BULB SIZE OR LEDS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nrojay, Jan 8, 2013.
  1. Jan 8, 2013 at 3:22 PM
    nrojay
    nrojay [OP] Active Member
    PARIS, TX
    05 tacoma
    I need to know what size Bulb or led will fit in the
    Fog light switch and Rear differential switch on dash
    both of mine are out, they are tiny
    I was going to order some leds from Super bright leds
  2. Jan 8, 2013 at 3:45 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  3. Jan 8, 2013 at 3:51 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  4. Jan 8, 2013 at 4:14 PM
    nrojay
    PARIS, TX
    05 tacoma
  5. Jan 8, 2013 at 5:59 PM
    File IFR
    Central MA
    As long as the socket feeds the lamp at 3 volts, otherwise you'll need a resistor inline.
  6. Jan 8, 2013 at 6:21 PM
    nrojay
    PARIS, TX
    05 tacoma
    NEOx-xHP: NEOx LED Bulb - High Power Instrument Panel LED
    [​IMG][​IMG]
    • NeoWedge series 1 High Power SMD LED Twist Lock Instrument Cluster and Gauge illumination bulb
    • 6 lumen
    • Available in 3mm, 4mm, 5mm sizes and five LED colors
    • Price for each.
    Select OptionsPart#: NEO3-RHPColor: [​IMG][​IMG][​IMG][​IMG][​IMG]LED Package: 3 mm (T-1)4 mm5 mm (T-1 3/4)
    $ 2.29
    [​IMG] [​IMG]
    Qty:
    Its either a 3mm, 4mm or 5mm in size here is what im looking at on Super Bright leds
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/instrument.html#
    A while back I saw something on the forum stating the size of led to replace this with, I have been searching this thing for the last few hours :frusty:
  7. Jan 8, 2013 at 6:33 PM
    File IFR
    Central MA
    Take the dead bulb out and measure the base.
    Those LEDs are already equiped with resistors, you're good there.
    ... I thought you were going to install an LED from scratch by soldering it in yourself... my bad. :eek:
  8. Jan 8, 2013 at 6:39 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    The fog light switch will be the 3mm ones on SuperbrightLEDs. I'm not sure if the diff one is the same. Take them out and compare.
  9. Jan 8, 2013 at 7:11 PM
    nrojay
    PARIS, TX
    05 tacoma
    Thank you guys so much for your help
    I just ordered them, I will post a reply to let you all know if they workout:D
    Yes they are the same size on both of them
  10. Jan 12, 2013 at 7:16 AM
    nrojay
    PARIS, TX
    05 tacoma
    Ok the lights mentioned above are perfect minus just a little shaving with a knife.
    On the led is 2 pieces of plastic on each side of the led that are used to twist and lock in
    I shaved those of, the led then slides into the slot and locks in
    If it does not come on, rotate the led in the slot
    www.Supperbrightleds.com
    Use the NEOx-xHP, 3mm in the color you want $2.29 each
    Just an FYI if you decide to buy
  11. Jan 12, 2013 at 4:14 PM
    Drunknsloth
    Retribution
    South West
    Why did you shave off what locks it in?
  12. Jan 12, 2013 at 4:17 PM
    flyzeye designs
    flyzeye designs Revised Company Logo
    Darren
    Mesa, AZ
    double-cab long-bed 4X4 debadged TRD Sport
    6 inch lift, tinted windows, custom tail lights, custom Red/White/Red-Black FLYZEYE Designs TCMA-0513 V2W interior light Custom Powder-Coated Devil Horns by Andres
    Nice!!! :cool:
  13. Jan 12, 2013 at 6:03 PM
    nrojay
    PARIS, TX
    05 tacoma
    If you do not it will not fit, even after trimming it fits very tightly.
  14. Jan 12, 2013 at 8:45 PM
    Drunknsloth
    Retribution
    South West
    Did you trim the entire locking part off? Or just trimmed it down? And what did you use?
  15. Feb 7, 2013 at 8:33 PM
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    Nice work OP! Ive been searching for two replacement bulbs for a few of my switches. Thanks for finding these and following up with the "after" info.
