Bull Bar and Winch Bumper Practical?
Discussion in '4 Cylinder' started by yotatildeath2010, Jan 29, 2012.
  1. Jan 29, 2012 at 12:12 AM
    yotatildeath2010
    yotatildeath2010 [OP] Member
    Reno, NV
    '11 2.7L 4 Cylinder 4x4
    I recently purchased my first toyota, a used 2011 Regular Cab 4 cylinder 4x4 (not lifted and pretty much like it came off the factory floor) and I'm curious about adding something like the ARB Bull Bar & Winch Bumper to it. I have questions about what it would do to my mpg's? the approximate cost inculding fog lights and 3000lb winch? Should I get a lift and bigger tires before putting it on? and if it's even really that practical for a 4 cylinder? I would really appreciate your guys' input on this idea. Thanks.
  2. Jan 29, 2012 at 12:20 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    do you want to lift the truck?
  3. Jan 29, 2012 at 12:20 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    You're going to need heavier duty front springs and shocks to handle the weight of the ARB bumper and you'll want more than a 3k lbs winch the average rule of thumb is to get a winch that is rated at twice the vehicle weight.
    you can find an ARB bumper here used every so often for $6-800 or new for about a grand
    a good winch will run you another $600-1000 bucks
    new shocks springs will be another $400-1500 dollars
    tired will be another 800-1200 dollars depending on what you go with
  4. Jan 29, 2012 at 12:22 AM
    KalamaKid
    Oregon
    why so much on the winch? A warn M8000 is only $400
  5. Jan 29, 2012 at 12:23 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    just ball parking numbers
    low and high
    m8000 for 400 or an XD9000i 9.5 for 1200
  6. Jan 29, 2012 at 12:25 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Right in Reno?! My shop is on the edge of Sparks, on Greg st.
    Hit me up if you're interested in any of my bumpers/armor.
    I can even do aluminum to keep it light weight since it seems to be a concern with your 4banger. :)
  7. Jan 29, 2012 at 12:25 AM
    KalamaKid
    Oregon
    Before you buy a lift,figure out what kind of weight your going to put on your front end.
  8. Jan 29, 2012 at 12:38 AM
    yotatildeath2010
    Reno, NV
    So I'm probably gonna be around $3500-4500 roughly? I think I definately would like the ARB for it's strength and integrety but I haven't yet got a full grasp of what else is out there yet. I figured I would need better springs and shocks. How much of a lift would you suggest with the ARB?
  9. Jan 29, 2012 at 12:40 AM
    yotatildeath2010
    Reno, NV
    Yes I do but not too much. Just enough to put a decent set of offroad tires on it. I just have the stock street ones on it right now.
  10. Jan 29, 2012 at 12:43 AM
    KalamaKid
    Oregon
    Before you buy a lift figure out how much weight your going to add to your front. Buy it all at once. Relentless is local and makes a really good product. Add a winch to it and your looking at 250LBs+ this will effect the type of coil you need to buy if your going to go something basic like OME
  11. Jan 29, 2012 at 12:48 AM
    yotatildeath2010
    Reno, NV
    Ok cool. Yeah I think I've driven past a couple times. I'll have drop in by sometime soon to get an idea of what you think would be best for all this. What's the adress on Greg?
  12. Jan 29, 2012 at 12:49 AM
    RelentlessFab
    Eric
    Sparks, NV
    shooting you a PM
  13. Jan 29, 2012 at 12:51 AM
    yotatildeath2010
    Reno, NV
    Yeah that makes sense. Thanks for the tip. What do you think that kind of weight would do to the mpg's? If you factor in the lift and and some tires.
  14. Jan 29, 2012 at 1:00 AM
    RelentlessFab
    Eric
    Sparks, NV
    As for weight, if you go aluminum the bumper is only about 60lbs so you might be adding 30-40lbs there over stock, then the winch which is about 80-90lbs. Add roughly 50lbs if you go with one of my steel bumpers. So that means adding 180lbs max with my stuff.
    Arb alone is around 160lbs from what I've read.
  15. Jan 29, 2012 at 1:09 AM
    KalamaKid
    Oregon
    Aluminum bumper you make is nice!
  16. Jan 29, 2012 at 1:11 AM
    RelentlessFab
    Eric
    Sparks, NV
    Thanks Jason!
  17. Jan 29, 2012 at 1:25 AM
    yotatildeath2010
    Reno, NV
    I really appreciate all the help guys! Thanks!
