Built Right UCA Caster 3.4?
Discussion in 'Suspension' started by jspadaro, Sep 3, 2010.
  1. Sep 3, 2010 at 10:21 AM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Camber and toe are both 0, caster is 3.4 on both sides. This is what they could get me. Anyone have better luck with the built rights? Also, is this dangerous to my truck for any reason? if the caster is too high, I'll just see some rubbing right?
    Also, my CV boots should be fine as long as the fins aren't touching right? I have about 1.75"-2" of lift up front with my leeper coilovers.
    Thanks! :D
  2. May 24, 2011 at 7:51 PM
    tonyplanet
    tonyplanet Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    I'm having caster issues too. Caster doesn't have effect on tire wear like Toe and Camber does.
    My caster is is between 4.8 and 5.0. I wouldn't say its dangerous to have this much caster. Have you had any better luck adjusting your caster since last?
  3. May 24, 2011 at 7:54 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    The rubbing you will experience will be in front on the bumper and fender liner, no need to worry about tire tread wear, just drivability and rubbing.
