Bull Bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slimbrady90, Nov 14, 2015.
  1. Nov 14, 2015 at 9:26 PM
    Slimbrady90
    Slimbrady90 [OP] Member
    Brady
    Utah
    Barney
    96 4 cylinder
    I've got a 96 2.7 4x4 that I'm looking for a bull bar for. I've looked online and haven't been able to find anything. Anyone know where I can pick one up or if it's possible to get a newer one and modify it to work?
  2. Nov 14, 2015 at 9:29 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I feel confident the bull bar will get negative feedback.
    cleats50 likes this.
  3. Nov 14, 2015 at 9:30 PM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    Why do you say that?
  4. Nov 14, 2015 at 9:31 PM
    HBGIBBY
    HBGIBBY Well-Known Member
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
  5. Nov 14, 2015 at 9:33 PM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    What is wrong with a bull bar?
  6. Nov 14, 2015 at 9:39 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Welcome to TW
    You're going to get an overwhelmingly negative response from TW regarding bullbars. They aren't attractive, and they offer no additional protection and in many cases, in accidents, end up making contact with the bumper, grille and hood causing more damage had the bar not be installed in the first place.
    If you are looking for added protection get a plate bumper, if you are looking to mount lights, there are a couple companies that make dedicated front bumper light bars that are quite streamlined.
    Hamer95USA likes this.
  7. Nov 14, 2015 at 9:41 PM
    HBGIBBY
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    The consensus here on TW is that it is an inferior product and only usable as a place to mount lights. After having the Avid bar in my hands, I am very pleased with the thick-wall tube construction. Like Pablo says, if you are going to push with it, need a plate bumper, for something just a bit more functional than the Bull Bar, get the Avid...
  8. Nov 14, 2015 at 9:50 PM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    I appreciate your concern but I'm looking for a bull bar. The link you shared isn't even for my 96. I'm looking for a bull bar that will fit my 96 so any help with that would be appreciated!
    T4RFTMFW likes this.
  9. Nov 14, 2015 at 11:32 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
  10. Nov 15, 2015 at 8:48 AM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    Pablo what did you search to find this? I've looked on Amazon several times and haven't seen anything that fits first gens.
  11. Nov 15, 2015 at 9:40 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Not tryna add to the hate on bull bars but theres a reason you dont see them on the 95-97 front end because they really dont go together. Westin used to make a "safari light bar" that looked pretty good but i dont think they make them anymore.
  12. Nov 15, 2015 at 11:59 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I just typed in "Amazon.com 1996 Toyota Tacoma Bullbar" into google and it popped up. I almost never use the actual website's search function on any website (including TW) and instead just type into google, the website I want to search, and then the search phrase I'm looking for.
  13. Nov 15, 2015 at 4:36 PM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    Thanks for the info Pablo
  14. Nov 15, 2015 at 11:50 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Def a damage multiplier and negative impact on approach angles....... But they do make good light mounts...... They should never have been called bull bars many yrs ago........ Iirc that term came from long haul truckers and the fellas in the outback who also call them 'roo bars.. Def a different aminal.
  15. Nov 16, 2015 at 9:35 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Three HUNDRED dollars shipped for that piece of scrap metal? :facepalm:
  16. Nov 16, 2015 at 10:23 AM
    Maestro
    Maestro Well-Known Member
    The Master
    Agreed, but in some cultures, bull-bars are considered a style element.
    Personally, I think they reduce the value of a vehicle, but everyone has their "thing."
    Wyoming09 likes this.
  17. Nov 16, 2015 at 4:40 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Well, I'm selling mine! But I'm probably to far away
  18. Nov 16, 2015 at 7:54 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    brush guard...... Even the name sounds funny...... Cuz u know, brush is hardcore
  19. Nov 16, 2015 at 8:02 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Go Rhino makes the bull bar that I have on my 99 and 03.
    Or if you like this police style bull bar design and have the cash/want a winch then check out Warn.
    This bull bar mounts to the bottom of the frame with 4 bolts and the top of the frame with 2 more bolts. This is much stronger than your average bull bar. You can also mounts lights, stand on it, and even mount the light bar portion to the bumper in two spots for even more stability (though you'd need to fab your own mounts, the points already exist, I did it on my 99)
    Hamer95USA and Justus like this.
  20. Dec 27, 2015 at 10:18 AM
    Slimbrady90
    Brady
    Utah
    Barney
    96 4 cylinder
    I know there's a lot of negativity towards them but I was able to find one and get it installed. I really like the way it turned out on Barney!
    95_Taco_831, esnook and JKU3000 like this.
