Bullet Proof Fab heavy duty tow hook install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rooney2oons, Jan 17, 2016.
  1. Jan 17, 2016 at 10:10 AM
    rooney2oons
    rooney2oons [OP] Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    the factory hardware on the 2016 is too long to use without using lots of extra washers. What have you guys done?
  2. Jan 17, 2016 at 10:12 AM
    DeTako
    DeTako Well-Known Member
    Felix
    Florida
    '16 TRD Sport 4x4 DCSB
    You may have mixed up the bolts, one is longer than the other two. I just installed the tow hook with no issues. 17mm socket, 3 bolts total.
  3. Jan 17, 2016 at 10:15 AM
    rooney2oons
    Dallas, Tx
    i have the short one that was holding on the end piece (not sure wtf that's for) and the other 2 are long enough to go through the factory hook and into the frame. the 2 long ones are too long.
  4. Jan 17, 2016 at 10:18 AM
    DeTako
    Felix
    Florida
    That makes no sense on my end, considering the BP tow hook is thicker than the OEM one. Which would make the bolts too short if anything. Wish I could help more... Are you replacing the passenger side hook?
    Side note: I also have no idea what that outter bolt is for. When you take it out, you can adjust/remove a rectangle piece of metal.
  5. Jan 17, 2016 at 10:21 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    does this count as a rated recovery point good for snatch strap and winching? or just for tow trucks to drag your broken down ass onto a flat bed
  6. Jan 17, 2016 at 10:23 AM
    DeTako
    Felix
    Florida
    I thought it was a recovery point, but now you mention it... I don't know. I'll have to dive into the manual and see.
  7. Jan 17, 2016 at 10:24 AM
    Joe23
    was just looking on BPF page and its rated for 8200lbs.
    might be fine for winching but not sure about using a snatch strap on it. given most snatch strap recovery points are usually rated 12 000lbs. anyone with some info? I guess it could depend on the truck but I know most full size call for at least a 12 000lb rating.
    And when you're talking about a chunk of metal flying at those speeds...rather make sure its rated.
    DeTako[QUOTED] likes this.
  8. Jan 17, 2016 at 10:27 AM
    rooney2oons
    Dallas, Tx
    This is what I got going on. Passenger side. the factory hook on the right comes off, 2 long bolts. the new bpf goes on and is not as thick.
    blackrifle76 likes this.
  9. Jan 17, 2016 at 10:34 AM
    DeTako
    Felix
    Florida
    You have a different OEM hook than I did. I have a TRD Sport. I wonder if the OR has a different setup. Here's my OEM hook:
  10. Jan 17, 2016 at 10:34 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
  11. Jan 17, 2016 at 10:36 AM
    DeTako
    Felix
    Florida
    Boom! Question answered! BP should have let the buyer know that... And maybe even supply needed hardware for the OR.
  12. Jan 17, 2016 at 10:36 AM
    rooney2oons
    Dallas, Tx
    that would be the issue. how do i tag the bpfab guy?
  13. Jan 17, 2016 at 10:37 AM
    rooney2oons
    Dallas, Tx
    been out of cars wrenching for years. can i buy those bolts at my local parts place?
  14. Jan 17, 2016 at 10:41 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Should be able to find them anywhere that has a decent supply of metric bolts. Also pick up some M12 washers as the factory ones are stuck on the bolts (at least they were for me). Home depot didn't have but a local hardware store had 8.8 grade bolts.
  15. Jan 17, 2016 at 10:42 AM
    DeTako
    Felix
    Florida
    Should be an easy find. Fairly common bolt in the auto world. Shoot, you might even find them at Lowe's... But I'd check an parts shop first.
  16. Jan 17, 2016 at 10:44 AM
    rooney2oons
    Dallas, Tx
    thanks guys. I would have eventually found shorter bolts, but a little notice would have been nice. got too much going on today. taco, damn jeep broke, steelers game, and i wanted to go pplay in the dirt.
  17. Jan 17, 2016 at 10:52 AM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Same thing happened to me. No big deal just leave everything off and go have fun. Just try to get stuck the other way round :)
    Take care.
    B.
    wahoobie likes this.
  18. Jan 17, 2016 at 2:21 PM
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
  19. Jan 17, 2016 at 2:23 PM
    rooney2oons
    Dallas, Tx
    Bought some bolts and installed. Done deal.
  20. Sep 14, 2017 at 8:12 PM
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
    hey there....
    was just looking to bolt this thing on my 2015 - so this 1/2" thick hunk of steel bolts to what looks like about 14 ga "frame" material with 2 + 1 weld nuts on it?? am i seeing this correctly?
