OEM halogens in an actual nighttime driving scenario? I have and there is no comparison between the halogens that come stock on the Taco vs. their LED counterparts.
  4. Jul 6, 2021 at 9:24 AM
    Koolbreeze7
    Jon
    Jersey
    That is odd....The OEM Halogens on my 17 were garbage. The OEM LEDs are a huge improvement. Ive driven both
    Bedawson, TRD-ED and Lt. Dangle like this.
  5. Jul 6, 2021 at 9:25 AM
    db6598
    db6598 Well-Known Member
    NC
    This problem can be solved for $1,400-$1,500.
    Lt. Dangle likes this.
  6. Jul 6, 2021 at 9:27 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    It is regional, Here in Florida you can only get the optional LED headlights if you get the $5100 premium tech upgrade ( thanks SET) but go but go out of the state/SET area and you can get the $485 package.
  7. Jul 6, 2021 at 9:28 AM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Just convert them to HID from xenon depot.
    HID bulbs work so well with our housings.
    Not sure why Toyota went as far as to give us projector housing and then not put HIDs in them.
    I personally prefer HIDs over LED.
    If you convert your lights to LEDs and live in a cold climate they won't produce enough heat to melt ice build up.
  8. Jul 6, 2021 at 9:28 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Reread for comprehension...
  9. Jul 6, 2021 at 9:32 AM
    tjswope
    tjswope Well-Known Member
    Tom
    Chester County, PA
    2019 cement off road double cab MT
    A bunch of smalls
    Toyota’s website only lists configurations that are actually available in your area, so I would assume that there aren’t any voodoo blues available without the LED option. That was obviously not the case when you bought your truck.
    xJuice and Koolbreeze7 like this.
  10. Jul 6, 2021 at 9:35 AM
    Lt. Dangle
    Ohio
  11. Jul 6, 2021 at 9:35 AM
    Koolbreeze7
    Jon
    Jersey
    Try it with a VPN and a different zip code?
  12. Jul 6, 2021 at 9:44 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    I have the OEM Toyota LED's. The Halogens aren't even in the running against the factory LED's.
    I can see these things reflecting off of road signs (especially White) twice as far as any other vehicle I've ever owned.
    They could even take bright away as an option as you only need dim.
    And Toyota has the technology down to. Never been flashed for bright lights, not once.
  13. Jul 6, 2021 at 9:46 AM
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    Agreed. My 2017 had some of the worst halogens I have experienced. They were set low from the factory but still sucked after a proper aim. The 2020 with LED has been great.
    TRD-ED[QUOTED] likes this.
  14. Jul 6, 2021 at 9:52 AM
    Travlr
    Middle'a Utah
    Yeah... that's a good point. LEDs reflect off reflective road signs better than halogens, for sure. But looking at the road surface or a deer stepping into your path I would take halogens.
  15. Jul 6, 2021 at 9:53 AM
    #35
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Must be rough having such poor vision that night time driving is impossible without the miracle that is LED headlights.
    :stirthepot:
  16. Jul 6, 2021 at 9:57 AM
    #36
    TRD-ED
    Lenoir NC.
    Hence, my comments about only needing dim. The OEM LED's light up the road on dim equal or better than most cars/trucks I've owned on bright
    Kev250R likes this.
  17. Jul 6, 2021 at 10:04 AM
    #37
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    i have LED’s on my tacoma and drive a Ford with LED’d for work. Gonna be honest, the Ford LED’s aren’t very good. I would find a Tacoma with them and report back. I would bet the results change.
    TRD-ED likes this.
  18. Jul 6, 2021 at 10:08 AM
    #38
    Travlr
    Middle'a Utah
    And see? That is where my experience is different. Oncoming LEDs look like aircraft landing lights... and you would expect that they would illuminate everything better than halogens. But while a reflective surface will shine bright, anything non-reflective doesn't seem to be as well illuminated. I've had this discussion with several other people too, and some people like LEDs and others just think the issue is about hype over new technology. I don't like LEDs as well as halogens, or for that matter as much as incandescents. They just don't illuminate as well. But some people see it differently.
    And this leads me to wondering if there is, indeed, a difference in how we see.
    I would never choose to use LEDs in my home.
  19. Jul 6, 2021 at 10:14 AM
    #39
    Traction
    WA
    2020 TRDOR
    I have also noticed that LED lighting within the Toyota range is variable. While my Tacoma is great, our 2019 RAV that we had for a short time had really terrible light output with the LED lighting.
    Travlr likes this.
  20. Jul 6, 2021 at 10:20 AM
    #40
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I suggest you drive a 20+ Taco with the factory LED headlights. The difference may surprise you. I travel frequently in rural areas at night and find that I now rarely need my high-beams or my driving lights.
    I LED’d all the fixtures in my house before I finished un-packing. My electric bill (when I don’t use my central air) is ~$50 in an area where comparable houses are spending $80-100 for electric. So yes, I’m a fan of this newer technology :thumbsup:
    TRD-ED likes this.
